Начал. Нашел пример
* Copyright © 2008 - 2014 Xilinx, Inc. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* Use of the Software is limited solely to applications:
* (a) running on a Xilinx device, or
that interact with a Xilinx device through a bus or interconnect.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* XILINX CONSORTIUM BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
* WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
* OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
* Except as contained in this notice, the name of the Xilinx shall not be used
* in advertising or otherwise to promote the sale, use or other dealings in
* this Software without prior written authorization from Xilinx.
* @file xemaclite_ping_reply_example.c
* This file contains an EmacLite ping reply example in polled mode. This example
* will generate a ping reply when it receives a ping request packet from the
* external world.
* @note
* The local IP address is set to 172.16.63.121. User needs to update
* LocalIpAddr variable with a free IP address based on the network on which
* this example is to be run.
* The local MAC address is set to 0x000A35030201. User can update LocalMacAddr
* variable with a valid MAC address. The first three bytes contains
* the manufacture ID. 0x000A35 is XILINX manufacture ID.
* This program will respond continuously to a number of ping requests as defined
* by MAX_PING_REPLIES in this file.
* <pre>
* MODIFICATION HISTORY:
* Ver Who Date Changes
* 1.00a ktn 20/08/08 First release
* 3.00a ktn 10/22/09 Updated example to use the macros that have been changed
* in the driver to remove _m from the name of the macro.
* 3.01a ktn 08/06/10 Updated the example to support little endian MicroBlaze.
* </pre>
/***************************** Include Files *********************************/
#include "xparameters.h"
#include "xstatus.h"
#include "xemaclite.h"
#include "xil_io.h"
/************************** Constant Definitions *****************************/
* The following constants map to the XPAR parameters created in the
* xparameters.h file. They are defined here such that a user can easily
* change all the needed parameters in one place.
#define EMAC_DEVICE_ID XPAR_EMACLITE_0_DEVICE_ID
* Change this parameter to limit the number of ping replies sent by this
* program.
#define MAX_PING_REPLIES 10 /* Maximum number of ping replies */
#define BROADCAST_PACKET 1 /* Broadcast packet */
#define MAC_MATCHED_PACKET 2 /* Dest MAC matched with local MAC */
#define IP_ADDR_SIZE 4 /* IP Address size in Bytes */
#define ARP_REQUEST 0x0001 /* ARP Request bits in Rx packet */
#define ARP_REPLY 0x0002 /* ARP status bits indicating reply */
#define ARP_PACKET_SIZE 0x3C /* ARP packet len 60 Bytes */
#define ICMP_PACKET_SIZE 0x4A /* ICMP packet length 74 Bytes
* including Src and Dest MAC Address */
#define BROADCAST_ADDR 0xFFFF /* Broadcast Address */
#define CORRECT_CKSUM_VALUE 0xFFFF /* Correct checksum value */
#define IDENT_FIELD_VALUE 0x9263 /* Identification field (random num) */
* Definitions for the locations and length of some of the fields in a
* IP packet. The lengths are defined in Half-Words (2 bytes).
