> CST Suite 2006, Чаво там ишо насочиняли ?
navuho
сообщение Oct 27 2005, 14:35
Пользователь №: 6 972
This list provides an overview of some of the most important innovations in the new Version 2006 of CST MICROWAVE STUDIO® .
General
Direct access to online support page.
Implemented an option to add one ore more readme files to the navigation tree.
Last stored view setting is restored after opening a project and shown in the preview bitmap.
Allow to enter (and simulate) eps / mue values < 1.0.
New dialog added for non-uniform scaling of the structure.
User defined shortcuts for menu entries.
Auto save feature added which saves the model automatically in user specified time intervals.
Improved handling of tables (more plot options, better data export).
Distributed computing revised.
Dispersive material fitting for (Re, Im) data lists (eps/mue) and magnetic tanD implemented.
Simulate lossy materials as lossfree or pec materials due to solver switch.
Import / Export
Added Agilent ADS component export.
Added support for temperature, voltage, current, resistance, conductance, inductance, and capacitance.
Free surfaces are considered by Pro/E import.
Import of Mecadtron models.
Import of curves added.
Arbitrary material properties can be assigned for tissues of voxel data imports.
Modeller
Multi selection for wires and materials added.
Creation of cylinder barrels for Tetrahedral solvers enabled.
Tree does not change anymore when entering mesh mode.
Implemented preview function in material dialog for user defined dispersion and tand list.
Transformations for lumped elements and ports added.
New dialog for animation of parameters.
Added the possibility to define multiple layers for the background material.
Transformations of discrete elements.
Hide/Unhide added to change the visibility of all dielectric and metal materials at once.
Multiple selection added for shell object or thicken sheet.
Multiple selection for mesh properties of wires added.
Edit feature for curve wire transformations added.
Definition of arbitrary planes now possible.
JEDEC Norm for bond wires added.
Variable relative position of maximum for spline type bond wires added.
Mesh Generation / Matrix Calculation
Added fixpoints at the corners of waveguide ports.
New PBA acceleration feature implemented.
Transient Solver
General 1st and 2nd order dispersive models are available in TD solver now.
Memory statistics for solver run and matrix calculation added to TD solver logfile.
Implemented current distribution excitation.
AR-filter can now be applied to probes and voltage monitors via VBA.
Number of pulses is parameterized.
Post Processing
2D plots can be visualized on arbitrary cut planes.
Renewed table properties dialog box, added tuning sliders.
Evaluate field on face for tetrahedral mesh enabled.
Smith charts can now also be plotted for S-parameters with frequency dependent reference impedances.
Evaluate field on curve for tetrahedral mesh enabled.
Energy density and loss density plots now work with tetrahedral fields.
Plot average vector length over all phases for complex vector fields implemented.
Loss and Q calculation for tetrahedral mesh implemented.
Surface losses can be added to navigation tree by enabling 'Save 3d data' in Q specials.
Combine results for far fields with tetrahedral mesh.
Combine results: Added frequency selection and farfield only option.
Replaced spice executable by newer version.
Implemented new Network MOR.
SAR dialog now enables use of volume based SAR calculation.
Ports
Allow to enter additional space around a waveguide port definition based on picks.
Farfield
Farfield polar plot now has z-axis in vertical direction.
Farfields can be visualized now together with the structure.
Farfield calculation for Tet-FD added.
Implemented VBA commands to calculate multiple farfield points.
Lossy dielectric ground plane for farfield calculation implemented.
Eigenmode Solver
External Q-factor calculation for the eigenmode solver.
The lossy JD Eigenmode solver now offers the option to use a TD compatible material treatment.
Frequency Domain Solver
Up and down arrow keys now work for selecting a field of a FD solver result file map, also for unit cell calculations.
Info text for result file maps now displays all parameters, including e.g. theta and phi.
The tetrahedral mesh type now is the default for the Frequency Domain solver.
Hex-FD solver, Hex-FD-MOR solver, and Eigenmode solver are now external executables.
General 1st and 2nd order dispersive models are available in FD solver now.
FD solvers now automatically increase the number of samples until S-parameter convergence if required.
The Hex-FD mesh and the adapted Tet-FD mesh are now reused or can be reused for faster scan angle parameter sweeps.
Memory statistics for solver run and matrix calculation added to Hex FD solver logfiles.
Hex and Tet FD solvers now log the number of DOFs and their memory usage.
The maximum number of processors can now be set for the Hex- and Tet-FD solvers.
The FD solver with hex and tet mesh now features a weight for evanescent modes during an S-parameter sweep.
Improved final FD solver frequency sweep error estimation, which may lead to a faster convergence.
An alternative selection method via dialog is now available for S-parameters.
FD solver's list of S-parameters-to-consider now takes into account Floquet ports.
Finished modifications for analytic Tet-FD Floquet modes.
Implemented Floquet port mode selection dialog.
The unit cell feature is available for Tet- and Hex-FD, with non-rectangular unit cells in the Tet-FD solver only.
It is now possible to display FD solver samples together with the broadband 1D curves when selecting "additional marks".
Allowed changing the result file map selection during FD solver runs, and added update.
The Hex-FD solver now switches between iterative and direct solvers in the 'auto' mode, depending on the initial guess.
The Hex-FD solver now calculates the initial guess to the solution before solving the equation, which usually speeds up a F-sweep.
Improved iterative solver for Hex-FD: periodic boundary conditions.
Improved iterative solver for Hex-FD (except for periodic boundary conditions).
Improved calculation of Hex-FD solver's initial guess to the solution, especially for lossy or periodic problems.
Added bad element visualization for the tetrahedral mesh, which is used by the Tet-FD solver.
An ohmic sheet surface impedance material with frequency-independent impedance is now available for Tet-FD.
Improved the memory requirements for the Tet-FD with many excitations.
A first order Tet-FD mode with direct solver is now available.
The Tet-FD solver now features a list of userdefined excitation ports and modes.
Tet-FD solver now supports a surface impedance model for corrugated walls.
The Tet-FD solver now supports diagonal anisotropic and gyrotropic materials.
The Tet-FD solver now also features periodic boundary conditions, except for ports.
The Tet-FD solver supports discrete ports and lumped elements.
The Tet-FD solvers S-parameter progression during an adaptive mesh refinement is now added to the result tree.
Tet-FD solver now writes a mesh adaptation log file.
The Tet-FD solver now features first order open boundary conditions.
Discrete ports are available for the fast resonant solver.
Hex MOR3D solver can be used with monitors.
MOR3D solver can handle (small) dielectric losses and dispersive materials.
- navuho   CST Suite 2006   Oct 27 2005, 14:35
RSS Текстовая версия Сейчас: 13th August 2025 - 12:05
Страница сгенерированна за 0.01343 секунд с 7
