Полная версия этой страницы: как снять дамп памяти, регистров и периферии на hardware fault ?
Огурцов
есть мысли ?
aaarrr
Цитата(Огурцов @ Nov 13 2017, 10:33) *
есть мысли ?
А в чем затруднения?
Непомнящий Евгений
В такой постановке вопроса - ИМХО, только через внешний отладчик. Который отловит hard fault и снимет дамп всего проца.
Если осетра урезать - то возможны и другие варианты
dimka76
Я вот так делал, но не для всех регистров.
CODE
// Use the 'naked' attribute so that C stacking is not used.
void HardFault_Handler(void)
* Get the appropriate stack pointer, depending on our mode,
* and use it as the parameter to the C handler. This function
* will never return
__asm( ".syntax unified\n"
"MOVS R0, #4 \n"
"MOV R1, LR \n"
"TST R0, R1 \n"
"BEQ _MSP \n"
"MRS R0, PSP \n"
"B HardFault_HandlerC \n"
"_MSP: \n"
"MRS R0, MSP \n"
".syntax divided\n"
while(1);
* HardFaultHandler_C:
* This is called from the HardFault_HandlerAsm with a pointer the Fault stack
* as the parameter. We can then read the values from the stack and place them
* into local variables for ease of reading.
* We then read the various Fault Status and Address Registers to help decode
* cause of the fault.
* The function ends with a BKPT instruction to force control back into the debugger
__attribute__((naked)) void HardFault_HandlerC(unsigned long *hardfault_args, uint32_t _lr)
volatile unsigned long stacked_r0;
volatile unsigned long stacked_r1;
volatile unsigned long stacked_r2;
volatile unsigned long stacked_r3;
volatile unsigned long stacked_r12;
volatile unsigned long stacked_lr;
volatile unsigned long stacked_pc;
volatile unsigned long stacked_psr;
volatile unsigned long _CFSR;
volatile unsigned long _HFSR;
volatile unsigned long _DFSR;
volatile unsigned long _AFSR;
volatile unsigned long _BFAR;
volatile unsigned long _MMAR;
stacked_r0 = ((unsigned long)hardfault_args[0]);
stacked_r1 = ((unsigned long)hardfault_args[1]);
stacked_r2 = ((unsigned long)hardfault_args[2]);
stacked_r3 = ((unsigned long)hardfault_args[3]);
stacked_r12 = ((unsigned long)hardfault_args[4]);
stacked_lr = ((unsigned long)hardfault_args[5]);
stacked_pc = ((unsigned long)hardfault_args[6]);
stacked_psr = ((unsigned long)hardfault_args[7]);
// Configurable Fault Status Register
// Consists of MMSR, BFSR and UFSR
_CFSR = (*((volatile unsigned long *)(0xE000ED28)));
// Hard Fault Status Register
_HFSR = (*((volatile unsigned long *)(0xE000ED2C)));
// Debug Fault Status Register
_DFSR = (*((volatile unsigned long *)(0xE000ED30)));
// Auxiliary Fault Status Register
_AFSR = (*((volatile unsigned long *)(0xE000ED3C)));
// Read the Fault Address Registers. These may not contain valid values.
// Check BFARVALID/MMARVALID to see if they are valid values
// MemManage Fault Address Register
_MMAR = (*((volatile unsigned long *)(0xE000ED34)));
// Bus Fault Address Register
_BFAR = (*((volatile unsigned long *)(0xE000ED38)));
uint32_t i, j;
uint8_t* p_data = (uint8_t*)hardfault_args;
while ( !(UART_U0LSR & UART_U0LSR_THRE) );
UART_U0THR = _lr & 0xFF;
UART_U0THR = (_lr >> 8) & 0xFF;
UART_U0THR = (_lr >> 16) & 0xFF;
UART_U0THR = (_lr >> 24) & 0xFF;
UART_U0THR = '\r';
UART_U0THR = '\n';
for(i=0; i<8; ++i)
for(j=0; j<4; ++j)
UART_U0THR = *p_data++;
UART_U0THR = '\r';
UART_U0THR = '\n';
UART_U0THR = '\r';
UART_U0THR = '\n';
//__asm("BKPT #0\n"); // Break into the debugger
Огурцов
спасибо, очень хорошо - работает
kolobok0
- писал в память, после перезагрузки - слив на носитель.
1) сохраняется запись о проблемах
2) рестарт МК и выход его на рабочие рельсы.
(круглый)
