Цитата(HardEgor @ May 14 2018, 05:10)
"Чтение даташита вслух - $100/час"
tSETTLING 3-4 μs
Settling time (full scale: for a
12-bit input code transition
between the lowest and the
highest input codes when
DAC_OUT reaches final
value ±1LSB
CLOAD ≤ 50 pF,
RLOAD ≥ 5 kΩ
А я читаю application notes (an 4566) по $200 за штуку.
Table 2 shows the maximum sampling rate for different STM32 products.
Note:Values reported in Table 2 have been measured on the bench, when bus is not used by any other system: in real applications it's necessary to have some margin.
1.5 Summary
By using external high speed OpAmp, it is possible to extend the speed performance of the STM32 DACs more than 1 Msps.
In Section 2 we will provide an example showing how to use this technique on STM32 products.
Table 2. Maximum sampling time for different STM32 microcontrollers
Для
STM32F3 Series 4.5 Msps
Только внутренний буфер надо отключить и приделать внешний.
