> ENI OEM-28B/02 RF Generator, I have a question?
steve robinson
сообщение Apr 18 2010, 11:43
Группа: Eng
Пользователь №: 24 671
ENI OEM-28B/02 uses 208/220/230/240, 3 phase input without neutral (delta connection) but inside the operating manual on page 2-5 under "power requirements" section there is a table showing allowed input voltages. Along with the above voltages in this table 380/400/415 are also included. My question is can I connect my generator to 3 phase 380 volts using setup indicated in this table?
If so in this case there should be an extra N (neutral) contact too (star connection). This means I should connect terminal 13 inside the generator (TB1 circuit) using an extra cable to the neutral of the supply power system. Am I right?
RSS Текстовая версия Сейчас: 6th September 2025 - 11:10
Страница сгенерированна за 0.14965 секунд с 7
