> data2mem ругается на bmm файл
Tanichev
сообщение Aug 5 2011, 09:58
Пользователь №: 63 290
Пытаюсь собрать системку с MicroBlaze на Virtex-4 XC4VLX80. XPS собирает платформу нормально. Использую только BRAM.
Затем, при попытке собрать прошивку вот так ругается:
ERROR:Data2MEM:47 - Not all BitLanes in ADDRESS_SPACE 'microblaze_0.bram_block_0_combined' have BMM location constraints.
    Some data for this ADDRESS_SPACE may be lost during BIT file
    replacement. Verify that the BMM file has location constraints
    for all BitLanes.
      Bitlane(s)
   bram_block_0/bram_block_0/ramb16_0 [31:31]
   bram_block_0/bram_block_0/ramb16_1 [30:30]
   bram_block_0/bram_block_0/ramb16_2 [29:29]
   bram_block_0/bram_block_0/ramb16_3 [28:28]
   bram_block_0/bram_block_0/ramb16_4 [27:27]
   bram_block_0/bram_block_0/ramb16_5 [26:26]
   bram_block_0/bram_block_0/ramb16_6 [25:25]
   bram_block_0/bram_block_0/ramb16_7 [24:24]
   bram_block_0/bram_block_0/ramb16_8 [23:23]
   bram_block_0/bram_block_0/ramb16_9 [22:22]
   bram_block_0/bram_block_0/ramb16_10 [21:21]
   bram_block_0/bram_block_0/ramb16_11 [20:20]
   bram_block_0/bram_block_0/ramb16_12 [19:19]
   bram_block_0/bram_block_0/ramb16_13 [18:18]
   bram_block_0/bram_block_0/ramb16_14 [17:17]
   bram_block_0/bram_block_0/ramb16_15 [16:16]
   bram_block_0/bram_block_0/ramb16_16 [15:15]
   bram_block_0/bram_block_0/ramb16_17 [14:14]
   bram_block_0/bram_block_0/ramb16_18 [13:13]
   bram_block_0/bram_block_0/ramb16_19 [12:12]
   bram_block_0/bram_block_0/ramb16_20 [11:11]
   bram_block_0/bram_block_0/ramb16_21 [10:10]
   bram_block_0/bram_block_0/ramb16_22 [9:9]
   bram_block_0/bram_block_0/ramb16_23 [8:8]
   bram_block_0/bram_block_0/ramb16_24 [7:7]
   bram_block_0/bram_block_0/ramb16_25 [6:6]
   bram_block_0/bram_block_0/ramb16_26 [5:5]
   bram_block_0/bram_block_0/ramb16_27 [4:4]
   bram_block_0/bram_block_0/ramb16_28 [3:3]
   bram_block_0/bram_block_0/ramb16_29 [2:2]
   bram_block_0/bram_block_0/ramb16_30 [1:1]
   bram_block_0/bram_block_0/ramb16_31 [0:0]
FPGA Programming Failed due to errors while initializing bitstream.
Я не могу понять, как собственно должен выглядеть этот файл laughing.gif (он его сгенерил автоматически).
Вот его содержание:
// BMM LOC annotation file.
// Release 12.2 - Data2MEM M.63c, build 1.7 Jun 25, 2010
// Copyright (c) 1995-2011 Xilinx, Inc.  All rights reserved.
// Processor 'microblaze_0', ID 100, memory map.
ADDRESS_MAP microblaze_0 MICROBLAZE 100
    // Processor 'microblaze_0' address space 'bram_block_0_combined' 0x00000000:0x0000FFFF (64 KBytes).
