> sk-mat91sam9xe512, на 9260 камне
RW9UAO
сообщение Nov 6 2008, 10:14
Пользователь №: 24 688
купил себе игрушку, балуюсь потихоньку. привязываю звуковой кодек и блок от тв тюнера к I2C.
вопрос - как записать в тюнер байтики? /dev/i2c у меня нету.
и еще вопрос такой, грузится через раз, когда нормально, когда такое вот выдает:
Starting kernel ...
Linux version 2.6.24 (root@armmaker) (gcc version 4.2.0 20070413 (prerelease) (CodeSourcery Sourcery G++ Lite 2007q1-10)) #38 Thu Oct 9 14:57:43 MSD 2008
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053173
Machine: Starterkit.ru SK-MAT91SAM9XE
Memory policy: ECC disabled, Data cache writeback
Clocks: CPU 200 MHz, master 100 MHz, main 12.000 MHz
CPU0: D VIVT write-back cache
CPU0: I cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
Kernel command line: root=/dev/ram0 rw initrd=0x21100000,0x500000 console=ttyS0,115200 mem=32M
AT91: 96 gpio irqs in 3 banks
PID hash table entries: 128 (order: 7, 512 bytes)
Console: colour dummy device 80x30
console [ttyS0] enabled
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 24548KB available (2428K code, 227K data, 112K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 64 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Time: pit clocksource has been installed.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 5120K
NetWinder Floating Point Emulator V0.97 (double precision)
io scheduler noop registered
io scheduler anticipatory registered (default)
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIAL
atmel_usart.2: ttyS2 at MMIO 0xfffb4000 (irq = 7) is a ATMEL_SERIAL
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
loop: module loaded
ssc ssc.0: Atmel SSC device at 0xc2820000 (irq 14)
MACB_mii_bus: probed
eth0: Atmel MACB at 0xfffc4000 irq 21 (00:1f:f2:00:00:00)
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:01, irq=-1)
Driver 'sd' needs updating - please use bus_type methods
atmel_spi atmel_spi.0: Atmel SPI Controller at 0xfffc8000 (irq 12)
mtd_dataflash spi0.0: AT45DB321x (4224 KBytes)
usbmon: debugfs is not available
at91_ohci at91_ohci: AT91 OHCI
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1
at91_ohci at91_ohci: irq 20, io mem 0x00500000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
udc: at91_udc version 3 May 2006
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
at91_i2c at91_i2c: AT91 i2c bus driver.
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.15 (Tue Nov 20 19:16:42 2007 UTC).
ASoC version 0.13.1
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RAMDISK: Compressed image found at block 0
crc error
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 112K
EXT2-fs error (device ram0): ext2_check_page: bad entry in directory #43: rec_len is smaller than minimal - offset=2048, inode=3471048704, rec_len=2, name_len=144
Warning: unable to open an initial console.
ему памяти не хватает или что? куда рыть?
RSS Текстовая версия Сейчас: 30th July 2025 - 07:51
Страница сгенерированна за 0.01368 секунд с 7
