> EPSC
artem79
сообщение Jan 15 2010, 10:06
Из: Казань
Пользователь №: 24 091
Добрый день.
Сталкнулся с проблемой загрузки программы во флаш.
Имеется след. система. EP2C5 - SRAM - EPCS. в качестве памяти программ используется SRAM. В отладчике все работает.
Пытаюсь загрузить во флэш через flash-programmer выдает следующее:
CODE
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd H:/Nios_60/software/count_binary_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="H:/Nios_60/nios_uart.sof" --outp
ut="nios_uart.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=nios_
uart.opt H:/Nios_60/nios_uart.sof nios_uart.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 73 megabytes
Info: Processing ended: Fri Jan 15 12:40:07 2010
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:05
Info: Command: quartus_cpf --no_banner --convert nios_uart.pof nios_uart.rpd
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Fri Jan 15 12:40:16 2010
Info: Elapsed time: 00:00:08
Info: Total CPU time (on all processors): 00:00:07
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00201000 --sidp=0x0
0202068 --id=477433320 --timestamp=1263547010 --instance=0 "nios_uart.flash"
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00202068: verified
No EPCS layout data - looking for section [EPCS-EF3013]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="nios_uart.flash" --input="count_
binary_0.elf" --output="epcs_flash_controller_0.flash"
# Programming flash with the project
0202068 --id=477433320 --timestamp=1263547010 --instance=0 "epcs_flash_controlle
r_0.flash"
Такое ощущение что флэшку не видит. Может кто сталкивался????? Работаю в QuartusII 9.0.
Сообщение отредактировал Omen_13 - Jan 19 2010, 20:31
Причина редактирования: Оформление
- artem79   EPSC   Jan 15 2010, 10:06
- - vadimuzzz   а систему в SOPC-билдере не пересобирали? обычно т...   Jan 15 2010, 14:41
- - artem79   Перепробывал разные варианты. пересобирал и т.д. У...   Jan 26 2010, 06:59
|- - vadimuzzz   а флеш точно EPCS или аналог? точное название микр...   Jan 26 2010, 07:15
|- - Stewart Little   Цитата(artem79 @ Jan 26 2010, 09:59) Пере...   Jan 26 2010, 07:51
|- - artem79   Цитата(Stewart Little @ Jan 26 2010, 10:5...   Jan 26 2010, 08:33
|- - Stewart Little   Цитата(artem79 @ Jan 26 2010, 11:20) Проб...   Jan 26 2010, 08:38
|- - vadimuzzz   Цитата(artem79 @ Jan 26 2010, 14:33) EPCS...   Jan 26 2010, 08:44
|- - Stewart Little   Цитата(vadimuzzz @ Jan 26 2010, 11:44) [E...   Jan 26 2010, 10:51
|- - vadimuzzz   Цитата(Stewart Little @ Jan 26 2010, 16:5...   Jan 26 2010, 10:59
|- - artem79   Цитата(vadimuzzz @ Jan 26 2010, 13:59) ой...   Jan 26 2010, 11:19
|- - Stewart Little   Цитата(artem79 @ Jan 26 2010, 14:19) нет....   Jan 26 2010, 11:25
- - artem79   После сохдания файла ниос вроде начал программиров...   Jan 26 2010, 09:23
|- - Stewart Little   Цитата(artem79 @ Jan 26 2010, 12:23) Посл...   Jan 26 2010, 09:38
- - vadimuzzz   по логам - все нормально, верификация проходит (ст...   Jan 26 2010, 09:38
|- - artem79   Цитата(vadimuzzz @ Jan 26 2010, 12:38) по...   Jan 26 2010, 09:55
|- - vadimuzzz   Цитата(artem79 @ Jan 26 2010, 15:55) Полу...   Jan 26 2010, 10:03
|- - artem79   Цитата(vadimuzzz @ Jan 26 2010, 13:03) ве...   Jan 26 2010, 10:18
- - vadimuzzz   непонятно.. надо как-нибудь дамп sram сделать посл...   Jan 26 2010, 10:36
|- - artem79   Цитата(vadimuzzz @ Jan 26 2010, 13:36) не...   Jan 26 2010, 10:39
|- - vadimuzzz   Цитата(artem79 @ Jan 26 2010, 16:39) внеш...   Jan 26 2010, 10:46
- - artem79   Все заработало! Последняя причина была в подкл...   Jan 26 2010, 11:51
- - Reanimator++   Осваиваю Flash Programmer. Собственно сначала натк...   Apr 13 2011, 10:46
|- - Stewart Little   Цитата(Reanimator++ @ Apr 13 2011, ...   Apr 13 2011, 13:40
- - vadimuzzz   1. давайте выхлоп флеш-программера с ключом -debug...   Apr 13 2011, 12:57
- - Reanimator++   9.1 SP2 1. Выхлоп Flash Programmer-а, добавил еще...   Apr 13 2011, 13:21
- - vadimuzzz   так, логи чистые. дамп можно слить так: Кодnios2-f...   Apr 13 2011, 13:37
- - Reanimator++   Ок, попробуем дампы сравнить с помощью Flash Progr...   Apr 13 2011, 19:18
- - Reanimator++   Сравнил дампы флеши после работы Quartus II Progra...   Apr 14 2011, 07:16
- - vadimuzzz   что-то это мне напоминает: http://electronix.ru/fo...   Apr 14 2011, 07:42
- - Reanimator++   Ух, сильно. Пошел коллекционировать квартусы, буду...   Apr 14 2011, 08:06
- - Reanimator++   Ура, получилось! Спасибо за помощь в борьбе с ...   Apr 14 2011, 12:04
- - vadimuzzz   я бы гуй пока не трогал, разберитесь в консоли сна...   Apr 14 2011, 14:33
- - Reanimator++   С консолью разобрался, благо утилиты несложные. На...   Apr 14 2011, 15:49
|- - vadimuzzz   Цитата(Reanimator++ @ Apr 14 2011, ...   Apr 14 2011, 22:55
- - gosu-art   Добрый день! Простите, если немножечко не в те...   May 12 2011, 09:28
|- - vadimuzzz   Цитата(gosu-art @ May 12 2011, 16:28...   May 12 2011, 09:59
|- - gosu-art   Цитата(vadimuzzz @ May 12 2011, 13:59) см...   May 12 2011, 10:10
|- - vadimuzzz   Цитата(gosu-art @ May 12 2011, 17:10...   May 12 2011, 11:13
- - Reanimator++   Кажется понял в чем вопрос. В epcs содержится .rbf...   May 12 2011, 20:41
- - vadimuzzz   Цитата(Reanimator++ @ May 13 2011, ...   May 12 2011, 23:06
RSS Текстовая версия Сейчас: 21st July 2025 - 22:32
Страница сгенерированна за 0.01375 секунд с 7
