> Сборка arm-elf- toolchain, Не удается собрать newlib
Bulya
сообщение Oct 28 2009, 12:37
Из: Харьков
Пользователь №: 40 874
Здравствуйте.
Собираю
binutils-2.20, gcc-4.3.4, newlib-1.17.0
с ключами
--target=arm-elf --enable-interwork --enable-multilib --enable-languages="c,c++" --with-gnu-as --with-gnu-ld
--disable-shared --disable-nls --disable-newlib-supplied-syscalls --disable-newlib-io-float
компиляция newlib прекращается с ошибками в linux-syscalls0.S
.../newlib-1.17.0/libgloss/arm/linux-syscalls0.S:37: Error: missing expression -- `swi'
.../newlib-1.17.0/libgloss/arm/linux-syscalls0.S:102: Error: missing expression -- `swi'
linux-syscalls0.S:
CODE
#include "linux-syscall.h"
#if __thumb__
# define FUNC(name) .type name, %function; .thumb_func; name:
# define SET .thumb_set
#else
# define FUNC(name) .type name, %function; name:
# define SET .set
#endif
#define GLOBAL(name) .global name; FUNC(name)
#define SIZE(name) .size name, .-name
#if __thumb__
# define SYSCALL0(name) \
GLOBAL(_ ## name); \
mov r12, r7; \
mov r7, #SYS_ ## name; \
swi; \
mov r7, r12; \
b _set_errno; \
SIZE(_ ## name)
/* static int _syscall3(int a, int b, int c, int number); */
FUNC(_syscall3)
push { r7 }
mov r7, r3
swi
pop { r7 }
b _set_errno
SIZE(_syscall3)
# define SYSCALL3(name) \
mov r3, #SYS_ ## name; \
b _syscall3; \
SIZE(_ ## name)
# define SYSCALL6(name) \
push { r4 - r5, r7 }; \
ldr r4, [sp, #12]; \
ldr r5, [sp, #16]; \
swi; \
pop { r4 - r5, r7 }; \
b _set_errno; \
SIZE(_ ## name)
# define SYSCALL4(name) SYSCALL6(name)
#else /* __thumb__ */
# define SYSCALL4(name) \
swi #SYS_ ## name; \
b _set_errno; \
SIZE(_ ## name)
push { r4 - r5 }; \
ldr r4, [sp, #8]; \
ldr r5, [sp, #12]; \
pop { r4 - r5 }; \
b _set_errno; \
SIZE(_ ## name)
#define SYSCALL0(name) SYSCALL3(name)
#define SYSCALL3(name) SYSCALL4(name)
#endif /* __thumb__ */
#define SYSCALL1(name) SYSCALL3(name)
#define SYSCALL2(name) SYSCALL3(name)
#define SYSCALL5(name) SYSCALL6(name)
SYSCALL1(alarm)
SYSCALL1(brk)
SYSCALL1(chdir)
SYSCALL2(chmod)
SYSCALL3(chown)
SYSCALL1(close)
SYSCALL1(dup)
SYSCALL2(dup2)
SYSCALL3(execve)
SYSCALL1(exit)
SYSCALL3(fcntl)
SYSCALL2(fstat)
SYSCALL2(ftruncate)
SYSCALL3(getdents)
SYSCALL0(getegid)
SYSCALL0(geteuid)
SYSCALL0(getgid)
SYSCALL2(getgroups)
SYSCALL1(getpgid)
SYSCALL0(getpgrp)
SYSCALL0(getpid)
SYSCALL0(getuid)
SYSCALL2(gettimeofday)
SYSCALL3(ioctl)
SYSCALL2(kill)
SYSCALL3(lchown)
SYSCALL2(link)
SYSCALL3(lseek)
SYSCALL2(lstat)
SYSCALL2(mkdir)
SYSCALL3(mknod)
SYSCALL2(nanosleep)
SYSCALL3(open)
SYSCALL0(pause)
SYSCALL1(pipe)
SYSCALL3(read)
SYSCALL3(readlink)
SYSCALL4(reboot)
SYSCALL1(rmdir)
SYSCALL5(select)
SYSCALL2(setpgid)
SYSCALL1(setgid)
SYSCALL0(setsid)
SYSCALL1(setuid)
SYSCALL3(sigprocmask)
SYSCALL2(socketcall)
SYSCALL2(stat)
SYSCALL1(stime)
SYSCALL2(symlink)
SYSCALL1(sync)
SYSCALL1(sysinfo)
SYSCALL1(times)
SYSCALL2(truncate)
SYSCALL1(umask)
SYSCALL1(uname)
SYSCALL1(unlink)
SYSCALL2(utime)
SYSCALL0(vfork)
SYSCALL4(wait4)
SYSCALL3(write)
т.е. передача номера прерывания через регистр r7 (в __thumb__), а не в инструкции swi вызывает ошибку.
Что характерно, системные вызовы linux мне вообще не нужны для arm-elf.
Подскажите, пожалуйста, решение проблемы (правильную конфигурацию при сборке или правильный синтаксис системных вызовов).
RSS Текстовая версия Сейчас: 27th July 2025 - 06:51
Страница сгенерированна за 0.01489 секунд с 7
