EWARM patch release version 5.30.5 build 1361 1. Purpose This patch release contains the following additions and fixes to EWARM 5.30.5. Section placement could fail with an internal error [range allocation inconsistency] when the needed range for a place at command partially overlapped a place in command with a larger start address. [EW20817] When building initialization tables in link jobs with multiple zero or copy areas not inside blocks, an internal calculation error in the linker could cause section placement to fail with error Lp011. [EW20968,20986] Complex class inheritance structures with classes with methods taking more than two parameters could lead to broken thunks in Thumb mode. [EW21014] Member accesses to auto structs assigned with memcpy could in some cases be optimized incorrectly. [EW21020]
Не позволяют скачать. Может у кого есть?
