Во время синтеза проекта в среде EDK мэппер выкинул следующие ошибки.
# Starting program map
# map -o system_map.ncd -pr b -ol high -timing system.ngd system.pcf
Release 10.1 - Map K.39 (nt)
Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved.
PMSPEC -- Overriding Xilinx file <c:/Xilinx/10.1/ISE/virtex4/data/virtex4.acd>
with local file <c:/Xilinx/10.1/ISE/virtex4/data/virtex4.acd>
Using target part "4vfx20ff672-11".
Mapping design into LUTs...
ERROR:MapLib:979 - LUT3 symbol "ip_header_0/ip_header_0/RFF_DATA_OUT<20>1"
(output signal=IP_TO_R_RFF_DATA<20>) has input signal
"ip_header_0/ip_header_0/bytes4_cnt<4>" which will be trimmed. See Section 5
of the Map Report File for details about why the input signal will become
undriven.
"ip_header_0/ip_header_0/remove4bytes" which will be trimmed. See Section 5
undriven.
ERROR:MapLib:979 - LUT4 symbol "ip_header_0/ip_header_0/write_packet1" (output
signal=IP_TO_R_WR_REQ) has input signal
"ip_header_0/ip_header_0/bytes4_cnt<4>1" which will be trimmed. See Section 5
undriven.
ERROR:MapLib:978 - LUT3 symbol "ip_header_0/ip_header_0/RFF_DATA_OUT<20>1"
(output signal=IP_TO_R_RFF_DATA<20>) has an equation that uses input pin I0,
which no longer has a connected signal. Please ensure that all the pins used
in the equation for this LUT have signals that are not trimmed (see Section 5
of the Map Report File for details on which signals were trimmed).
(output signal=IP_TO_R_RFF_DATA<20>) has an equation that uses input pin I1,
ERROR:MapLib:978 - LUT4 symbol "ip_header_0/ip_header_0/write_packet1" (output
signal=IP_TO_R_WR_REQ) has an equation that uses input pin I3, which no
longer has a connected signal. Please ensure that all the pins used in the
equation for this LUT have signals that are not trimmed (see Section 5 of the
Error found in mapping process, exiting...
Errors found during the mapping phase. Please see map report file for more
details. Output files will not be written.
Design Summary
Number of errors : 6
Number of warnings : 2
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
В чем причина?
Нелегко оказаться на верном пути, но куда труднее его пройти.
(с) Уилл Роджерс
