> AVR ADC 10 bit ,help me
vanduongbk
сообщение Apr 2 2011, 03:49
Пользователь №: 61 811
I write program convert adc 10 bit and results to led ,it operates accuracy but i have a problem while simulation by protues ,it appears warning as below ,i dont know it operate or not in real circuit ,please help me
this is warning
and this is code
and I want to ask how I can transfer this 10 bit once time to pc through rs232
TVF
сообщение Apr 2 2011, 04:49
Пользователь №: 54 076
Datasheet page 214: "ADCL must be read first, then ADCH"
impossible
Сообщение отредактировал TVF - Apr 2 2011, 04:51
Son Of Stone
сообщение Apr 2 2011, 07:35
Пользователь №: 44 106
ATmega's UART allows sending from 5 to 9 data bits at once (in one frame). Best frame format for communication with PC (using hardware RS232 or USB-TO-COM adapter) is 8 data bits and 1 stop bit. You should send ADC conversion result in two frames using "USART Data Register
Empty (UDRE) Interrupt" (Page 150 in datasheet). Example:
Chip type           : ATmega16
Program type        : Application
Clock frequency     : 14,745600 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
#include <mega16.h>
register unsigned char ADCH_, ADCL_; //Plase variables in working registers for fast access to them
// ADC interrupt service routine
interrupt [ADC_INT] void adc_isr(void)
ADCL_ = ADCL;
ADCH_ = ADCH; //Right order to read ADC result!
//Preparing data to transmission
ADCH_<<=3;
ADCH_|=ADCL_>>5;
ADCL_&=0x1F;
//Now we have 5 higher bits of the result in ADCH_ and 5 lower bits of result in ADCL_;
ADCH_|=0x80; //Set MSB in ADCH_ in 1 for correct handling recived data on PC
//Start Transmission!
UDR=ADCH_;
UCSRB=0x28;//UDRE interrupt enabled
// USART Transmitter interrupt service routine
interrupt [USART_DRE] void usart_tx_udre(void)
UDR=ADCL_;
UCSRB=0x08;   //UDRE interrupt disabled
ADCSRA|=0x40; //Start next ADC conversion!!;
void main(void)
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: Off
// USART Transmitter: On, UDRE int. On
// USART Mode: Asynchronous
// USART Baud Rate: 57600
UCSRA=0x00;
UCSRB=0x08; //TXEN=1;
UCSRC=0x86; //8-bit frame
UBRRH=0x00;
UBRRL=0x0F;
//ADC initialization
ADMUX=0xC0; // ADC Voltage Reference: Int., cap. on AREF, INPUT=PORTA.0
ADCSRA=0xCF; // ADC Clock frequency: 115,200 kHz, START FIRST CONVERSION
#asm("sei")
while (1);
P. S. Van Duong, are you from Vietnam? I glad to see vietnamese man on this forum!
My e-mail is KT829A[dog]yahoo[dot]com. Also i use YahooMessanger with this Yahoo ID. Any messages welcome!
_Pasha
сообщение Apr 3 2011, 04:38
Пользователь №: 29 509
BTW avr DLL is slightly mature in your installation, most recent is 7.7SP0 build 9076.
But, as mentioned before, the key problem is an order of reading ADCL:ADCH
vanduongbk
сообщение Apr 3 2011, 06:19
thank you very much for your best reply
yes ,i come from vietnamese , your id is KT829A
thank again
i am using protues 7.5 sp3
i dont know where i can download 7.7 full ,please help me
Сообщение отредактировал IgorKossak - Apr 3 2011, 18:34
Причина редактирования: ridiculous quoting
_Pasha
сообщение Apr 3 2011, 07:26
Check your private mail box
vanduongbk
сообщение Apr 5 2011, 07:08
and now i only use adc bit ,i transmit data to pc but how i can plot graph from this data which x -axis is time and y -axis is data in voltage
please help me in any programming as VB,VC ,matlab .....
_Pasha
сообщение Apr 5 2011, 08:25
Maybe you can store data in *.csv format and then import in excel or open office calc to build diagram. That's the simplest way. But...Are you need to plot in a realtime?
P.S. I found in my archives the following link oscilloscope lib
Look at this. Perhaps it is very helpful
vanduongbk
сообщение Apr 6 2011, 05:04
yes i need to plot it in real time ,please help me ,if can please in vc or vb thank again
you can help me about using Universal Real-Time Software Oscilloscope GUI DLL Library
Сообщение отредактировал vanduongbk - Apr 6 2011, 05:05
fest
сообщение Apr 6 2011, 06:34
Пользователь №: 59 936
i have code work with rs232 in borland delphi. you can translate it to whatever you need.
