2 страниц V  < 1 2
> boot LPC2478 STK from external flash
andybeg
сообщение May 28 2010, 12:53
Пользователь №: 22 954
в lowlevel_init.c была найдена закомментированная функция, но её раскоментирование и вставка в инициалзацию схемы не решило проблемы sad.gif запись в NOR не производится
** Function name:        ConfigureEMC
** Descriptions:        Configure EMC for external SDRAM, NAND and NOR FLASH
** parameters:            None
** Returned value:    None
void
ConfigureEMC(void)
    volatile unsigned int i, dummy = dummy;
//  SCS     &= ~0x00000002;
//  SCS     |= 0x00000002;
  EMC_CTRL = 0x00000001;
    PCONP   |= 0x00000800;        /* Turn on EMC PCLK */
  PINSEL4  = 0x50000000;
#ifdef USE_32_BIT_DATABUS
  PINSEL5  = 0x55010115;
  PINSEL7  = 0x55555555;
#else
  PINSEL5  = 0x05050555;
#endif
  PINSEL6  = 0x55555555;
  PINSEL8  = 0x55555555;
  PINSEL9  = 0x50555555;
  //all registers...
  EMC_DYN_RP     = 1;   //>20ns = 2 clk
  EMC_DYN_RAS    = 3;   //>45ns = 3 clk
  EMC_DYN_SREX   = 5;   //>80-100ns = 6 clk
  EMC_DYN_APR    = 1;   //
  EMC_DYN_DAL    = 5;   //2 clk
  EMC_DYN_WR     = 1;   //2 clk
  EMC_DYN_RC     = 5;   //>65ns = 4 clk
  EMC_DYN_RFC    = 5;   //>80-100ns = 6 clk
  EMC_DYN_XSR    = 5;   //>80-100ns = 6 clk
  EMC_DYN_RRD    = 1;   //>15ns = 1-2 clk
  EMC_DYN_MRD    = 1;   //2 clk
  EMC_DYN_RD_CFG = 1;   //or 1,2,3
  EMC_DYN_RASCAS0 = 0x00000202;
  EMC_DYN_CFG0 = 0x00005480;
#else
  EMC_DYN_RP     = 2;   //>20ns = 2 clk
  EMC_DYN_SREX   = 7;   //>80-100ns = 6 clk
  EMC_DYN_APR    = 2;   //
  EMC_DYN_XSR    = 7;   //>80-100ns = 6 clk
  EMC_DYN_MRD    = 2;   //2 clk
  EMC_DYN_RASCAS0 = 0x00000303;
  EMC_DYN_CFG0 = 0x00000680;
#endif
  //wait 100mS
  delayMs(100);
  //Send command: NOP
  EMC_DYN_CTRL = 0x00000183;
  //wait 200mS
  delayMs(200);
  //Send command: PRECHARGE-ALL, shortest possible refresh period
  EMC_DYN_CTRL = 0x00000103;
  EMC_DYN_RFSH = 0x00000002;
  //wait 128 ABH clock cycles
  for(i=0; i<0x40; i++)
    asm volatile(" nop");
  //Set correct refresh period
  EMC_DYN_RFSH = 28;
  //Send command: MODE
  EMC_DYN_CTRL = 0x00000083;
  //Set mode register in SDRAM
  dummy = *((volatile unsigned int*)(SDRAM_BASE_ADDR | (0x22 << 11)));
#else
  dummy = *((volatile unsigned int*)(SDRAM_BASE_ADDR | (0x33 << 12)));
#endif
  //Send command: NORMAL
  EMC_DYN_CTRL = 0x00000000;
  //Enable buffer
  EMC_DYN_CFG0 |= 0x00080000;
  //initial system delay
  delayMs(1);
  EMC_STA_WAITWEN0  = 0x2;
  EMC_STA_WAITOEN0  = 0x2;
  EMC_STA_WAITRD0   = 0x1f;
  EMC_STA_WAITPAGE0 = 0x1f;
  EMC_STA_WAITWR0   = 0x1f;
  EMC_STA_WAITTURN0 = 0xf;
  EMC_STA_CFG0      = 0x00000081;
  EMC_STA_WAITWEN1  = 0x2;
  EMC_STA_WAITOEN1  = 0x2;
  EMC_STA_WAITRD1   = 0x8;
  EMC_STA_WAITPAGE1 = 0x1f;
  EMC_STA_WAITWR1   = 0x8;
  EMC_STA_WAITTURN1 = 0xf;
  EMC_STA_CFG1      = 0x00000080;
lpc-2478-stk # fatload usb 0 0x80800000 romfs_5.img
reading romfs_5.img
581632 bytes read
lpc-2478-stk # md 0x80800000
80800000: ffffffff ffffffff ffffffff ffffffff    ................
80800010: ffffffff ffffffff ffffffff ffffffff    ................
80800020: ffffffff ffffffff ffffffff ffffffff    ................
80800030: ffffffff ffffffff ffffffff ffffffff    ................
80800040: ffffffff ffffffff ffffffff ffffffff    ................
80800050: ffffffff ffffffff ffffffff ffffffff    ................
80800060: ffffffff ffffffff ffffffff ffffffff    ................
80800070: ffffffff ffffffff ffffffff ffffffff    ................
80800080: ffffffff ffffffff ffffffff ffffffff    ................
80800090: ffffffff ffffffff ffffffff ffffffff    ................
808000a0: ffffffff ffffffff ffffffff ffffffff    ................
808000b0: ffffffff ffffffff ffffffff ffffffff    ................
808000c0: ffffffff ffffffff ffffffff ffffffff    ................
808000d0: ffffffff ffffffff ffffffff ffffffff    ................
808000e0: ffffffff ffffffff ffffffff ffffffff    ................
808000f0: ffffffff ffffffff ffffffff ffffffff    ................
2 страниц V  < 1 2
RSS Текстовая версия Сейчас: 30th July 2025 - 12:08
Страница сгенерированна за 0.01377 секунд с 7
