Hello!
I have a problem with programming Infineon XC16x devices on-chip flash.
There is two connected into JTAG chain XC164CS-32F40 chips on my board. When I try to program 1st device in the chain, it appears an error:
"mVision3. Error: Flash download failed: target DLL has been cancelled". Then, when I try to program 2nd device in the chain, it appears another error:
"UL2OCDS Driver ERROR. This OCDS revision is currently not supported. Please check for a newer UL2OCDS.DLL driver or contact the Keil support team" and then after pressing OK button: "mVision3. Error: Flash download failed: target DLL has been cancelled".
Jtag-chain connections as in topic "Chaining multiple JTAG devices" in "mVision3 Users Guide").
I tryed to program devices with downloaded uVision v3.67 (C166 v6.17) from www.keil.com with UL2OCDS.DLL v1.22 but situation did not changed (same errors). Same result with chaining two Easy Kit XC164CS v3.2.
When I program stand-alone devices there is no any problems.
What I have to do to make possible programming in JTAG chain?
