> Reverse Engineering в CAM350 v10, научно-популярное кино
Yuri Potapoff
сообщение Oct 21 2008, 16:52
Из: Железнодорожный
Пользователь №: 1 093
Reverse Engineering
If you are working with "legacy" data in a Gerber format, DownStream can "Reverse Engineer" it for you. Reverse engineering is the process of starting with Gerber files then adding part and netlist information, to create an intelligent database, which can be brought back to any CAD system.
How does it Work
Using Gerber files, Reverse Engineering will perform what is called netlist extraction. The netlist extraction process is fully automated and even supports the most complex blind & buried vias, MCMs and hybrid designs. Once all the information has been recreated and recovered, the new data file can then be imported back into your CAD system of choice.
Add part and netlist information to a Gerber file
Perform Netlist Extraction
Import the new intelligent data into your current CAD system
View the Demo
We have created demonstrations to help walk you through this unique functionality. These demos are divided into three parts to show you each individual process that make up Reverse Engineering.
Part One: Data Preparation - 6 minutes - View Demo or Download Demo
Part Two: Building and Adding Parts - 6 minutes - View Demo or Download Demo
Part Three: Exporting Data and Reading into your CAD System - 90 seconds - View Demo or Download Demo
When do you Need Reverse Engineering
Reverse Engineering is important if you have an archive of old designs - stored as Gerber files or in another CAD database - that you wish to view, use, or convert to your new system. With the right tools, you can reverse engineer those files to be useful again.
http://www.downstreamtech.com/support/Reve...ngineering.html
RSS Текстовая версия Сейчас: 25th July 2025 - 07:51
Страница сгенерированна за 0.0136 секунд с 7
