Цитата(yusin @ Oct 15 2008, 06:12)
Well, Mr. Alex190, have you had a chance to review a
SYNERGY team approach to very low noise VCO design even wide tuning range?
Please see attached Ph.D thesis research by Dr. Ulrich L. Rohde and Dr. Ajay Kumar Poddar.
Key points are -SiGe high Ft transistor, varactor tuned coupled microstrip line resonator and push-
push topology (two sub-VCO circuits in symmetrical coupling to half lambda common microstrip line resonator).
"..The measured phase noise show 5-7 dB improvement with respect to the fundamental oscillator sub-circuit...".
By this way it's possible to get very low noise level VCO (mainly like DRO & CRO varactor tuned oscillators have)
but with planar, low cost SMT VCO structure.
IMHO, cavity resonator will be reasonable only for the fixed frequency ( or with bulky mechanical tuning) oscillator for extreme low phase noise.
/Sorry -" poddar_ajay.part1,2,3.rar" - limit to attachment size/
Thank you for the files that you submitted. I am all too good aware of Dr' Rohde work. I don't know what implications may be involved from copying his design, as it is patented. What their work is all about- a very videband fast tuning low noise oscillators to (probably?) directly compete with YIG technology. I have also read an article of Matjas Widmar, in which a 2-4.2GHz instantaneous bandwidth unit was produced actually in home laboratory. Its phase noise is not as good as in Dr' Rohde design, but the design is FREE. I mostly seek a DRO replacement, so my case is very simple, relatively. I only need enouth tuning range of the Varactor to compensate for the cavity drift with temperature. Extreme low noise in very narroband cavity oscillators you say? Thats my goal!
Цитата(khach @ Oct 15 2008, 00:43)
Для регулировки связи генератора с резонатором есть старое проверенное решение из техниеи ЭПР спектроскопии- в отверстии связи (щели) делалось перпендикулярное отверстие с резьбой, в которое вкручивался винт из тефлона. Вкручивая- выкручивая винт можно было плавно регулировать связь в широком диапазоне.
А как планируется варикап подключать? Несовсем понятно на чертеже платы как расположены земляные полигоны, можно ли детализировать?
Вот кстати фотки промышленного генератора диапазона 2-3 ГГц с механической перестройкой и на транзисторе (он лежит на дне резонатора). Так же виден варикап (слева) и петля связи выхода (справа). Перестройка механическая, движением диэлектрической втулки с помощью микрометрического винта.
Thank you for the photo. An electrically floating coaxial center line is a very odd approach, which will be prone to vibration and general mechanical instsability. How do i plan to connect the varicap? In the design you seen- by a probe and into the peak of electric field (thats near the top of the center resonator pole, with an etched opening in the PCB gnd plane). If the oscillator will turn out as a succesful design i think about another slot loaded microstrip just for the varicap. Or a turning platform with a magnetic loop loaded by the varicap. I imagine that the beauty of this approach is that by mechanically turning the loop insert, you will control the exact coupling of the varicap to the cavity, so to reduce phase noise to a minimum. The screw tuning of the slot coupling is also a very nice idea. Just need to figure out how to design it mechanically... And i would think that the screw should be metallic, not teflon. What is EPR? Regarding the gnd planes in my try - all the bottom side is filled with a solid copper plane with a small etched slot when indicated.
Цитата(AlexKLm @ Oct 16 2008, 19:37)
Не нашёл я генератор, вспоминал конструкцию и пришла на ум несколько другая, возможно она будет работать, я надеюсь. Вот рисунок.
Thank you for the pictures. It looks like a Colpits -R cell (capacitor on emmiter with Cbe working as the second capacitor) with the cavity coupled EXACTLY as i trying to do. Too bad you did not tried it.... By the way, in equivalent circuit, the resonator (the cavity) should have been represented as TRANSFORMER coupled to the Base and not by 3 "solder" joints. The varicap should be drawn also as a winding on this transformer loaded by the varicap to gnd. The M factors (the magnetic coupling like in normal transformers) are a function of the slot position ALONG the resonator length. L1 is very important as it prevents the emmiter resistor from loading the -R too much. So it is better not be ommited. The big difference between our designs are two:
1. I use "common base"- actually inductor from base to GND to push a low frequency RF transistor as high as possible (for phase noise reasons). This creates a -G instead of -R.
2. I do not like to couple the varicap as the transistor, means, use the same slot. My goal is to couple the varicap just enouth to be able to phase-lock the oscillator across wide temperature range. So in my opinion, the varicap should be located at a different spot.
