> Вышел новый Hotfix SPB16.5
Alexander E
сообщение Jul 6 2011, 14:07
Пользователь №: 58 959
Вышел новый Hotfix:16.50.001
293005 ALLEGRO_EDITOR DATABASE Allegro crash when attempting to move mech. symbol
298289 CIS EXPLORER CIS querry gives wrong results
366939 ALLEGRO_EDITOR OTHER Cannot attach refdes on silk subclass with add text
432200 ALLEGRO_EDITOR MANUFACT Fillets with an arc are required for Flexi designs
443447 APD SHAPE Shapes not following the acute angle trim control setting.
473308 PSPICE AA_SENS Passing variables to lower level blocks using subparam
517556 PSPICE AA_SENS Advanced Analysis does not support variables being passed down the hierarchy
548143 ALLEGRO_EDITOR SHAPE Dynamic shpe on Etch TOP will not void properly.
606959 ADW COMPONENT_BROWSE Key properties with blank values are not getting read in shooping cart
616466 ALLEGRO_EDITOR SHAPE Solid shapes are not getting filled
641358 SIP_LAYOUT DIE_STACK_EDITOR Request for Via and Multi Layer Pin support for DIE stack Area (blue region)
644122 SIP_LAYOUT OTHER SiP Layout - xsection - ERROR Adjacent conductive layers are not allowed, but these are diestack layers not conductor
