> позиционное и скоростное управление
Hellper
сообщение Oct 20 2009, 19:59
Из: Санкт-Петербург
Пользователь №: 29 745
Система управления стабилизацией скорости основана на использование ПИД регулятора:
#define SCALING_FACTOR  128
#include <limits.h>
typedef struct PID_DATA
    int16_t lastProcessValue;
    int32_t sumError;
    int16_t P_Factor;
    int16_t I_Factor;
    int16_t D_Factor;
    int16_t maxError;
    int32_t maxSumError;
} pidData_t;
#define MAX_INT         INT_MAX
#define MAX_LONG        LONG_MAX
#define MAX_I_TERM      ( MAX_LONG / 2 )
void pidInit( int16_t, int16_t, int16_t, struct PID_DATA * );
int16_t regulator( int16_t, int16_t, struct PID_DATA * );
void pidInit( int16_t p_factor, int16_t i_factor, int16_t d_factor, struct PID_DATA *pid )
    // Start values for PID controller
    pid->sumError = 0;
    pid->lastProcessValue = 0;
    // Tuning constants for PID loop
    pid->P_Factor = p_factor;
    pid->I_Factor = i_factor;
    pid->D_Factor = d_factor;
    // Limits to avoid overflow
    pid->maxError = MAX_INT / (pid->P_Factor + 1);
    pid->maxSumError = MAX_I_TERM / (pid->I_Factor + 1);
int16_t regulator( int16_t need, int16_t current, struct PID_DATA *pid )
    int32_t pwmOutput;
    int32_t temp;
    int16_t pTerm;
    int16_t iTerm;
    int16_t dTerm;
    int16_t error;
    error = need - current;
    if ( error > pid -> maxError )
        pTerm = MAX_INT;
    else
        if ( error < -pid -> maxError )
            pTerm = -MAX_INT;
        else
            pTerm = pid -> P_Factor * error;
    temp = pid -> sumError + error;
    if ( temp > pid -> maxSumError )
        iTerm = MAX_I_TERM;
        pid -> sumError = pid -> maxSumError;
    else
        if ( temp < -pid -> maxSumError )
            iTerm = -MAX_I_TERM;
            pid -> sumError = -pid -> maxSumError;
        else
            pid -> sumError = temp;
            iTerm = pid -> I_Factor * pid -> sumError;
    dTerm = pid -> D_Factor * ( pid -> lastProcessValue - current );
    pid -> lastProcessValue = current;
    pwmOutput = pTerm + iTerm - dTerm;
    pwmOutput >>= 7;
    if ( pwmOutput < MIN_RM_MOTOR_OUTPUT )
        pwmOutput = MIN_RM_MOTOR_OUTPUT;
    else
        if ( pwmOutput > MAX_RM_MOTOR_OUTPUT )
              pwmOutput = MAX_RM_MOTOR_OUTPUT;
    return (int16_t)pwmOutput;
возвращаемое значение используется для коррекции мощности двигателя.
хочется сделать изменение скорости в зависимости от пройденного пути, те задается закон( трапеция, парабола, треугольник и тп) и в течение перемещения производиться коррекция необходимой скорости.
как наиболее эффективно и красиво реализовать ?
есть вариант разбивать перемещение на элементарные отрезки и высчитывать заранее точки, в которых изменять скорость, основываясь на показаниях датчиков обратной связи, и устанавливать требуемые значения для скоростного ПИД регулятора. Функции, по которым необходимо изменять закон движения, ввести как таблицы и масштабировать с использованием коэффициентов. Устремляя значения длин отрезков к малой величине добиться наибольшего соответствия действительных значений.
есть другой вариант ? проблемы малых перемещений ?
ПС: все происходит в микроконтроллере(Silabs)
Сообщение отредактировал Hellper - Oct 20 2009, 20:03
RSS Текстовая версия Сейчас: 4th August 2025 - 20:45
Страница сгенерированна за 0.01353 секунд с 7
