Библиотеки для вычисления MD5 и SHA-1, Возможно, оптимизированные под х51 |
(1 - 6)
Feb 4 2009, 12:40
Йа моск ;)
Из: Kharkiv-city
Пользователь №: 6 610
Вопрос - нафига Вам x51? MD5 делал для AVR, правда, оптимизировал больше в сторону занимаемой памяти при вменяемом быстродействии. Собирал IAR'ом. Гнусем даже пробовать нехочу, наверняка будет ужасно. Посмотрите, может чем-то поможет. CODE #include "stdafx.h"
#define F1(x, y, z) ( ((x) & (y)) | ((~x) & (z)) ) #define F2(x, y, z) ( ((x) & (z)) | ((y) & (~z)) ) #define F3(x, y, z) ( (x) ^ (y) ^ (z) ) #define F4(x, y, z) ( (y) ^ ((x) | (~z)) )
typedef struct { unsigned long g; unsigned char f; unsigned char e; }MD5STEP_DATA;
static const __flash MD5STEP_DATA table[]= { {0xd76aa478, 7, 0 }, {0xe8c7b756, 12, 1 }, {0x242070db, 17, 2 }, {0xc1bdceee, 22, 3 }, {0xf57c0faf, 7, 4 }, {0x4787c62a, 12, 5 }, {0xa8304613, 17, 6 }, {0xfd469501, 22, 7 }, {0x698098d8, 7, 8 }, {0x8b44f7af, 12, 9 }, {0xffff5bb1, 17, 10}, {0x895cd7be, 22, 11}, {0x6b901122, 7, 12}, {0xfd987193, 12, 13}, {0xa679438e, 17, 14}, {0x49b40821, 22, 15}, {0xf61e2562, 5, 1 }, {0xc040b340, 9, 6 }, {0x265e5a51, 14, 11}, {0xe9b6c7aa, 20, 0 }, {0xd62f105d, 5, 5 }, {0x02441453, 9, 10}, {0xd8a1e681, 14, 15}, {0xe7d3fbc8, 20, 4 }, {0x21e1cde6, 5, 9 }, {0xc33707d6, 9, 14}, {0xf4d50d87, 14, 3 }, {0x455a14ed, 20, 8 }, {0xa9e3e905, 5, 13}, {0xfcefa3f8, 9, 2 }, {0x676f02d9, 14, 7 }, {0x8d2a4c8a, 20, 12}, {0xfffa3942, 4, 5 }, {0x8771f681, 11, 8 }, {0x6d9d6122, 16, 11}, {0xfde5380c, 23, 14}, {0xa4beea44, 4, 1 }, {0x4bdecfa9, 11, 4 }, {0xf6bb4b60, 16, 7 }, {0xbebfbc70, 23, 10}, {0x289b7ec6, 4, 13}, {0xeaa127fa, 11, 0 }, {0xd4ef3085, 16, 3 }, {0x04881d05, 23, 6 }, {0xd9d4d039, 4, 9 }, {0xe6db99e5, 11, 12}, {0x1fa27cf8, 16, 15}, {0xc4ac5665, 23, 2 }, {0xf4292244, 6, 0 }, {0x432aff97, 10, 7 }, {0xab9423a7, 15, 14}, {0xfc93a039, 21, 5 }, {0x655b59c3, 6, 12}, {0x8f0ccc92, 10, 3 }, {0xffeff47d, 15, 10}, {0x85845dd1, 21, 1 }, {0x6fa87e4f, 6, 8 }, {0xfe2ce6e0, 10, 15}, {0xa3014314, 15, 6 }, {0x4e0811a1, 21, 13}, {0xf7537e82, 6, 4 }, {0xbd3af235, 10, 11}, {0x2ad7d2bb, 15, 2 }, {0xeb86d391, 21, 9 } };
/*=============================================*/ static __x_z void _move(char *d, const char *s, UREG l); __x_z void back_memmove(void *d, const void *s, UREG l) { _move((char*)d,(char*)s,l); }
static __x_z void _move(char *d, const char *s, UREG l) { do { *--d=*--s; } while(--l); }
#pragma inline=forced static __x_z void _memcpy_flash(char *d, const char __flash *s, UREG l); #pragma inline=forced static __x_z void memcpy_flash(void *d, const void __flash *s, UREG l) { _memcpy_flash((char*)d,(char __flash *)s,l); }
#pragma inline=forced static __x_z void _memcpy_flash(char *d, const char __flash *s, UREG l) { do { *d++=*s++; } while(--l); }
static __x_z void sum(unsigned long *state, unsigned long *a) { UREG i=4; unsigned long t; do { t=*a++; t+=*state; *state++=t; } while(--i); }
