Здравствуйте уважаемые.
Имеется старый GPS модуль (черная коробочка 5x8x15) к нему в подключается специальный переходник RS232-RS232.
Подключаю это "черное чудо" к com-порту компьютера. Включаю на компьютере программу COMPump выставляю параметры управления потоком в нет, включаю монитор порта. Наблюдаю вот такую картину
0,IRP_MJ_CREATE,DOWN,TRUE,0x0,63 00 6D 00 70 00 6D 00 2E 00 65 00 78 00 65 00 00 00 ,c.m.p.m...e.x.e...,
1,IRP_MJ_CREATE,UP,FALSE,0x0,,,
2,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size),DOWN,TRUE,0x0,00 20 00 00 A0 0F 00 00 ,. .. ...,
3,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size),UP,FALSE,0x0,,,
4,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate),DOWN,FALSE,0x0,,,
5,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate),UP,TRUE,0x0,80 25 00 00 ,%..,
6,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control),DOWN,FALSE,0x0,,,
7,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control),UP,TRUE,0x0,00 00 08 ,...,
8,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS: Retrieve special characters),DOWN,FALSE,0x0,,,
9,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS: Retrieve special characters),UP,TRUE,0x0,00 00 00 00 11 13 ,......,
10,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information),DOWN,FALSE,0x0,,,
11,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 10 00 00 00 04 00 00 ,................,
12,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate),DOWN,FALSE,0x0,,,
13,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate),UP,TRUE,0x0,80 25 00 00 ,%..,
14,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control),DOWN,FALSE,0x0,,,
15,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control),UP,TRUE,0x0,00 00 08 ,...,
16,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS: Retrieve special characters),DOWN,FALSE,0x0,,,
17,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS: Retrieve special characters),UP,TRUE,0x0,00 00 00 00 11 13 ,......,
18,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information),DOWN,FALSE,0x0,,,
19,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 10 00 00 00 04 00 00 ,................,
20,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate),DOWN,TRUE,0x0,80 25 00 00 ,%..,
21,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate),UP,FALSE,0x0,,,
22,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),DOWN,FALSE,0x0,,,
23,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),UP,FALSE,0x0,,,
24,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),DOWN,FALSE,0x0,,,
25,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),UP,FALSE,0x0,,,
26,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL: Set line control),DOWN,TRUE,0x0,00 00 08 ,...,
27,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL: Set line control),UP,FALSE,0x0,,,
28,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS: Set special characters),DOWN,TRUE,0x0,00 00 00 00 11 13 ,......,
29,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS: Set special characters),UP,FALSE,0x0,,,
30,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW: Set handshake information),DOWN,TRUE,0x0,00 00 00 00 00 00 00 00 00 10 00 00 00 04 00 00 ,................,
31,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW: Set handshake information),UP,FALSE,0x0,,,
32,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_TIMEOUTS: Retrieve timeouts),DOWN,FALSE,0x0,,,
33,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_TIMEOUTS: Retrieve timeouts),UP,TRUE,0x0,FF FF FF FF 00 00 00 00 00 00 00 00 0A 00 00 00 E8 03 00 00 ,ÿÿÿÿ............è...,
34,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS: Set timeouts),DOWN,TRUE,0x0,FF FF FF FF 00 00 00 00 00 00 00 00 0A 00 00 00 E8 03 00 00 ,ÿÿÿÿ............è...,
35,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS: Set timeouts),UP,FALSE,0x0,,,
36,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),DOWN,FALSE,0x0,,,
37,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),UP,FALSE,0x0,,,
38,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),DOWN,FALSE,0x0,,,
39,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),UP,FALSE,0x0,,,
40,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,0F 00 00 00 ,....,
41,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
42,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,08 00 00 00 ,....,
43,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
44,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask),DOWN,TRUE,0x0,FD 01 00 00 ,ý...,
45,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask),UP,FALSE,0x0,,,
46,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),DOWN,FALSE,0x0,,,
47,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),UP,TRUE,0x0,00 00 00 00 ,....,
48,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
в итоге никаких данных не приходит, я так понимаю что он чего-то ждет, но чего?
Включаю режим RTS\CTS либо DTR и о чудо все работает.
Пробую эту "черное чудо" подключить к DSP (BF533) используя example из Visual DSP++v5.0( driver UART), реакции тоже никакой