645816 ALLEGRO_EDITOR SHAPE Slide a cline all removes gnd shapes on board
725355 ALLEGRO_EDITOR SHAPE User can not voided Logo correctly.
763569 CONCEPT_HDL CORE Display status of Hide/Show unconnected pins icon in DE HDL UI
770021 CAPTURE BACKANNOTATE Changing pin group property after pin swap resets pin numbers
792126 CAPTURE PROPERTY_EDITOR Attempt to change display for occ prop resets
799014 CONCEPT_HDL CONSTRAINT_MGR concept2cm errors not shown in export physical after hier_write
803147 CIS LINK_DATABASE_PA Link DB part should not change RefDes of multi package part
804240 PSPICE DEHDL Problem in simulation result for a multi-section split part.
809118 CAPTURE NETLISTS ENH to compare two schematic Capture designs
816568 ALLEGRO_EDITOR SHAPE shape disappears when update to smooth.. State no etch
830053 CAPTURE STABILITY DXF export fails if schematic folder name as /
832108 ALLEGRO_EDITOR SHAPE Shape void incorrectly.
833542 CONCEPT_HDL CORE PDF publisher font is NOT WYSIWIG with respect to what seen in DE HDL
835777 CIS DERIVE_NEW_DB_PA For XLS, donot display table as worksheetName$worksheetName to avoid 8012 error
837640 CIS GEN_BOM date format of CIS BOM has broken macros of 16.2 in 16.3 version
844074 APD SPECCTRA_IF Export Router fails with memory errors.
851595 CONCEPT_HDL CORE Pin numbers overlap on the pin and increase in size
852832 CAPTURE BACKANNOTATE Why is Capture crashing with Mentor back annotation?
855015 ALLEGRO_EDITOR OTHER The rats are NOT connecting to the ends of the clines like they should be.
859883 CAPTURE NETLISTS ENH to compare two schematic Capture designs
866009 SIG_INTEGRITY OTHER Net with Pull-up/down should not be used for Diff-pair.
866830 SCM REPORTS Multiple lines added as separator between title block and report header instead of single line
866833 SCM REPORTS Extra indentation is left in the left side of the report when the Line Numbers are set to OFF
868618 SCM IMPORTS Block re-import does not update the docsch and sch view
873402 SIP_LAYOUT LOGIC pin swap for co-design die in SiP
874010 SIG_INTEGRITY OTHER PCB SI crashes when the Xnet is extracted with VARIANT_TO_IGNORE property.
874400 ALLEGRO_EDITOR INTERACTIV Flip mode issue with move command
874966 ALLEGRO_EDITOR INTERFACES Placed mechanical component do not get Ref Des or part number in IDF file
875709 ALLEGRO_EDITOR REPORTS Film area report generated incorrect data at l1
876275 CONCEPT_HDL CONSTRAINT_MGR Constraint Manager not retaining target net
879361 SCM UI SCM crashes when opening project
879496 CONCEPT_HDL OTHER Customer wants to have “the tabulation” key as separator in HDL BOM.
879514 PSPICE AA_MC Monte Carlo to handle equation as comp VALUE.
881845 ALLEGRO_EDITOR SHAPE Delete island deletes complete shape
882413 PDN_ANALYSIS PCB_PI PDN Analysis should support routed power nets
882427 PDN_ANALYSIS PCB_PI PDN Analysis target impedance should have a variable multiplier
882567 SIG_INTEGRITY OTHER PCB SI crash if boolean type prop was specified to VARIANT env.
882644 ALLEGRO_EDITOR PLACEMENT PCB Place Replicate Function automatically match Enhancement
883164 ALLEGRO_EDITOR INTERACTIV Vias marked fanout moves away from position when moving component
883224 SIG_INTEGRITY SIMULATION crash while reflection simulation from Constraint Manager
883760 PCB_LIBRARIAN METADATA Incorrectly formatted revision.dat file in the metadata folder
885391 SIG_INTEGRITY SIMULATION RLGC data sampling algorithm and w-element interpolation.
885849 ALLEGRO_EDITOR MANUFACT Silkscreen Audit cannot find Solder mask for the text string
885996 SIG_INTEGRITY OTHER The effect of sn_maxwidthlimit user preference is not seen in cross section impedance calculations
