Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаPrinted Circuits Handbook - 6th Edition - By Clyde F. Coombs (McGraw-Hill - 2008)
PART13. CHAPTER 58
COMPONENT-TO-PWB RELIABILITY—THE IMPACT OF DESIGN VARIABLES AND LEAD FREE
58.3.2 Double-Sided (Mirrored BGA)
"While the double-sided configuration certainly reduces signal delay, the primary disadvantage
is a significant reduction in the thermomechanical reliability of the solder joint interconnects
between the packages and PWB. Placing BGA packages in mirror or quasi-mirror
configurations tends to rigidize the PWB assembly such that it does not bend as much during
temperature cycling.The increased stiffness of the PWB due to double-sided mounting means
the solder joints have to absorb more differential strain between the packages and PWB,
resulting in as much as a 50 percent reduction in solder joint fatigue life (Figs. 58.9 and 58.10).4
In terms of solder joint strain, the effect is the same as having a thicker or stiffer PWB.The primary
failure mode is cracking in the solder joints near the package/joint interface.
Due to the dramatic decrease in assembly reliability when attempting mirrored configurations,
these types of configurations should be avoided whenever possible.When it is impossible
to avoid a mirror configuration, a quasi-mirror configuration without common through-hole
vias is recommended (see Fig. 58.8). Common through-hole vias in this configuration tend to
rigidize the assembly and contribute to further reduction in solder fatigue life. A standard rule
of 50 percent reduction in fatigue life when employing a mirror configuration may be taken as
a first-pass approximation.Thermal cycle testing should be performed to ensure that the reliability
degradation will still keep service life at an acceptable level when either a mirror or
quasi-mirror configuration is considered."
Хотя двусторонняя конфигурация, безусловно, снижает задержки сигнала, основным недостатком является значительное снижение термомеханической надежности
паяных соединений между корпусом компонента и ПП.
Размещение BGA корпусов в зеркальной или квази-зеркальной конфигурациях приводит к упрочнению (увеличению жесткости) ПП таким образом,
что ПП недостаточно прогибается (деформируется) при термоциклировании.
Повышенная жесткость ПП из-за двустороннего монтажа означает что паяные соединения должны поглощать бо'льшие напряжения между корпусом и ПП,
что в конечном итоге приводит к сокращению усталостной долговечности паяных соединений почти на 50 процентнов (рис. 58,9 и 58,10).
Что касается механического напряжения паяных соединений, эффект соответствует более толстой и жесткой ПП.
Первичным видом отказа является растрескивание в месте расположения паяных соединений между корпусом и ПП.
Из-за резкого снижения надежности ПП при использовании зеркальных конфигураций, этих типов конфигураций следует по возможности избегать.
При невозможности отказа от зеркальных конфигурации, рекомендуется применять квази-зеркальные конфигурации без общих сквозных переходных отверстий (см. рис. 58,8).
Общие сквозные переходные отверстия в этой конфигурации, как правило, упрочняют сборку и вносят вклад в дальнейшее снижение усталостной долговечности паяных соединений.
В качестве приближения первого порядка может быть принято стандартное правило 50% сокращения долговечности при использовании зеркальной конфигурации.
При рассмотрении зеркальных или квази-зеркальных конфигураций для того, что бы гарантировать что уменьшение надежности
обеспечивает сохранение ресурса на приемлемом уровне необходимо выполнить комплекс термоциклических испытаний.