    ADDRESS_SPACE bram_block_0_combined RAMB16 [0x00000000:0x0000FFFF]
        BUS_BLOCK
            bram_block_0/bram_block_0/ramb16_0 [31:31] INPUT = bram_block_0_combined_0.mem;
            bram_block_0/bram_block_0/ramb16_1 [30:30] INPUT = bram_block_0_combined_1.mem;
            bram_block_0/bram_block_0/ramb16_2 [29:29] INPUT = bram_block_0_combined_2.mem;
            bram_block_0/bram_block_0/ramb16_3 [28:28] INPUT = bram_block_0_combined_3.mem;
            bram_block_0/bram_block_0/ramb16_4 [27:27] INPUT = bram_block_0_combined_4.mem;
            bram_block_0/bram_block_0/ramb16_5 [26:26] INPUT = bram_block_0_combined_5.mem;
            bram_block_0/bram_block_0/ramb16_6 [25:25] INPUT = bram_block_0_combined_6.mem;
            bram_block_0/bram_block_0/ramb16_7 [24:24] INPUT = bram_block_0_combined_7.mem;
            bram_block_0/bram_block_0/ramb16_8 [23:23] INPUT = bram_block_0_combined_8.mem;
            bram_block_0/bram_block_0/ramb16_9 [22:22] INPUT = bram_block_0_combined_9.mem;
            bram_block_0/bram_block_0/ramb16_10 [21:21] INPUT = bram_block_0_combined_10.mem;
            bram_block_0/bram_block_0/ramb16_11 [20:20] INPUT = bram_block_0_combined_11.mem;
            bram_block_0/bram_block_0/ramb16_12 [19:19] INPUT = bram_block_0_combined_12.mem;
            bram_block_0/bram_block_0/ramb16_13 [18:18] INPUT = bram_block_0_combined_13.mem;
            bram_block_0/bram_block_0/ramb16_14 [17:17] INPUT = bram_block_0_combined_14.mem;
            bram_block_0/bram_block_0/ramb16_15 [16:16] INPUT = bram_block_0_combined_15.mem;
            bram_block_0/bram_block_0/ramb16_16 [15:15] INPUT = bram_block_0_combined_16.mem;
            bram_block_0/bram_block_0/ramb16_17 [14:14] INPUT = bram_block_0_combined_17.mem;
            bram_block_0/bram_block_0/ramb16_18 [13:13] INPUT = bram_block_0_combined_18.mem;
            bram_block_0/bram_block_0/ramb16_19 [12:12] INPUT = bram_block_0_combined_19.mem;
            bram_block_0/bram_block_0/ramb16_20 [11:11] INPUT = bram_block_0_combined_20.mem;
            bram_block_0/bram_block_0/ramb16_21 [10:10] INPUT = bram_block_0_combined_21.mem;
            bram_block_0/bram_block_0/ramb16_22 [9:9] INPUT = bram_block_0_combined_22.mem;
            bram_block_0/bram_block_0/ramb16_23 [8:8] INPUT = bram_block_0_combined_23.mem;
            bram_block_0/bram_block_0/ramb16_24 [7:7] INPUT = bram_block_0_combined_24.mem;
            bram_block_0/bram_block_0/ramb16_25 [6:6] INPUT = bram_block_0_combined_25.mem;
            bram_block_0/bram_block_0/ramb16_26 [5:5] INPUT = bram_block_0_combined_26.mem;
            bram_block_0/bram_block_0/ramb16_27 [4:4] INPUT = bram_block_0_combined_27.mem;
            bram_block_0/bram_block_0/ramb16_28 [3:3] INPUT = bram_block_0_combined_28.mem;
            bram_block_0/bram_block_0/ramb16_29 [2:2] INPUT = bram_block_0_combined_29.mem;
            bram_block_0/bram_block_0/ramb16_30 [1:1] INPUT = bram_block_0_combined_30.mem;
            bram_block_0/bram_block_0/ramb16_31 [0:0] INPUT = bram_block_0_combined_31.mem;
        END_BUS_BLOCK;
    END_ADDRESS_SPACE;
END_ADDRESS_MAP;
Подскажите пожалуйста, что нужно поправить в этом файле.
Спасибо!
Ответов (1 - 5)
dsmv
сообщение Aug 5 2011, 11:14
Пользователь №: 8 284
Существуют два BMM файла.
Первый формируется при синтезе.
Второй - после трассировки.