886090 ALLEGRO_EDITOR INTERACTIV Add Arc w/Radius does not snap to grid
887180 CAPTURE SCHEMATIC_EDITOR Signals Navigation window doesn’t get updated for Buses
887442 APD SHAPE Copper pour of Dynamic shapes on Top layer which contains many existing signal traces fails.
887578 SCM AUTO_UI Component Replace pops-up the DSPANE-204 Message
887926 SIG_INTEGRITY GEOMETRY_EXTRACT Field solution failed if diff trace on bottom doesn't have reference plane.
888414 SIG_EXPLORER OTHER View Trace Parameter display the thickness of dielectric incorrectly.
888600 CONCEPT_HDL CREFER Cross References not added to Schegen schematic
888679 SIP_LAYOUT SHAPE Can't create the Dynamic shape on layer M1_sig without unwanted horizontal openings appearing.
888804 ALLEGRO_EDITOR OTHER Fillet will become static shape after import from partition board.
888945 CONCEPT_HDL OTHER unplaced component after placing module
889222 ALLEGRO_EDITOR SHAPE Allegro freezes/hangs when adding shape as Polygon with OpenGL ON.
889365 SIG_INTEGRITY GEOMETRY_EXTRACT top/bottom trace impedances extracted to sigxp are wrong in 16.3
889404 ALLEGRO_EDITOR OTHER Incorrect pad size for Top conductor padstack written to column 59-62.
889426 CONCEPT_HDL CHECKPLUS CheckPlus does not find single node net
889636 ALLEGRO_EDITOR MANUFACT Incorrect spelling of "Visibility" in "Film Control" tab in the Artwork Control Form
891235 F2B PACKAGERXL Packager crashes without creating a pxl.log file
891292 ALLEGRO_EDITOR SHAPE arc routing causes weird undesireable shape fill performance
891856 ALLEGRO_EDITOR EDIT_ETCH crash when sliding diff pairs
892375 ALLEGRO_EDITOR PLACEMENT Place Replicate Update disband other groups, irrespective Fixed property added or not.
892455 ALLEGRO_EDITOR SYMBOL Why the overlapping pins are not reported with DRC?
892541 SIG_EXPLORER OTHER Export/Import layerstack through the technology file is changing the layer thickness
892766 APD WIREBOND Excuting Finger moving cannot push aside finger to move with together by shove all mode
892907 ALLEGRO_EDITOR DRC_CONSTR DRC not reported for etch_turn_under_pin violations
892963 ALLEGRO_EDITOR SKILL Bad shape boundary created after axlPolyOperation 'OR
892964 SIP_LAYOUT LOGIC Request that Edit Parts List use Dashes "-".
893295 APD WIREBOND Why move wirebond command does not shove wirebonds? This result in drcs.
893706 CONSTRAINT_MGR OTHER On line DRC hangs on partitioned board
893743 APD EDIT_ETCH Route behavior when spanning pads not as expected.
893783 SIP_LAYOUT OTHER Padstack Design Editing update File menu with a Update to Design and Close instead of 2 operation
894456 ALLEGRO_EDITOR REPORTS Request Net names be added to Propagation delay lines of the DRC report.
894499 SIG_INTEGRITY LIBRARY Tool crashes when moving a cline or selecting the Info icon with OpenGL on.
894582 APD SHAPE When making a dynamic xhatch Via shapes surrounding are abnormal.
895542 SIP_LAYOUT WIREBOND SIP design crashing when moving bond finger using blur mode BLUR_BONDFINGER_PRESRV_CON
895591 ALLEGRO_EDITOR PCAD_IN Importing PCAD file fails to get to the point where we can map layers
895757 APD ARTWORK Import Gerber command could not be imported Gerber data
895964 CONCEPT_HDL CHECKPLUS The CheckPlus command “getFileSubstrings” is not working correctly
896428 SCM UI Changed Ref Des value not maintained in DEHDL block when part is replaced
896655 CAPTURE EDIF Import/Export Design of Hierarcy design with OrCAD Capture
896846 CAPTURE IMPORT/EXPORT Import edif2cap and capture is crashing
897155 ALLEGRO_EDITOR REPORTS Copper coverage in L2 and L7 looks like the same but film area report had large gap.
897654 CAPTURE EE_INTERSHEET_RE Capture crashes on adding intersheet refernces in abbreviated format on attached design.
899344 RF_PCB BE_IFF_EXPORT dlibx2iff does not provide the component boundary drawing
899629 CONSTRAINT_MGR OTHER ECset for Total Etch Lenght is not present in OrCAD Prof
900175 CONCEPT_HDL CONSTRAINT_MGR Few Xnets are lost from Match Group after packaging and importing the netlist to board file.
900481 CONCEPT_HDL CORE Genview creates a larger symbol without taking the no. of pin in consideration
900813 ALLEGRO_EDITOR DRC_CONSTR With rotated pads, pad (pin - via) soldermask spacing DRC is unreasonable.
900905 PSPICE STABILITY Simsrvr crash and RPC Server unavailable error while running simulation.
901783 CONCEPT_HDL CORE CDS_PART_NAME is annotated on the schematic canvas after running back annotation in 16.5
901909 APD EXPORT_DATA The "package_pin_delay_length.rpt" with Z-axis delay turned on seems wrong
901987 CONCEPT_HDL OTHER SPB16.5 zoom fit does not center the page while ploting the schematic page
902133 CIS OTHER The visible part property value are being shown very distant from part graphics on schematic
902166 SPECCTRA ROUTE Specctra crashes when reading in "bestsave.w" file
902170 ALLEGRO_EDITOR DATABASE Diffpair Issues with OrCad PCB Designer Professional
902177 CONSTRAINT_MGR CONCEPT_HDL Option to view the layer thickness in CM worksheet through worksheet customization
902463 ALLEGRO_EDITOR INTERACTIV APD crashes when we click ( show element ) on certain components
902621 CONCEPT_HDL OTHER Design Differences (vdd) Crashes
902909 APD WIREBOND die to die wirebond crash
902933 ALLEGRO_EDITOR PADS_IN Pads_in fails while reading PADS ASCII file body
903284 PDN_ANALYSIS PCB_STATICIRDROP IRDrop voltage gradients are plotted outside of the PCB outline
903680 CONSTRAINT_MGR ECS_APPLY Constraint Manager not passing all hiearchical member objects to a custom measurement.
904403 ALLEGRO_EDITOR DATABASE Allegro crashes when refreshing module
Евграфов Александр/ Alexander Evgraphov
Skype: alexander.evgraphov
RSS Текстовая версия Сейчас: 19th August 2025 - 21:20
Страница сгенерированна за 0.01993 секунд с 7
