> атрибут _IRQ
sergey sva
сообщение Mar 22 2011, 08:24
Из: Самарская область Сызрань
Пользователь №: 27 923
Скачал пример посмотрел, возник вопрос обработчик прерывания написан в стартапе, и в то же время возле функции установлен атрибут _IRQ который указывает компилятору что это функия прерывания и нужно добавить обработчик, или ошибаюсь?
@*   startup.s: startup file for NXP LPC230x Family Microprocessors
@*   Copyright(C) 2006, NXP Semiconductor
@*   All rights reserved.
@*   History
@*   2006.09.01  ver 1.00    Prelimnary version, first Release
@ modified by Martin Thomas:
@  - changed comment char to @ for GNU assembler (arm-elf-as)
@    "The line comment character is [...] ▒@▓ on the ARM [...]"
@    (GNU-as manual from binutils V 2.17)
@  - ported RV-ASM to GNU-ASM (sections, import/export, equ,
@    :OR:, Labels etc.)
@  - added .data and .bss inits
@  - call main instead of __main (since there is no "RV runtime-init")
@  - call main with bx so it can be thumb-code
@  - added IRQ-Wrapper for easier porting of ISR-codes for IAR, RV etc.
@  - TargetResetInit can be a thumb-function (using BX instead of BL)
@  - moved TargetResetInit call before the stack-inits and use
@    a temporary stack-pointer
@  - route swi-exception to handler implemented in swi_handler.h
@@    PRESERVE8
@ *  The STARTUP.S code is executed after CPU Reset. This file may be
@ *  translated with the following SET symbols. In uVision these SET
@ *  symbols are entered under Options - ASM - Define.
@ *  REMAP: when set the startup code initializes the register MEMMAP
@ *  which overwrites the settings of the CPU configuration pins. The
@ *  startup and interrupt vectors are remapped from:
@ *     0x00000000  default setting (not remapped)
@ *     0x40000000  when RAM_MODE is used
@ *  RAM_MODE: when set the device is configured for code execution
@ *  from on-chip RAM starting at address 0x40000000.
@ Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
.equ Mode_USR,            0x10
.equ Mode_FIQ,            0x11
.equ Mode_IRQ,            0x12
.equ Mode_SVC,            0x13
.equ Mode_ABT,            0x17
.equ Mode_UND,            0x1B
.equ Mode_SYS,            0x1F
.equ I_Bit,               0x80            @ when I bit is set, IRQ is disabled
.equ F_Bit,               0x40            @ when F bit is set, FIQ is disabled
@// <h> Stack Configuration (Stack Sizes in Bytes)
@//   <o0> Undefined Mode      <0x0-0xFFFFFFFF:8>
@//   <o1> Supervisor Mode     <0x0-0xFFFFFFFF:8>
@//   <o2> Abort Mode          <0x0-0xFFFFFFFF:8>
@//   <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:8>
@//   <o4> Interrupt Mode      <0x0-0xFFFFFFFF:8>
@//   <o5> User/System Mode    <0x0-0xFFFFFFFF:8>
@// </h>
.equ UND_Stack_Size,     0x00000000
.equ SVC_Stack_Size,     0x00000100
.equ ABT_Stack_Size,     0x00000000
.equ FIQ_Stack_Size,     0x00000000
.equ IRQ_Stack_Size,     0x00000100
.equ USR_Stack_Size,     0x00000200
.equ Stack_Size,        (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \
                         FIQ_Stack_Size + IRQ_Stack_Size + USR_Stack_Size)
@@                AREA    STACK, NOINIT, READWRITE, ALIGN=3
@@Stack_Mem       SPACE   Stack_Size
@@Stack_Top       EQU     Stack_Mem + Stack_Size
.arm
.section .STACK, "w"
.align 3
Stack_Mem:
.space Stack_Size
.equ Stack_Top, Stack_Mem + Stack_Size
@// <h> Heap Configuration
@//   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF>
@// </h>
@@Heap_Size       EQU     0x00000000
@@                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
@@Heap_Mem        SPACE   Heap_Size
.equ Heap_Size,   0x00000000
.section .HEAP, "w"
.align 3
HeapMem:
.if (Heap_Size>0)
.space Heap_Size
.endif
@ Area Definition and Entry Point
@  Startup Code must be linked first at Address at which it expects to run.
@@                AREA    RESET, CODE, READONLY
@@                ARM
.section .RESET, "ax"
.arm
@ Exception Vectors
@  Mapped to Address 0.
@  Absolute addressing mode must be used.
