> проблемы с компиляцией Perl в buildroot
leonopulos
сообщение May 15 2009, 17:00
Пользователь №: 41 958
Здравствуйте.
Пытаюсь скомпилировать через buildroot ядро и rootfs.
Процесс затыкается на компиляции Perl-а:
Doing variable substitutions on .SH files...
Extracting cflags (with variable substitutions)
Extracting config.h (with variable substitutions)
Extracting makeaperl (with variable substitutions)
Extracting makedepend (with variable substitutions)
Extracting makedir (with variable substitutions)
Extracting Makefile (with variable substitutions)
Extracting myconfig (with variable substitutions)
Extracting pod/Makefile (with variable substitutions)
Extracting Policy.sh (with variable substitutions)
Extracting writemain (with variable substitutions)
Extracting x2p/cflags (with variable substitutions)
Extracting x2p/Makefile (with variable substitutions)
Now you need to generate make dependencies by running "make depend".
You might prefer to run it in background: "make depend > makedepend.out &"
It can take a while, so you might not want to run it right now.
Run make depend now? [y]
sh ./makedepend MAKE=make
make[1]: Entering directory `/home/leonopulos/buildroot/buildroot/build_arm/perl-5.8.8'
sh writemain lib/auto/DynaLoader/DynaLoader.a > perlmain.c
rm -f opmini.c
cp op.c opmini.c
echo av.c scope.c op.c doop.c doio.c dump.c hv.c mg.c reentr.c perl.c perly.c pp.c pp_hot.c pp_ctl.c pp_sys.c regcomp.c regexec.c utf8.c gv.c sv.c taint.c toke.c util.c deb.c run.c universal.c xsutils.c pad.c globals.c perlio.c perlapi.c numeric.c locale.c pp_pack.c pp_sort.c miniperlmain.c perlmain.c opmini.c | tr ' ' '\n' >.clist
make[1]: Leaving directory `/home/leonopulos/buildroot/buildroot/build_arm/perl-5.8.8'
./makedepend: 1: Syntax error: Unterminated quoted string
make: *** [depend] Ошибка 2
If you compile perl5 on a different machine or from a different object
directory, copy the Policy.sh file from this object directory to the
new one before you run Configure -- this will help you with most of
the policy defaults.
Подскажите, в чём причина?
RSS Текстовая версия Сейчас: 21st July 2025 - 07:39
Страница сгенерированна за 0.01342 секунд с 7