#define ETHER_PROTO_TYPE_LEN 1 /* Ethernet protocol Type length */
#define SRC_MAC_ADDR_LOC 3 /* Source MAC address location */
#define MAC_ADDR_LEN 3 /* MAC address length */
#define ETHER_PROTO_TYPE_LOC 6 /* Ethernet Proto type location */
#define ARP_HW_TYPE_LEN 1 /* Hardware Type length */
#define ARP_PROTO_TYPE_LEN 1 /* Protocol Type length */
#define ARP_HW_ADD_LEN 1 /* Hardware address length */
#define ARP_PROTO_ADD_LEN 1 /* Protocol address length */
#define ARP_ZEROS_LEN 9 /* Length to be filled with zeros */
#define ARP_REQ_STATUS_LOC 10 /* ARP request location */
#define ARP_REQ_SRC_IP_LOC 14 /* Src IP address location of ARP request */
#define ARP_REQ_DEST_IP_LOC_1 19 /* Destination IP's 1st half word location */
#define ARP_REQ_DEST_IP_LOC_2 20 /* Destination IP's 2nd half word location */
#define IP_VERSION_LEN 1 /* IP Version length */
#define IP_PACKET_LEN 1 /* IP Packet length field */
#define IP_FRAG_FIELD_LEN 1 /* Fragment field len in ICMP packet */
#define IP_TTL_ICM_LEN 1 /* Time to live and ICM fields length */
#define IP_ADDR_LEN 2 /* Size of IP address in half-words */
#define IP_CSUM_LOC_BACK 5 /* IP checksum location from end of frame */
#define IP_HDR_START_LOC 7 /* IP header start location */
#define IP_HDR_LEN 10 /* IP Header length */
#define IP_FRAG_FIELD_LOC 10 /* Fragment field location */
#define ICMP_TYPE_LEN 1 /* ICMP Type length */
#define ICMP_ECHO_FIELD_LEN 2 /* Echo field length in half-words */
#define ICMP_REQ_SRC_IP_LOC 13 /* Src IP address location of ICMP request */
#define ICMP_ECHO_FIELD_LOC 17 /* Echo field location */
#define ICMP_DATA_START_LOC 17 /* Data field start location */
#define ICMP_DATA_LEN 18 /* ICMP data length */
#define ICMP_DATA_LOC 19 /* ICMP data location including
identifier number and sequence number */
#define ICMP_DATA_CSUM_LOC_BACK 19 /* Data checksum location from end of
frame */
#define ICMP_DATA_FIELD_LEN 20 /* Data field length */
/**************************** Type Definitions *******************************/
/***************** Macros (Inline Functions) Definitions *********************/
/************************** Function Prototypes ******************************/
static int EmacLitePingReplyExample(u16 DeviceId);
static void ProcessRecvFrame(XEmacLite *InstancePtr);
static u16 CheckSumCalculation(u16 *RxFramePtr, int StartLoc, int Length);
/************************** Variable Definitions *****************************/
* Set up a local MAC address.
static u8 LocalMacAddr[XEL_MAC_ADDR_SIZE] =
0x00, 0x0A, 0x35, 0x02, 0x22, 0x5E
* The IP address was set to 172.16.63.121. User need to set a free IP address
* based on the network on which this example is to be run.
static u8 LocalIpAddr[IP_ADDR_SIZE] =
172, 16, 63, 121
static XEmacLite EmacLiteInstance; /* Instance of the EmacLite driver */
* Buffers used for Transmission and Reception of Packets. These are declared as
* global so that they are not a part of the stack.
static u8 RxFrame[XEL_MAX_FRAME_SIZE];
static u8 TxFrame[XEL_MAX_FRAME_SIZE];
* Variable used to indicate the length of the received frame.
u32 RecvFrameLength = 0;
* Variable used to indicate the number of Ping replies sent.
u32 NumOfPingReplies;
* This function is the main function of the Ping reply example in
* polled mode.
* @param None.
* @return XST_FAILURE to indicate failure, otherwise XST_SUCCESS
* is returned.
* @note None.
int main()
int Status;
* Run the EmacLite Ping reply example.
Status = EmacLitePingReplyExample(EMAC_DEVICE_ID);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
return XST_SUCCESS;
* The entry point for the EmacLite Ping reply example in polled mode.
* @param DeviceId is device ID of the XEmacLite Device.
* @return XST_FAILURE to indicate failure, otherwise XST_SUCCESS is
* returned.
* @note This is in a continuous loop generating a specified number of
* ping replies as defined by MAX_PING_REPLIES.
int Status;
XEmacLite *EmacLiteInstPtr = &EmacLiteInstance;
XEmacLite_Config *ConfigPtr;
NumOfPingReplies = 0;
* Initialize the EmacLite device.
ConfigPtr = XEmacLite_LookupConfig(DeviceId);
if (ConfigPtr == NULL) {
return XST_FAILURE;
Status = XEmacLite_CfgInitialize(EmacLiteInstPtr,
ConfigPtr,
ConfigPtr->BaseAddress);
return XST_FAILURE;
* Set the MAC address.
XEmacLite_SetMacAddress(EmacLiteInstPtr, LocalMacAddr);
* Empty any existing receive frames.
XEmacLite_FlushReceive(EmacLiteInstPtr);
while (1) {
* Wait for a Receive packet.
while (RecvFrameLength == 0) {
RecvFrameLength = XEmacLite_Recv(EmacLiteInstPtr,
(u8 *)RxFrame);
* Process the Receive frame.
