> подключение nios к пк через avalon-usb2.0
Sidny Sho
сообщение May 24 2011, 06:11
Пользователь №: 63 923
Привет всем. При добавлении ядра usb 2.0 к проекту с ниосом возникает куча ошибок:
Error: set ALTERA_HW_TCL_KEEP_TEMP_FILES=1 to retain temp files
Error: Command: d:/altera/10.1sp1/quartus//bin/quartus_sh.exe -t C:/Users/mastak/AppData/Local/Temp/alt5118_6414808022124526354.dir/0002_sopcqmap/not_a_project_setup.tcl
Error: Command: d:/altera/10.1sp1/quartus//bin/quartus_map.exe not_a_project --generate_hdl_interface=D:/altera/10.1sp1/ip/sls/usb20hr/hardware/component/hdl/sls_avalon_usb20hr.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/mastak/AppData/Local/Temp/alt5118_6414808022124526354.dir/0002_sopcqmap/
Error: Info: *******************************************************************
Error: Info: Running Quartus II Shell
Error:     Info: Version 10.1 Build 197 01/19/2011 Service Pack 1 SJ Web Edition
Error:     Info: Copyright (C) 1991-2011 Altera Corporation. All rights reserved.
Error:     Info: Your use of Altera Corporation's design tools, logic functions
Error:     Info: and other software and tools, and its AMPP partner logic
Error:     Info: functions, and any output files from any of the foregoing
Error:     Info: (including device programming or simulation files), and any
Error:     Info: associated documentation or information are expressly subject
Error:     Info: to the terms and conditions of the Altera Program License
Error:     Info: Subscription Agreement, Altera MegaCore Function License
Error:     Info: Agreement, or other applicable license agreement, including,
Error:     Info: without limitation, that your use is for the sole purpose of
Error:     Info: programming logic devices manufactured by Altera and sold by
Error:     Info: Altera or its authorized distributors.  Please refer to the
Error:     Info: applicable agreement for further details.
Error:     Info: Processing started: Tue May 24 10:10:22 2011
Error: Info: Command: quartus_sh -t C:/Users/mastak/AppData/Local/Temp/alt5118_6414808022124526354.dir/0002_sopcqmap/not_a_project_setup.tcl
Error: Info: Evaluation of Tcl script C:/Users/mastak/AppData/Local/Temp/alt5118_6414808022124526354.dir/0002_sopcqmap/not_a_project_setup.tcl was successful
Error: Info: Quartus II Shell was successful. 0 errors, 0 warnings
Error:     Info: Peak virtual memory: 130 megabytes
Error:     Info: Processing ended: Tue May 24 10:10:22 2011
Error:     Info: Elapsed time: 00:00:00
Error:     Info: Total CPU time (on all processors): 00:00:00
Error: Command took 0.464s
Error: Info: Running Quartus II Generate HDL Interface
Error: Info: Command: quartus_map not_a_project --generate_hdl_interface=D:/altera/10.1sp1/ip/sls/usb20hr/hardware/component/hdl/sls_avalon_usb20hr.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/mastak/AppData/Local/Temp/alt5118_6414808022124526354.dir/0002_sopcqmap/
Error: Error: Can't find valid feature line for core 5750_0A01 in current license
Error: Error (10003): Can't open encrypted VHDL or Verilog HDL file "d:/altera/10.1sp1/ip/sls/usb20hr/hardware/component/hdl/sls_avalon_usb20hr.v" -- current license file does not contain a valid license for encrypted file
Error: Error: Quartus II Generate HDL Interface was unsuccessful. 2 errors, 0 warnings
Error:     Error: Peak virtual memory: 243 megabytes
Error:     Error: Processing ended: Tue May 24 10:10:23 2011
Error:     Error: Elapsed time: 00:00:01
Error:     Error: Total CPU time (on all processors): 00:00:00
Error: Command took 0.693s
Error: Analyser output file not present: sls_avalon_usb20hr.v.xml
Error: No definition of sls_avalon_usb20hr in D:/altera/10.1sp1/ip/sls/usb20hr/hardware/component/hdl/sls_avalon_usb20hr.v
Warning: sls_avalon_usb20hr_0: set_interface_property: Interface conduit_end (conduit) can't have associatedClock
Info: sls_avalon_usb20hr_0: IN Buffer Memory Size = 2 KBytes
Info: sls_avalon_usb20hr_0: OUT Buffer Memory Size = 2 KBytes
Info: sls_avalon_usb20hr_0: Disabling simulation.
Info: sls_avalon_usb20hr_0: Use ' / ' instedad of ' \ ' in Hex file path name
Info: sls_avalon_usb20hr_0: Hex file : Enum_ram.hex.
Ответов (1 - 2)
spectr
сообщение May 24 2011, 06:53
Из: Earth
Пользователь №: 1 437
Ему не хватает лицензии на это ядро. Либо ковыряйте, либо покупайте.
Sidny Sho
сообщение May 24 2011, 09:48
а как это можно обойти?
RSS Текстовая версия Сейчас: 20th July 2025 - 20:54
Страница сгенерированна за 0.01361 секунд с 7
