Цена очень интересная в Украине от 22 у.е.
рабочий код WinAvr Atmega32 7,3728 Мег
// данные на клаву
#define LED_KEY_ZONE_1 15
#define LED_KEY_ZONE_2 14
#define LED_KEY_ZONE_3 13
#define LED_KEY_ZONE_4 12
#define LED_KEY_ZONE_5 7
#define LED_KEY_ZONE_6 6
#define LED_KEY_ZONE_7 5
#define LED_KEY_ZONE_8 4
#define LED_KEY_ACDC 11
#define LED_KEY_MODEM 10
#define LED_KEY_TRABLE 9
#define LED_KEY_BUZZER 8
#define LED_KEY_GUARD_1 3
#define LED_KEY_GUARD_2 2
#define LED_KEY_ALARM_1 1
#define LED_KEY_ALARM_2 0
// Данные от клавы
#define ST_KEY_TAMPER 0
#define ST_KEY_ROW_1 1
#define ST_KEY_ROW_2 2
#define ST_KEY_ROW_3 3
#define ST_KEY_COL_4 4
#define ST_KEY_COL_3 5
#define ST_KEY_COL_2 6
#define ST_KEY_COL_1 7
#define ST_KEY_Z2_OK 8
#define ST_KEY_Z2_KZ 9
#define ST_KEY_Z1_OK 10
#define ST_KEY_Z1_KZ 11
#define ST_KEY_ADR_A 12
#define ST_KEY_ADR_B 13
#define ST_KEY_ADR_C 14
#define ST_KEY_ADR_D 15
#define LED_PORT PORTB
#define LED_DDR DDRB
#define LED_PIN PINB
#define CON_PORT PORTC
#define CON_DDR DDRC
#define CON_PIN PINC
#define MOD_DDR DDRD
#define MOD_PORT PORTD
#define MOD_PIN PIND
#define STON 0x01
#define STOFF 0x00
#define PIN_MODEM (1<<0)
#define PIN_VCC (1<<1)
#define PIN_SOUND (1<<2)
#define PIN_CONTROL (1<<3)
#define PIN_LEDS_1 (1<<4)
#define PIN_LEDS_2 (1<<5)
#define PIN_GROUP_1 (1<<6)
#define PIN_GROUP_2 (1<<7)
#define PIN_LED_CORE (1<<7)
#define PIN_KEY_DATA (1<<0)
#define PIN_KEY_CLK (1<<1)
#define PIN_KEY_IN (1<<2)
#define ON_KEY_CLK LED_PORT &= ~(PIN_KEY_CLK)
#define OFF_KEY_CLK LED_PORT |= (PIN_KEY_CLK)
#define ON_KEY_DATA LED_PORT &= ~(PIN_KEY_DATA)
#define OFF_KEY_DATA LED_PORT |= (PIN_KEY_DATA)
#define IS_KEY_DATA LED_PIN & PIN_KEY_IN
#include <avr\io.h>
#include <avr\interrupt.h>
#include <avr\signal.h>
#include <inttypes.h>
#include <string.h>
#include <stdlib.h>
#include <avr\eeprom.h>
#include <mydef.h>
extern uint8_t out_m_buffer[MODEM_BUFFER];
extern void ModemSend(uint8_t *buf,uint8_t size);
extern uint8_t ReadEE(uint8_t addr); -- чтение eeprom
uint8_t key_data[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // данные для отправки на клаву
uint8_t key_state[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // данные от клавы
uint8_t key_buffer[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // буфер нажатых клавиш
uint8_t table_leds [8] ={15,14,13,12,7,6,5,4};
uint8_t old_key = 'Z';
uint8_t key_data_index = 'Z';
void Init_Key(void);
void Read_Key(void);
void Write_Key(void);
void Work_Key(void);
void delay_key(uint8_t times)
for (uint8_t i = 0;i<times;i++)
asm("nop");
void Init_Key(void) //
OFF_KEY_DATA;ON_KEY_CLK;
for (uint8_t i = 0;i<16;i++)
OFF_KEY_CLK;delay_key(96);
ON_KEY_CLK;delay_key(96);
void Read_Key(void)
ON_KEY_DATA;ON_KEY_CLK;
key_state[i] = ~IS_KEY_DATA;
if (key_data[i] == 0) OFF_KEY_DATA; else ON_KEY_DATA;
void Work_Key(void)
uint8_t inp_key = 'Z';
Read_Key();
Write_Key();
key_data[LED_KEY_BUZZER] = 0;
if (key_state[1])
key_data[LED_KEY_BUZZER] = 1; // ROW 1
if (key_state[7]) inp_key = '1';
if (key_state[6]) inp_key = '4';
if (key_state[5]) inp_key = '7';
if (key_state[4]) inp_key = '*';
if (key_state[2])
key_data[LED_KEY_BUZZER] = 1; // ROW 2
if (key_state[7]) inp_key = '2';
if (key_state[6]) inp_key = '5';
if (key_state[5]) inp_key = '8';
if (key_state[4]) inp_key = '0';
if (key_state[3])
key_data[LED_KEY_BUZZER] = 1; // ROW 3
if (key_state[7]) inp_key = '3';
if (key_state[6]) inp_key = '6';
if (key_state[5]) inp_key = '9';
if (key_state[4]) inp_key = '#';
if (old_key != inp_key)
old_key = inp_key;
if (inp_key !='Z')
key_buffer[key_data_index] = inp_key;
key_data_index ++;
if(key_data_index >15) key_data_index = 0;
if(inp_key == '*') key_data_index = 0; // сброс буфера *
if(inp_key == '#') // конец ввода #
// данные в буфере
memset(Core.Keys.data_buffer,0x00,16);
Core.Keys.data_index = 0;
if (key_state[ST_KEY_TAMPER]) // чтение состояния тампера
if (key_state[ST_KEY_ADR_A]) // чтение состояние адреса A
if (key_state[ST_KEY_ADR_B]) // чтение состояние адреса A
if (key_state[ST_KEY_ADR_C]) // чтение состояние адреса A
if (key_state[ST_KEY_ADR_D]) // чтение состояние адреса A
// Чтение 1 шлейфа
if( key_state[ST_KEY_Z1_OK]) // если 1 то в норме
if( key_state[ST_KEY_Z1_KZ]) // если 1 то короткое замыкание
if( key_state[ST_KEY_Z2_OK]) // Чтение 2 шлейфа
if( key_state[ST_KEY_Z2_KZ])
думаю что пригодится
применение
SIGNAL(SIG_OVERFLOW0)
TCNT0=76; // 25 ms
Work_Key();
int main(void)
TCNT0 = 0x7F; TCCR0 = 0x05; TIMSK|= (1<<TOIE0);
InitKey();
while(1)
