> Помогите разобраться с CC1101, Не получается установить переменную длину пакета
Igor_O
сообщение Feb 25 2009, 11:37
Пользователь №: 41 641
RF_SETTINGS code rfSettings = {
0x06, // FSCTRL1 Frequency synthesizer control.
0x00, // FSCTRL0 Frequency synthesizer control.
0x10, // FREQ2 Frequency control word, high byte.
0x09, // FREQ1 Frequency control word, middle byte.
0x7B, // FREQ0 Frequency control word, low byte.
0xF5, // MDMCFG4 Modem configuration.
0x75, // MDMCFG3 Modem configuration.
0x13, // MDMCFG2 Modem configuration.
0x22, // MDMCFG1 Modem configuration.
0xE5, // MDMCFG0 Modem configuration.
0x00, // CHANNR Channel number.
0x14, // DEVIATN Modem deviation setting (when FSK modulation is enabled).
0x56, // FREND1 Front end RX configuration.
0x10, // FREND0 Front end TX configuration.
0x18, // MCSM0 Main Radio Control State Machine configuration.
0x16, // FOCCFG Frequency Offset Compensation Configuration.
0x6C, // BSCFG Bit synchronization Configuration.
0x03, // AGCCTRL2 AGC control.
0x40, // AGCCTRL1 AGC control.
0x91, // AGCCTRL0 AGC control.
0xE9, // FSCAL3 Frequency synthesizer calibration.
0x2A, // FSCAL2 Frequency synthesizer calibration.
0x00, // FSCAL1 Frequency synthesizer calibration.
0x1F, // FSCAL0 Frequency synthesizer calibration.
0x59, // FSTEST Frequency synthesizer calibration.
0x81, // TEST2 Various test settings.
0x35, // TEST1 Various test settings.
0x09, // TEST0 Various test settings.
0x07, // FIFOTHR RXFIFO and TXFIFO thresholds.
0x3F, // IOCFG2 GDO2 output pin configuration.
0x06, // IOCFG0D GDO0 output pin configuration. Refer to SmartRFR Studio User Manual for detailed pseudo register explanation.
0x0C, // PKTCTRL1 Packet automation control.
0x05, // PKTCTRL0 Packet automation control.
0x00, // ADDR Device address.
0xFF // PKTLEN Packet length.
Передаю 3 байта. Если ставлю PKTLEN 0х03 и PKTCTRL0 0х04 пакеты приходят .
В приемнике:
0. Инициализация и установка мощности
1. SFRX
2. Пауза 1 мс
3. Вкл. SRX
4. Читаю GDO0 пока не 1
5. Читаю GDO0 пока не 0
6. Проверяю, что RXBYTES не равен 0
7. 3 раза читаю RXFIFO
8. Вывод результата на RS232
9. SIDLE
переход на п.1
В передатчике:
1. SFTX
2. 3 раза данные в TXFIFO
3. STX
5. Читаю GDO0 пока не 0 - Окончание передачи
6. Пауза 1 сек (для вывода в приемнике данных на RS232 )
переход на п.1
Если ставлю в настройках PKTLEN 0хFF и PKTCTRL0 0х05 пакеты не приходят. В чем может быть проблема?
- Igor_O   Помогите разобраться с CC1101   Feb 25 2009, 11:37
- - rx3apf   Цитата(Igor_O @ Feb 25 2009, 14:37) Если ...   Feb 25 2009, 12:11
|- - Igor_O   Получилось! По даташиту думалось, что длину па...   Feb 25 2009, 13:48
|- - rx3apf   Цитата(Igor_O @ Feb 25 2009, 16:48) Получ...   Feb 25 2009, 14:44
- - Igor_O   Никак не получается запустить устойчивый прием/пер...   Mar 7 2009, 11:56
|- - Dog Pawlowa   Цитата(Igor_O @ Mar 7 2009, 15:56) Никак ...   Mar 7 2009, 17:33
- - bloodden   Код//38.4kbps nastroyki dlya 26.000 halSpiWriteR...   Mar 7 2009, 22:25
- - Igor_O   У Вас в коде кол-во принятых байт не анализируется...   Mar 8 2009, 14:33
|- - rx3apf   Я бы предложил для начала поиграться с фиксированн...   Mar 8 2009, 16:07
- - Igor_O   Разобрался с длиной пакета. Как оказалось все прос...   Mar 24 2009, 12:40
|- - rx3apf   Цитата(Igor_O @ Mar 24 2009, 15:40) Прием...   Mar 24 2009, 13:04
|- - _3m   Цитата(Igor_O @ Mar 24 2009, 15:40) ...че...   Mar 24 2009, 13:06
- - Igor_O   To rx3apf: Не совсем понял. Задержка после подачи ...   Mar 24 2009, 13:24
|- - rx3apf   Цитата(Igor_O @ Mar 24 2009, 16:24) To rx...   Mar 24 2009, 13:37
|- - rx3apf   Цитата(Igor_O @ Mar 24 2009, 16:24) To rx...   Mar 24 2009, 13:56
|- - Igor_O   Что не делаю - все равно через несколько часов зав...   Mar 26 2009, 10:04
- - Igor_O   У меня есть ожидание 0 на SDO. Но поставил несколь...   Mar 24 2009, 13:47
- - Igor_O   Пробую читать регистры СС после "отключения...   Mar 30 2009, 08:07
- - anaconda   Доброй ночи! У меня проблема таже. Есть две пл...   May 5 2009, 19:47
- - IDL   Всем доброго времени суток. Я тоже столкнулся с та...   Nov 23 2016, 06:08
- - IDL   Проблема решена. В датахе сказано, что GDO0 устана...   Nov 25 2016, 06:05
RSS Текстовая версия Сейчас: 31st July 2025 - 04:13
Страница сгенерированна за 0.01389 секунд с 7