ProcessRecvFrame(EmacLiteInstPtr);
* If the number of ping replies sent is equal to that
* specified by the user then exit out of this loop.
if (NumOfPingReplies == MAX_PING_REPLIES) {
return XST_SUCCESS;
* This function processes the received packet and generates the corresponding
* reply packets.
* @param InstancePtr is a pointer to the instance of the EmacLite.
* @return None.
* @note This function assumes MAC does not strip padding or CRC.
u16 *RxFramePtr;
u16 *TxFramePtr;
u16 *TempPtr;
u16 CheckSum;
u32 NextTxBuffBaseAddr;
int Index;
int PacketType = 0;
TxFramePtr = (u16 *)TxFrame;
RxFramePtr = (u16 *)RxFrame;
* Determine the next expected Tx buffer address.
NextTxBuffBaseAddr = XEmacLite_NextTransmitAddr(InstancePtr);
* Check the packet type.
Index = MAC_ADDR_LEN;
TempPtr = (u16 *)LocalMacAddr;
while (Index--) {
if (Xil_Ntohs((*(RxFramePtr + Index)) == BROADCAST_ADDR) &&
(PacketType != MAC_MATCHED_PACKET)) {
PacketType = BROADCAST_PACKET;
} else if (Xil_Ntohs((*(RxFramePtr + Index)) == *(TempPtr + Index)) &&
(PacketType != BROADCAST_PACKET)) {
PacketType = MAC_MATCHED_PACKET;
} else {
PacketType = 0;
break;
* Process broadcast packet.
if (PacketType == BROADCAST_PACKET) {
* Check for an ARP Packet if so generate a reply.
if (Xil_Ntohs(*(RxFramePtr + ETHER_PROTO_TYPE_LOC)) ==
XEL_ETHER_PROTO_TYPE_ARP) {
* IP address of the local machine.
TempPtr = (u16 *)LocalIpAddr;
* Check destination IP address of the packet with
* local IP address.
if (
((*(RxFramePtr + ARP_REQ_DEST_IP_LOC_1)) == *TempPtr++) &&
((*(RxFramePtr + ARP_REQ_DEST_IP_LOC_2)) == *TempPtr++)) {
* Check ARP packet type(request/reply).
if (Xil_Ntohs(*(RxFramePtr + ARP_REQ_STATUS_LOC)) ==
ARP_REQUEST) {
* Add destination MAC address
* to the reply packet (i.e) source
* address of the received packet.
Index = SRC_MAC_ADDR_LOC;
while (Index < (SRC_MAC_ADDR_LOC +
MAC_ADDR_LEN)) {
*TxFramePtr++ =
*(RxFramePtr + Index);
Index++;
* Add source (local) MAC address
* to the reply packet.
Index = 0;
while (Index < MAC_ADDR_LEN) {
*TxFramePtr++ = *TempPtr++;
Index++;
* Add Ethernet proto type H/W
* type(10/3MBps),H/W address length and
* protocol address len (i.e)same as in
* the received packet
Index = ETHER_PROTO_TYPE_LOC;
while (Index < (ETHER_PROTO_TYPE_LOC +
ETHER_PROTO_TYPE_LEN +
ARP_HW_TYPE_LEN +
ARP_HW_ADD_LEN
+ ARP_PROTO_ADD_LEN)) {
*TxFramePtr++ =
Index++;
* Add ARP reply status to the reply
* packet.
*TxFramePtr++ = Xil_Htons(ARP_REPLY);
* Add local MAC Address
Index = 0;
Index++;
* Add local IP Address
Index = 0;
while (Index < IP_ADDR_LEN) {
*TxFramePtr++ = *TempPtr++ ;
Index++;
* Add Destination MAC Address
* to the reply packet from the received
* packet.
MAC_ADDR_LEN)) {
*TxFramePtr++ =
Index++;
* Add Destination IP Address
Index = ARP_REQ_SRC_IP_LOC;
while (Index < (ARP_REQ_SRC_IP_LOC +
IP_ADDR_LEN)) {
*TxFramePtr++ =
Index++;
* Fill zeros as per protocol.
