подозреваю, что какой-то глобальный констрейн нужен, или неправильно включаю
STARTUPE3_inst : STARTUPE3
port map
USRCCLKO => spmo.sck, -- 1-bit input: User CCLK input
CFGCLK => open, -- 1-bit output: Configuration internal oscillator clock output
CFGMCLK => open, -- 1-bit output: Configuration internal oscillator clock output
EOS => open, --rstn_cfg, -- 1-bit output: Active-High output signal indicating the End Of Startup
PREQ => open, -- 1-bit output: PROGRAM request to fabric output
DO => vcc(3 downto 0), -- 4-bit input: Allows control of the D pin output
DI => open, -- 4-bit output: Allow receiving on the D input pin
DTS => gnd(3 downto 0), -- 4-bit input: Allows tristate of the D pin
FCSBO => vcc(0), -- 1-bit input: Controls the FCS_B pin for flash access
FCSBTS => vcc(0), -- 1-bit input: Tristate the FCS_B pin
GSR => gnd(0), -- 1-bit input: Global Set/Reset input (GSR cannot be used for the port)
GTS => gnd(0), -- 1-bit input: Global 3-state input (GTS cannot be used for the port name)
KEYCLEARB => vcc(0), -- 1-bit input: Clear AES Decrypter Key input from Battery-Backed RAM (BBRAM)
PACK => gnd(0), -- 1-bit input: PROGRAM acknowledge input
USRCCLKTS => vcc(0), -- 1-bit input: User CCLK 3-state enable input
USRDONEO => vcc(0), -- 1-bit input: User DONE pin output control
USRDONETS => vcc(0) -- 1-bit input: User DONE 3-state enable output
port map
пример нашел с микроблейзом - там много "мусора" пока не понял, что не так