@  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors:        LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            @ Reserved Vector
                LDR     PC, IRQ_Addr
@@                LDR     PC, [PC, #-0x0120]     @ Vector from VicVectAddr
                LDR     PC, FIQ_Addr
Reset_Addr:      .word     Reset_Handler
Undef_Addr:      .word     Undef_Handler
SWI_Addr:        .word     SWI_Handler
PAbt_Addr:       .word     PAbt_Handler
DAbt_Addr:       .word     DAbt_Handler
                 .word     0xB9206E28             @ Reserved Address
IRQ_Addr:        .word     IRQ_Handler
FIQ_Addr:        .word     FIQ_Handler
Undef_Handler:   B       Undef_Handler
@@ SWI_Handler:     B       SWI_Handler
.extern SoftwareInterrupt
SWI_Handler:     B       SoftwareInterrupt  @ see swi_handler.S
PAbt_Handler:    B       PAbt_Handler
DAbt_Handler:    B       DAbt_Handler
@@ handled thru assembler wrapper (see below)
@@ IRQ_Handler:    B       IRQ_Handler
FIQ_Handler:     B       FIQ_Handler
@ Reset Handler
@                EXPORT  Reset_Handler
.global Reset_handler
Reset_Handler:
@  Call low-level init C-function
@                IMPORT TargetResetInit
@                BL   TargetResetInit
                 .extern TargetResetInit
                 ldr     SP, =Stack_Top    @ temporary stack at Stack_Top
                 LDR R0, =TargetResetInit
                 MOV LR, PC
                 BX R0
@  Setup Stack for each mode
                LDR     R0, =Stack_Top
@  Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_UND | I_Bit | F_Bit
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
@  Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_ABT | I_Bit | F_Bit
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
@  Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_FIQ | I_Bit | F_Bit
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
@  Enter IRQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_IRQ | I_Bit | F_Bit
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
@  Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC | I_Bit | F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
@  Enter User Mode and set its Stack Pointer
@  mt:          MSR     CPSR_c, #Mode_USR
                MSR     CPSR_c, #Mode_USR | I_Bit
                MOV     SP, R0
                SUB     SL, SP, #USR_Stack_Size
@  mt: Start application in USR-mode with IRQ-exceptions disabled.
@  They can be enabled at runtime thru IntEnable in swi.h/swi_handler.S.
@  Relocate .data section (Copy from ROM to RAM)
                LDR     R1, =_etext
                LDR     R2, =_data
                LDR     R3, =_edata
                CMP     R2, R3
                BEQ     DataIsEmpty
LoopRel:        CMP     R2, R3
                LDRLO   R0, [R1], #4
                STRLO   R0, [R2], #4
                BLO     LoopRel
DataIsEmpty:
@  Clear .bss section (Zero init)
                MOV     R0, #0
                LDR     R1, =__bss_start__
                LDR     R2, =__bss_end__
                CMP     R1,R2
                BEQ     BSSIsEmpty
LoopZI:         CMP     R1, R2
                STRLO   R0, [R1], #4
                BLO     LoopZI
BSSIsEmpty:
@  Enter the C code
@                IMPORT  __main
@                LDR     R0, =__main
                .extern main
                LDR R0, =main
                BX      R0
@ User Initial Stack & Heap (not used in GNU port)
@@                AREA    |.text|, CODE, READONLY
@@                IMPORT  __use_two_region_memory
@@                EXPORT  __user_initial_stackheap
@@__user_initial_stackheap
@@                LDR     R0, =  Heap_Mem
@@                LDR     R1, =(Stack_Mem + USR_Stack_Size)
@@                LDR     R2, = (Heap_Mem +      Heap_Size)
@@                LDR     R3, = Stack_Mem
@@                BX      LR
@@ IRQ_Wrapper based on Examples for
@@ AT91-ARM7TDMI AIC from Atmel,
@@ adapted to LPC23xx/24xx VIC by M. Thomas
@@ This wrapper avoids compiler-dependencies.
.set LPC_BASE_VIC, 0xFFFFF000
.set VIC_VectAddr, 0xF00
.arm
IRQ_Handler:
@- Manage Exception Entry
@- Adjust and save LR_irq in IRQ stack
            sub         lr, lr, #4
            stmfd       sp!, {lr}
@- Save SPSR need to be saved for nested interrupt
            mrs         r14, SPSR
            stmfd       sp!, {r14}
@- Save and r0 in IRQ stack
            stmfd       sp!, {r0}
@- Load the ISR-Address from VICVectAddr
            ldr         r14, =LPC_BASE_VIC
            ldr         r0 , [r14, #VIC_VectAddr]
@- Enable Interrupt and Switch in Supervisor Mode
           msr         CPSR_c, #Mode_SVC
@- Save scratch/used registers and LR in User Stack
            stmfd       sp!, { r1-r3, r12, r14 }
@- Branch to the routine pointed by the VIC_VectAddr
            mov         r14, pc
            bx          r0
@- Restore scratch/used registers and LR from User Stack
            ldmia       sp!, { r1-r3, r12, r14 }
@- Disable Interrupt and switch back in IRQ mode
            msr         CPSR_c, #I_Bit | Mode_IRQ
@-  Mark the End of Interrupt on the VIC
@   by writing to VICVectAddr - not needed
@   here since already done in the ISRs
@@           ldr         r14, =LPC_BASE_VIC
@@           str         r14, [r14, #VIC_VectAddr]
@- Restore R0
            ldmia       sp!, {r0}
@- Restore SPSR_irq and r0 from IRQ stack
            ldmia       sp!, {r14}
            msr         SPSR_cxsf, r14
@- Restore adjusted  LR_irq from IRQ stack directly in the PC
            ldmia       sp!, {pc}^
@                END
.end
void RTCHandler (void) __irq
  RTC_ILR |= ILR_RTCCIF;        /* clear interrupt flag */
  IENABLE;            /* handles nested interrupt */
  alarm_on = 1;
  IDISABLE;
  VICVectAddr = 0;        /* Acknowledge Interrupt */
c таким стартапом не нужен __IRQ ?
Сообщение отредактировал sergey sva - Mar 22 2011, 08:25
RSS Текстовая версия Сейчас: 20th July 2025 - 01:31
Страница сгенерированна за 0.01382 секунд с 7