Index = 0;
while (Index < ARP_ZEROS_LEN) {
*TxFramePtr++ = 0x0000;
Index++;
* Transmit the Reply Packet.
XEmacLite_Send(InstancePtr,
(u8 *)&TxFrame,
ARP_PACKET_SIZE);
* Process packets whose MAC address is matched.
if (PacketType == MAC_MATCHED_PACKET) {
* Check ICMP packet.
XEL_ETHER_PROTO_TYPE_IP) {
* Check the IP header checksum.
CheckSum = CheckSumCalculation(RxFramePtr,
IP_HDR_START_LOC,
IP_HDR_LEN);
* Check the Data field checksum.
if (CheckSum == CORRECT_CKSUM_VALUE) {
ICMP_DATA_START_LOC,
ICMP_DATA_FIELD_LEN);
* Add destination address
* to the reply packet (i.e)source
MAC_ADDR_LEN)) {
*TxFramePtr++ =
Index++;
* Add local MAC address
Index = 0;
Index++;
* Add protocol type
* header length and, packet
* length(60 Bytes) to the reply packet.
IP_VERSION_LEN +
IP_PACKET_LEN)) {
*TxFramePtr++ =
Index++;
* Identification field a random number
* which is set to IDENT_FIELD_VALUE.
*TxFramePtr++ = IDENT_FIELD_VALUE;
* Add fragment type, time to live and
* ICM field. It is same as in the
* received packet.
Index = IP_FRAG_FIELD_LOC;
while (Index < (IP_FRAG_FIELD_LOC +
IP_TTL_ICM_LEN +
IP_FRAG_FIELD_LEN)) {
*TxFramePtr++ =
Index++;
* Checksum first set to 0 and
* added in this field later.
* Add Source IP address
Index = 0;
Index++;
* Add Destination IP address.
Index = ICMP_REQ_SRC_IP_LOC;
while (Index < (ICMP_REQ_SRC_IP_LOC +
IP_ADDR_LEN)) {
*TxFramePtr++ =
Index++;
* Calculate checksum, and
* add it in the appropriate field.
(u16 *)TxFrame,
IP_HDR_START_LOC,
IP_HDR_LEN);
CheckSum = ~CheckSum;
*(TxFramePtr - IP_CSUM_LOC_BACK) =
Xil_Htons(CheckSum);
* Echo reply status & checksum.
Index = ICMP_ECHO_FIELD_LOC;
while (Index < (ICMP_ECHO_FIELD_LOC +
ICMP_ECHO_FIELD_LEN)) {
Index++;
* Add data to buffer which was
* received from the packet.
Index = ICMP_DATA_LOC;
while (Index < (ICMP_DATA_LOC +
ICMP_DATA_LEN)) {
*TxFramePtr++ =
(*(RxFramePtr + Index));
Index++;
* Generate checksum for the data and
(u16 *)TxFrame,
*(TxFramePtr - ICMP_DATA_CSUM_LOC_BACK)
= Xil_Htons(CheckSum);
* Transmit the frame.
(u8 *)&TxFrame,
ICMP_PACKET_SIZE);
* Increment the number of
* Ping replies sent.
NumOfPingReplies++;
* This function calculates the checksum and returns a 16 bit result.
* @param RxFramePtr is a 16 bit pointer for the data to which checksum
* is to be calculated.
* @param StartLoc is the starting location of the data from which the
* checksum has to be calculated.
* @param Length is the number of halfwords(16 bits) to which checksum is
* to be calculated.
* @return It returns a 16 bit checksum value.
* @note This can also be used for calculating checksum. The ones
* complement of this return value will give the final checksum.
u32 Sum = 0;
u16 CheckSum = 0;
int Index;
* Add all the 16 bit data.
Index = StartLoc;
while (Index < (StartLoc + Length)) {
Sum = Sum + Xil_Ntohs(*(RxFramePtr + Index));
Index++;
* Add upper 16 bits to lower 16 bits.
CheckSum = Sum;
Sum = Sum >> 16;
CheckSum = Sum + CheckSum;
return CheckSum;
Вот этот код изначально ругается,что ему чего-то не хватает.
Так и должно быть????? Надо ручками копаться и копировать в рабочий каталог того что не хватает?
