Fixed CCRs: SPB 17.2 HF046
08-24-2018
CCRID Product ProductLevel2 Title
1880800 ADW PART_BROWSER Server connection failure on a running SDA session.
1880895 ADW PART_BROWSER NCB - components missing from the component browser
1962336 ALLEGRO_EDITOR INTERFACES Smart PDF shows both top and bottom probe layers for a film layer with only a single probe layer (top or bottom)
1955128 ALLEGRO_EDITOR MANUFACT Need to close PCB Editor to delete xsectionChart.log generated on placing a cross-section chart
1969088 ALLEGRO_EDITOR SHAPE PCB Editor crashes on updating shapes to smooth
1963828 ASDA DESIGN_EXPLOR Unwired schematic block movement with text is not correct
1954426 ASDA OPEN_CLOSE_PR Double-clicking to paste a note crashes SDA
1965423 ASDA OPEN_CLOSE_PR Crash when working with notes in SDA
1960060 ASDA PART_MANAGER Original property differences not displayed in Part Manager on selecting a new part from CB and doing reset
1960112 ASDA PART_MANAGER Part Manager incorrectly updating part property values
1955723 ASDA ROUTING Draw Multiple Bits misses bit 0 when in reverse order.
1952963 CONCEPT_HDL CORE Variant Editor takes a long time to load
1962568 CONCEPT_HDL CORE Directive DEHDL_BROWSER_FILEPATH does not work
1939192 PCB_LIBRARIAN SYMBOL_EDITOR pin_text size and location very different between DE-HDL and Symbol Editor resulting in text overlap
1952967 SCM OTHER Error while copying a release 17.2-2016 design: message says design created in release 16.3 or an earlier version
1948999 SPIF OTHER Some place_keepout shapes and antipads not exported
08-24-2018