Второй файл выглядит так:
    ADDRESS_SPACE bram_block_0_combined RAMB16 [0xFFFF0000:0xFFFFFFFF]
        BUS_BLOCK
            ppc/bram_block_0/bram_block_0/ramb16_0 [63:62] PLACED = X3Y8;
            ppc/bram_block_0/bram_block_0/ramb16_1 [61:60] PLACED = X4Y5;
            ppc/bram_block_0/bram_block_0/ramb16_2 [59:58] PLACED = X4Y6;
            ppc/bram_block_0/bram_block_0/ramb16_3 [57:56] PLACED = X2Y1;
            ppc/bram_block_0/bram_block_0/ramb16_4 [55:54] PLACED = X1Y1;
            ppc/bram_block_0/bram_block_0/ramb16_5 [53:52] PLACED = X4Y8;
            ppc/bram_block_0/bram_block_0/ramb16_6 [51:50] PLACED = X1Y2;
            ppc/bram_block_0/bram_block_0/ramb16_7 [49:48] PLACED = X0Y3;
            ppc/bram_block_0/bram_block_0/ramb16_8 [47:46] PLACED = X3Y6;
            ppc/bram_block_0/bram_block_0/ramb16_9 [45:44] PLACED = X2Y2;
            ppc/bram_block_0/bram_block_0/ramb16_10 [43:42] PLACED = X3Y7;
            ppc/bram_block_0/bram_block_0/ramb16_11 [41:40] PLACED = X4Y7;
            ppc/bram_block_0/bram_block_0/ramb16_12 [39:38] PLACED = X4Y11;
            ppc/bram_block_0/bram_block_0/ramb16_13 [37:36] PLACED = X3Y4;
            ppc/bram_block_0/bram_block_0/ramb16_14 [35:34] PLACED = X4Y4;
            ppc/bram_block_0/bram_block_0/ramb16_15 [33:32] PLACED = X4Y10;
            ppc/bram_block_0/bram_block_0/ramb16_16 [31:30] PLACED = X0Y4;
            ppc/bram_block_0/bram_block_0/ramb16_17 [29:28] PLACED = X2Y0;
            ppc/bram_block_0/bram_block_0/ramb16_18 [27:26] PLACED = X0Y2;
            ppc/bram_block_0/bram_block_0/ramb16_19 [25:24] PLACED = X4Y2;
            ppc/bram_block_0/bram_block_0/ramb16_20 [23:22] PLACED = X0Y0;
            ppc/bram_block_0/bram_block_0/ramb16_21 [21:20] PLACED = X1Y0;
            ppc/bram_block_0/bram_block_0/ramb16_22 [19:18] PLACED = X3Y0;
            ppc/bram_block_0/bram_block_0/ramb16_23 [17:16] PLACED = X3Y1;
            ppc/bram_block_0/bram_block_0/ramb16_24 [15:14] PLACED = X4Y9;
            ppc/bram_block_0/bram_block_0/ramb16_25 [13:12] PLACED = X0Y1;
            ppc/bram_block_0/bram_block_0/ramb16_26 [11:10] PLACED = X3Y5;
            ppc/bram_block_0/bram_block_0/ramb16_27 [9:8] PLACED = X3Y2;
            ppc/bram_block_0/bram_block_0/ramb16_28 [7:6] PLACED = X3Y3;
            ppc/bram_block_0/bram_block_0/ramb16_29 [5:4] PLACED = X4Y3;
            ppc/bram_block_0/bram_block_0/ramb16_30 [3:2] PLACED = X4Y0;
            ppc/bram_block_0/bram_block_0/ramb16_31 [1:0] PLACED = X4Y1;
        END_BUS_BLOCK;
    END_ADDRESS_SPACE;
Обратите внимание на атрибут PLACED - он показывает где расположен блок памяти.
Tanichev
сообщение Aug 5 2011, 11:20
А почему у меня он всего один? Ведь XPS уже всё сделал. А это возможно вбить вручную? Как понимать эти координаты?
Mad_max
сообщение Aug 5 2011, 13:11
Из: Зеленоград
Пользователь №: 23 811
Координаты физического расположения BRAM на кристалле должны соответствовать координатам в BMM файле.
Соответственно проверьте, там ли у Вас BRAM расположены.
dsmv
сообщение Aug 8 2011, 10:14
Наверное он не был указан для ngdbuild;
В параметрах ngdbuild должно быть указано: -bm <имя файла.bmm>
Тогда после par появится файл <имя файла_bd.bmm> с установленными атрибутами размещения.
Tanichev
сообщение Aug 10 2011, 07:25
Собирал платформу вручную, видимо. не нашёл, где и что указывать. Через визард работает. Спасибо за ответы
RSS Текстовая версия Сейчас: 24th July 2025 - 19:43
Страница сгенерированна за 0.01395 секунд с 7
