> nios2-flash-programmer можно пользовать?, на двух платах с разными флашками фигня какая-то
yes
сообщение Dec 17 2009, 16:09
Пользователь №: 1 640
вроде бы удобный тул, чтобы мануал на флашку не читать, но прошить не могу.
вот что-то такое происходит
[NiosII EDS]$ nios2-flash-programmer --base=0 --debug --erase-all
Using cable "USB-Blaster [USB-1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Found CFI table in 16 bit mode
Raw CFI query table read from device:
   0: 20 00 BB 88 00 00 FF FF  FF FF FF FF FF FF FF FF   ...............
  10: FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  ................
  20: 51 00 52 00 59 00 03 00  00 00 35 00 00 00 00 00  Q.R.Y.....5.....
  30: 00 00 00 00 00 00 27 00  36 00 B4 00 C6 00 04 00  ......'.6.......
  40: 04 00 0A 00 00 00 05 00  05 00 03 00 00 00 16 00  ................
  10: 51 52 59 03 00 35 00 00  00 00 00 27 36 B4 C6 04  QRY..5.....'6...
  20: 04 0A 00 05 05 03 00 16  01 00 03 00 02 07 00 20  ...............
  30: 00 3E 00 00 01                                    .>...
CFI extended table read from device:
   0: 50 52 49 31 30 66 00 00  00 01 03 00 30 C0 01 80  PRI10f......0...
  10: 00 03 03 FF FF FF FF FF  FF FF FF FF FF FF FF FF  ................
Read autoselect code 0020-88BB (in 16 bit mode)
No CFI override data for [FLASH-0020-88BB]
Target timeout loop runs 1504100 times/s
Timeout set to 771 loops
Device size is 4MByte
Erase regions are:
  offset        0:   8 x 8K
  offset    10000:  63 x 64K
Device supports Intel style programming algorithm
Multi-byte programming with 8 byte buffer
Sector erase timeout is 8s
Word program timeout is 512us
Buffer program timeout is 512us
              : Checksumming existing contents
00000000      : Already erased
00002000      : Needs erasing
00004000      : Needs erasing
00006000      : Needs erasing
00008000      : Needs erasing
0000A000      : Needs erasing
0000C000      : Needs erasing
0000E000      : Needs erasing
00010000      : Needs erasing
00020000      : Needs erasing
00030000      : Already erased
Erase failed at offset 2000
Leaving target processor paused
в 0 сектор пишет правильно
ну и во втором случае валится (я до опции --debug тогда не добрался, но тоже не сразу валится)
RSS Текстовая версия Сейчас: 6th September 2025 - 08:24
Страница сгенерированна за 0.04329 секунд с 7
