Цитата(oleg-n @ Jul 17 2013, 12:51)
Так в чем же отличие ??
Откройте справку на разделе Using Real-TIme DFA Analysis.
CODE
Adoption Considerations
The DFA application is not considered "use out of the box" technology.
Adoption, especially with larger companies, requires some planning
between CAD and manufacturing groups. When considering the DFA
application, a review of your package symbol placebound shapes against
the clearance parameters is necessary. Questions to consider:
Are your current placebound shapes drawn tightly around the package
extents not accounting for clearance requirements to other packages? If
so, you may not require migration to the new DFA placebound shape.
Are your current placebound shapes drawn outside the extents of the pins
or assembly outline to account for clearance requirements? If so,
Cadence recommends incorporating the new DFA placebound shape that can
be automatically generated with the utility, dfa_update.
Figure 1пїЅ1пїЅ Compact placebound geometry (l) and extended placebound ®
Legacy placebound shapes may be drawn to include the space required for
rudimentary clearance checking and may not integrate well with DFA
spreadsheet-driven rules. Although the DFA checker reverts to the legacy
placebound shape if a dfa_placebound shape is not found, it is estimated
this model is inaccurate for many companies as it lacks precision due to
the static nature of a single placebound shape for multiple combinations
of clearance requirements. Customers are cautioned to sample the output
of dfa_update to ensure conformance with their package spacing guidelines.
Может я не правильно выбираю слой куда скопировать этот прилипший слой? Допустим у меня после команды Zcopy прилип слой place bound (был открыт слой TOP) что мне делать в этот момент ..куда нажать если я хочу на слой BOT вставить и цвет поменять на противоположный!?
Ничего не должно прилипать. Команда применяется к объектам, отмеченным на панели Find. Копирование происходит в слой, указанный на панели Options. О какой смене цветов Вы говорите? Смена цветов и копирование - разные вещи. Чтобы компонент на плате нормально переворачивался, не надо ничего рисовать в дополнительных слоях. Опять же, почитайте справку. Слои с суффиксами _TOP и _BOTTOM автоматически располагаются там, где надо при переносе компонента операцией Mirror.