void MD5cheat(char *out_, unsigned char *_p, UREG len) { unsigned long state[4]; static __flash unsigned long state_init[4]={0x67452301,0xefcdab89,0x98badcfe,0x10325476}; memcpy_flash(state,state_init,16); { unsigned char *wp=_p+len; unsigned long *p=(unsigned long *)_p; UREG i=len; if ((i&63)!=56) { *wp++=0x80; i++; } while((i&63)!=56) { *wp++=0; i++; } { UINT16 v=__multiply_unsigned(len,8); *wp++=v; //len<<3; *wp++=v>>8; //len>>5; } *wp++=0; *wp++=0; *wp++=0; *wp++=0; *wp++=0; *wp++=0; i+=8; i>>=6; do { volatile struct { unsigned long a, b, c, d; }; UREG i; UREG n; UREG k; unsigned long tt; unsigned long const __flash *up; unsigned char const __flash *cp; back_memmove((void*)(&a+4),state+4,16); up=&table->g; i=0; do { #pragma diag_suppress=Pa082 if (!(i&32)) { if (!(i&16)) { tt=a+F1(b,c,d); } else { tt=a+F2(b,c,d); } } else { if (!(i&16)) { tt=a+F3(b,c,d); } else { tt=a+F4(b,c,d); } } #pragma diag_default=Pa082 tt+=*up++; cp=(unsigned char const __flash *)up; n=*cp++; k=*cp++; up=(unsigned long const __flash *)cp; tt+=p[k]; do { tt<<=1; if (SREG_Bit0) tt|=1; } while(--n); a=tt+b; tt=d; back_memmove((void*)(&a+4),(void*)(&a+3),12); a=tt; i++; } while(!(i&64)); sum(state,(unsigned long *)&a); p+=16; } while(--i); i=16; { char *out=out_; wp=(unsigned char*)state; do { UREG c; UREG c2; c2=c=*wp++; c>>=4; c+='0'; if (c>'9') c+='a'-10-'0'; *out++=c; c2&=0x0F; c2+='0'; if (c2>'9') c2+='a'-10-'0'; *out++=c2; } while(--i); } } }
Имейте в виду, процедура производит дополнение до целого блока прямо по месту входных данных, так что размер входного буфера должен быть кратен 64м байтам. Ну и выход у нее прямо в hex-виде, если нет необходимости - можно убрать.
Feb 4 2009, 15:10
Йа моск ;)
Из: Kharkiv-city
Цитата х51 - потому как проект уже сделан под такой проц Какое-то специализированное железо? Или банальный 8051? Потому что 32хбитная математика там еле шевелиться будет. Может еще не поздно вставить pin-to-pin совместимый AVR и пересобрать софт (если он, конечно, на Си). Цитата нужно туда еще вкрутить проверку по обоим хешам Ну можно аналогично исполнить и ША-адын. Только это еще медленнее и еще больше затрат по ОЗУ.
Feb 5 2009, 09:44
Йа моск ;)
Из: Kharkiv-city
Цитата камень у меня 89С5131 Эээ, это что за камень? Чей? Цитата или плюнуть и перелопатить проект под какой-нить ARM... Правильное решение. Но имейте в виду, ARM'ы все 3хвольтовые, т.е. возможно надо будет перелопачивать периферию. Может быть, проще AVR? Как-никак приличный выигрыш по производительности.
Feb 5 2009, 17:24
Пользователь №: 20 514
Цитата(Rst7 @ Feb 5 2009, 12:44)  Эээ, это что за камень? Чей? Это Atmel Цитата(Rst7 @ Feb 5 2009, 12:44)  Правильное решение. Но имейте в виду, ARM'ы все 3хвольтовые, т.е. возможно надо будет перелопачивать периферию. Может быть, проще AVR? Как-никак приличный выигрыш по производительности. Тык все равно плату переделывать... хотел обойтись частью существующего проекта, но уж если переделывать - так с музыкой  В старом проекте данные жрались/передавались по 32-разрядной шине, ARM как раз туда будет. Потом для согласования по разрядности ставил CPLD, тут ее не будет. А у тестируемого девайса используются 3в FLASH, пущенные через что-то типа 16211 для согласования с 5в интерфейсом. По идее, должно работать
