Вот кинули на почту, что вышел кейл 2.0.
Список изменений:
[Enhanced Device Simulation and Target Debugging]
Added device simulation and target debugging for the following devices:
Atmel AT91SAM7S128, AT91SAM7S256, AT91SAM7S32, AT91SAM7S64. Projects for Atmel AT91SAM7S Evaluation Board are included in the folder ..\ARM\...\Boards\Atmel\AT91SAM7S.
Philips LPC2131, LPC2132, LPC2138. Projects for Keil MCB2130 Evaluation Board are included in the folder ..\ARM\...\Boards\Keil\MCB2130.
[ULINK - Enhancements + New Features]
Corrected: problem with Big Endian interpretation on Samsung devices (configuration example in GNU\Boards\Samsung\S3C340X).
Added: Philips LPC213x and LPC210x devices are now stopped at RESET. There are no longer issues with lock situations (for example IDLE mode) that disable JTAG.
[Device Support]
Added startup code, example project, and header files for Samsung S3C44B0X (folder ..\ARM\Boards\Samsung\S3C44001\Hello).
Enhanced example projects with configuration for external program memory on Philips LPC2200 (folder ..\ARM\..\Boards\Phytec).
[Keil CARM Compiler]
The Keil CARM Compiler is included as final release. Added is a PACK directive and the __packed attribute that allows definition of byte-aligned variables.
[Keil AARM Macro Assembler]
Corrected: problem with LDR PC,=Reset_Addr (should load address, but not content). Note: check your Startup.S files, since it was part of the startup code in early versions.
[LA Linker/Locater]
Added: ELF/DWARF output file. The linker now generates an ELF/DWARF compatible output file with the extension *.ELF.
[µVision Debugger]
Enhanced: The ELF/DWARF loader has been enhanced and performs now full stack tracking, contains display support for enum types, uses the life-time information for register variables and allows debugging of source code in include files.
[Advanced RTX Real-Time Operating System]
Added: Advanced RTX Kernel including Kernel aware debugging support is now part of the Keil Development Suite for ARM.
Качать можно отсюда: http://www.keil.com/demo/eval/arm.htm