CODE
unit Unit33;
interface
uses
Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
Dialogs, StdCtrls, ExtCtrls, ComCtrls;
type
TForm1 = class(TForm)
Timer1: TTimer;
Label2: TLabel;
Label1: TLabel;
Timer2: TTimer;
Image1: TImage;
procedure FormCreate(Sender: TObject);
procedure q(Sender: TObject; var Action: TCloseAction);
procedure Timer1Timer(Sender: TObject);
private
{ Private declarations }
public
{ Public declarations }
end;
var
Form1: TForm1;
hcom,houtfile: thandle;
dcb: tdcb;
stat: tcomstat;
lock: bool;
bytecount: dword;
databuf, x: byte;
const bufsize=sizeof(databuf);
implementation
{$R *.dfm}
procedure TForm1.FormCreate(Sender: TObject);
begin
x:=0;
stat.cbInQue:=0;
bytecount:=0;
lock:=true;
hcom:=createfile('com3',generic_read or generic_write,0,nil,open_existing,file_attribute_normal,0);
if hcom=invalid_handle_value then begin
showmessage('can''t open port');
application.Terminate;
end;
setupcomm(hcom,1600,1600);
with dcb do begin
baudrate:=57600;
bytesize:=8;
parity:=noparity;
stopbits:=onestopbit;
end;
if not setcommstate(hcom,dcb) then begin
showmessage('can''t set port');
end;
houtfile:=createfile('out.txt',generic_read or generic_write,0,nil,open_always,
if houtfile=invalid_handle_value then begin
showmessage('can''t open out file');
end;
lock:=false;
end;
procedure TForm1.q(Sender: TObject; var Action: TCloseAction);
begin
closehandle(houtfile);
closehandle(hcom);
end;
procedure TForm1.Timer1Timer(Sender: TObject);
var i,blocks,errors,bytes: dword;
begin
if not lock then begin
lock:=true;
clearcommerror(hcom,errors,@stat);
blocks:=stat.cbInQue div bufsize;
if blocks>0 then begin
for i:=1 to blocks do begin
if not readfile(hcom,databuf,bufsize,bytes,nil)
then beep;
writefile(houtfile,databuf,bufsize,bytes,nil);
inc(bytecount,bytes);
image1.Canvas.Pixels[x, 255-databuf]:=0;
inc(x);
if (x > 340) then x:=0;
end;
flushfilebuffers(houtfile);
end;
label1.Caption:='read '+inttostr(blocks)+
' blocks. write in file '+inttostr(bytecount)+' bytes';
form1.Caption:=datetimetostr(date+time);
lock:=false;
end;
end;
end.
Сообщение отредактировал IgorKossak - Apr 6 2011, 07:06
Причина редактирования: Use [codebox] tags
_Pasha
сообщение Apr 6 2011, 06:48
vanduongbk
сообщение Apr 7 2011, 02:26
Цитата(fest @ Apr 6 2011, 13:34) *
thank you for this help but i cant know borland delphi language because i am not learnt this language
Сообщение отредактировал IgorKossak - Apr 7 2011, 07:19
Причина редактирования: overquoting
defunct
сообщение Apr 7 2011, 21:44
кекс
Пользователь №: 12 326
Borland C++ Builder uses the same set of VCL components as Delphi. I'd suggest to get Borland C++ Builder 6.0 and to have a look at the "chart" component example there.
Its pretty simple to draw graphics with it. Much simpler than in stupid vc.
All what you'd need to get done is to launch C++ Builder, find "Chart" component on the components toolbar in "Additional" section, put "Chart" component on the application form, setup needed parameters width/ height / color / font size etc, then periodically re-load actual values gotten from COM port into it in real time. It shall draw graphic and scale automatically.
If you'd find "Chart" is not what you're looking for (e.g. too slow or too smart sm.gif ), you may refer to more stupid "Image" component example. In the "Image" you're allowed to draw graphic primitives(pixels, lines, circles etc) manually, like follows:
Image1->Canvas->pixels[x, y] = color;
note: referring directly to pixels[] array would work slower compared to drawing graphic with advanced func primitives - line(), rect(), arc() etc.
fest already showed how simple the program may be on Delphi. Same size program will be in C++ Builder just different lang.
btw, there is nothing complex in reading Delphi, below are several compliances b/w those langs, which would allow you to read fest's example:
deplhi               C
begin              -  {
end                -  }
integer(x)         -  (int)x
var x,y : integer; -  int x, y;
if condition then  -  if (condition)
  operator1              operator1;
else                  else
  operator2;             operator2;
Form1.Image1       -  Form1->Image1
not                -  !
or                 -  ||
and                -  &&
RSS Текстовая версия Сейчас: 22nd August 2025 - 16:55
Страница сгенерированна за 0.01478 секунд с 7
