Cyclone® IV EP4CE22F17C6N FPGA
22,320 Logic elements (LEs)
594 Embedded memory (Kbits)
66 Embedded 18 x 18 multipliers
4 General-purpose PLLs
153 Maximum FPGA I/O pins
Configuration Status and Set-Up Elements
On-board USB-Blaster circuit for programming
FPGA Serial Configuration Device (EPCS)
Expansion Header
Two 40-pin Headers (GPIOs) provides 72 3.3V I/O pins
Two 5V power pins, two 3.3V power pins and four ground pins
One 26-pin header provides 16 3.3V digital I/O pins and 8 analog input pins to connect to analog sensors, etc
Memory Devices
32MB SDRAM
2Kb I2C EEPROM
General User Input/Output
8 green LEDs
2 debounced push-buttons
4 dip switches
G-Sensor
ADI ADXL345, 3-axis accelerometer with high resolution (13-bit)
A/D Converter
NS ADC128S022, 8-Channel, 12-bit A/D Converter
50 ksps to 200 ksps
Clock System
On-board 50MHz clock oscillator
Power Supply
USB Type mini-AB port (5V)
Two DC 5V pins of the GPIO headers (5V)
2-pin external power header (3.6-5.7V)
http://www.terasic.com.tw/cgi-bin/page/arc...93&PartNo=1
Не использовалась, в заводской упаковке.
Подробнее, можно почитать, например, здесь:
http://we.easyelectronics.ru/blog/plis/2458.html
Цена 5000 р.
Лучше писать на почту, можно в личку.
Почта: noaxam@gmail.com
