> Free pascal compiler for 8051
Igor Funa
сообщение Aug 6 2008, 10:58
Пользователь №: 39 461
For those who like programming in Pascal here is Turbo51 - a free Pascal compiler for the 8051 family of microcontrollers:
http://turbo51.com/
It features a fast single pass optimizing compiler, Borland Turbo Pascal 7 syntax, full floating point support, mixed Pascal and assembler programming, full use of register banks, advanced multi-pass optimizer, smart linker, generates compact high quality code, output formats include binary, Intel HEX and assembler source.
Igor
Ответов (1 - 6)
Konst_777
сообщение Aug 6 2008, 18:45
Пользователь №: 5 644
This is great project Igor. a14.gif Please accept my sincere appreciation for your work.
I hope that you can implement "Import of OMF51 object files" and "Generation of OMF51 object files" before very long.
LEAS
сообщение Aug 15 2008, 11:50
Из: Город Невест
Пользователь №: 38 619
I have posted to thise subject, but from my mistake i posted to AVR . This is not IDE, compiler only! You need to read author's suite to get recommendations on Text Editor and so on.
Igor Funa
сообщение Aug 25 2008, 05:27
Thanks. Import of OMF51 object files needs a lot of work since without proper calling conventions it won't be of much use. Generation of OMF51 absolute object file is planned for next release.
Igor
Igor Funa
сообщение Sep 22 2008, 06:13
Some months ago I have posted information about availability of Turbo51 - a free Pascal compiler for the 8051 family of microcontrollers.
Now Turbo51 can generate absolute OMF-51 extended object file needed for source-level debugging. You can use Keil uVision, Silabs IDE, Raisonance RIDE or any other IDE/debugger that supports OMF-51 object files.
http://turbo51.com/
Igor
Igor Funa
сообщение Sep 22 2008, 06:16
Turbo51 can now generate absolute OMF-51 extended object file needed for source-level debugging. You can use Keil uVision, Silabs IDE, Raisonance RIDE or any other IDE/debugger that supports OMF-51 object files.
http://turbo51.com/
Igor
Konst_777
сообщение Sep 29 2008, 17:39
http://turbo51.com/
Igor
This is good news. In my following design I will without fail try to use your Pascal compiler.
RSS Текстовая версия Сейчас: 27th July 2025 - 08:00
Страница сгенерированна за 0.01436 секунд с 7
