> Помогите запустить связку SAM7S64 FLASH, IAR 4.41 и JLink
rv3bj
сообщение Mar 13 2009, 14:29
Пользователь №: 12 265
Имею опыт общения с LPC. Хочется освоить SAM7S. Беру Basic проект из IAR. Проверяю две конфигурациию Первая все в RAM - работает отлично. При попытке запуска отладчика JLink получаю сообщение
IAR Embedded Workbench IDE
The debugging session could not be started.
Either the debugger initialization failed, or else the file "c:\EW_ARM441\ARM\config\flashloader\Atmel\FlashAT91SAM7Sx.d79" was corrupt or of an unsupported format.
There might be more information in the Debug Log window
OK
и далее Debug Log window:
Fri Mar 13 17:11:23 2009: Loaded macro file: c:\EW_ARM441\ARM\config\flashloader\Atmel\FlashAT91SAM7Sx.mac
Fri Mar 13 17:11:24 2009: DLL version: V4.02
Fri Mar 13 17:11:24 2009: Firmware: J-Link compiled Feb 20 2006 18:20:20 -- Update --
Fri Mar 13 17:11:24 2009: JTAG speed is initially set to: 32 kHz
Fri Mar 13 17:11:24 2009: TotalIRLen = 4, IRPrint = 0x01
Fri Mar 13 17:11:24 2009: Halting CPU core
Fri Mar 13 17:11:24 2009: Software reset was performed
Fri Mar 13 17:11:24 2009: Initial reset was performed
Fri Mar 13 17:11:24 2009: J-Link found 1 JTAG device. ARM core Id: 3F0F0F0F(ARM7)
Fri Mar 13 17:11:24 2009: Device at TAP0 selected
Fri Mar 13 17:11:24 2009: ---------------------------------------- FLASH Download V1.3
Fri Mar 13 17:11:24 2009: ---------------------------------------- 14/November/2005
Fri Mar 13 17:11:24 2009: ---------------------------------------- PLL Enable
Fri Mar 13 17:11:24 2009: -------------------------------Set CPSR ----------------------------------
Fri Mar 13 17:11:24 2009: CPSR 000000D3
Fri Mar 13 17:11:24 2009: ------------------------------- The Remap is done ----------------------------------------
Fri Mar 13 17:11:24 2009: ---------------------------------------- Chip ID 0x27090540
Fri Mar 13 17:11:24 2009: ---------------------------------------- Extention 0x00000000
Fri Mar 13 17:11:24 2009: ---------------------------------------- Flash Version 0x00000110
Fri Mar 13 17:11:24 2009: Error in c:\EW_ARM441\ARM\config\flashloader\Atmel\FlashAT91SAM7Sx.mac at line 34, col 5: Unknown or ambiguous symbol.
execUserSetup
Fri Mar 13 17:11:24 2009: Error while calling macro execUserFlashInit.
Подскажите где я неправ или пришлите работающий проект под SAM Flash.
RSS Текстовая версия Сейчас: 6th September 2025 - 22:18
Страница сгенерированна за 0.01326 секунд с 7
