library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_signed.all;
entity MODULE_CUMULATE_SUMM_A is
Port (
clk : in STD_LOGIC;
Data_in : in STD_LOGIC_VECTOR(11 downto 0);
Data_in_en : in STD_LOGIC;
Data_in_Val : in STD_LOGIC;
Data_out : out STD_LOGIC_VECTOR(21 downto 0);
Data_out_Val: out STD_LOGIC;
Data_Start : out STD_LOGIC
end MODULE_CUMULATE_SUMM_A;
architecture Behavioral of MODULE_CUMULATE_SUMM_A is
constant NSUMM : integer := 15000;
constant Nomber_Strobe : integer := 100;
type Memory_Accum is array(0 to 99) of integer;
signal Memory : Memory_Accum := (others => 0);
signal Count : integer := 0;
signal Position : integer := 0;
begin
CS : process(clk)
begin
if clk'event and clk = '1' then
case Data_in_en is
when '1' =>
case Data_in_Val is
when '1' =>
if Count < NSUMM then
Memory(Position) <= CONV_INTEGER(Data_in) + Memory(Position);
if Position < 99 then
Position <= Position + 1;
elsif Position = 99 then
Position <= 0;
Count <= Count + 1;
end if;
elsif Count = NSUMM then
Data_out <= CONV_STD_LOGIC_VECTOR(CONV_INTEGER(Data_in) + Memory(Position),22);
Memory(Position) <= 0;
Data_Start <= '1';
Data_out_Val <= '1';
Position <= 0;
Count <= 0;
end if;
end if;
when others =>
Data_out_Val <= '0';
end case;
when others =>
Data_out <= (others => '0');
Data_Start <= '0';
Position <= 0;
end case;
end if;
end process;
end Behavioral;
Port (
clk : in STD_LOGIC;
begin
CS : process(clk)
begin
case Data_in_en is
when '1' =>
case Data_in_Val is
when '1' =>
Position <= 0;
Count <= Count + 1;
end if;
Data_Start <= '1';
Position <= 0;
Count <= 0;
end if;
end if;
when others =>
end case;
when others =>
Data_Start <= '0';
Position <= 0;
end case;
end if;
end process;
end Behavioral;
В isim все работает, однако если "зашивать" в ПЛИС, все благополучно перестает работать...
Однако если NSUMM = 1000, все работает. Кто может сказать, в чем может быть причина?
