Список того что в этой библиотеке.
CODE
CSV text has been written to file : DIGITAL_BOARD_INTERFACE.csv
Library Component Count : 67
Name Description
10SC10M CAP ELECT OS-CON SC 10uf / 10v
10SC22M CAP ELECT OS-CON SC 22uf / 10v
16SA470M CAP ELECT OS-CON SA 470uf / 16v
73391-0070 CONN JACK SMA STR 50 OHM PCB
74ABT02D IC QUAD 2-IN NOR GATE 14-SOIC
74ABT02D_1 IC QUAD 2-IN NOR GATE 14-SOIC
74ABT04D IC INVERTER HEX 14SOIC
74ABT04D_1 IC INVERTER HEX 14SOIC
74ABT74D IC FLIP FLOP DUAL D OCTAL 14SOIC
74ABT74D_1 IC FLIP FLOP DUAL D OCTAL 14SOIC
74AHC1G79GV IC D F-F POS-EDGE TRIG SC74A-5
AD586KR IC PREC VOLT REF 5V 8-SOIC
ADG719BRTZ IC SWITCH SPDT SOT23-6
ADM1485AR IC TX/RX RS-485 HS 5V 8SOIC
ADM708ARZ IC SUPERVISOR MPU 4.4 WD 8SOIC
ADUM1100ARZ IC DIGITAL ISOL/COUPLER 8-SOIC
APT1608CGCK LED 1.6X0.8MM 570NM GRN CLR SMD
APT1608EC LED 1.6X0.8MM 625NM RED CLR SMD
APT1608PBC/A LED 1.6X0.8MM 470NM BLUE CLR SMD
BLM21PG221SN1D FERRITE CHIP 220 OHM 2000MA 0805
BLM31PG601SN1L FERRITE CHIP 600 OHM 1500MA 1206
DIR9001IPWQ1 IC DGTL AUDIO INTFC RCVR 28TSSOP
DIT4192IPW IC DIG AUDIO TRANSMTR 5V 28TSSOP
ECS-120-20-5PDN-TR CRYSTAL 12.000 MHZ 20PF CSM-7
ED555/2DS TERMINAL BLOCK 3.5MM 2POS PCB
EPM3256ATC144-10 IC MAX 3000A CPLD 256 144-TQFP
GCM1885C2A220JA16D CAP CER 22PF 100V C0G 0603
GCM21B5C1H223JA16L CAP CER 22000PF 50V C0G 5% 0805
GRM21BR71H105KA12L CAP CER 1UF 50V X7R 0805
GRM21BR71H473KA01L CAP CER 47000PF 50V 10% X7R 0805
GRM21BR71H683KA01L CAP CER 68000PF 50V 10% X7R 0805
GXO-U100H\A 24.57600MHzGXO-U100H\A 24.57600MHz
GXO-U100H\A 33.8688MHzGXO-U100H\A 33.8688MHz
Header 13X2 Header, 13-Pin, Dual row
Header 14X2 Header, 14-Pin, Dual row
Header 2 Header, 2-Pin
Header 2X2 Header, 2-Pin, Dual row
Header 3X2 Header, 3-Pin, Dual row
Header 4X2 Header, 4-Pin, Dual row
Header 5X2 Header, 5-Pin, Dual row
Header 7X2 Header, 7-Pin, Dual row
Header 8X2 Header, 8-Pin, Dual row
ISO150AU IC BI-DIR DIGTL CUPLR 28-SOIC
LM1117DT-3.3 800mA Low-Dropout Linear Regulator
LM1117DT-5.0 800mA Low-Dropout Linear Regulator
LM1117T-5.0 IC REG LDO 800MA 5.0V TO-220
MMA02040C2001FB300 RES 2.0K OHM .4W 1% 0204 MELF
MMA02040C2209FB300 RES 22 OHM .4W 1% 0204 MELF
MMA02040C4708FB300 RES 4.7 OHM .4W 1% 0204 MELF
MMA02040C7509FB300 RES 75 OHM .4W 1% 0204 MELF
MMB02070C4708FB200 RES 4.7 OHM 1W 1% 0207 MELF
PCM2704DB IC STEREO AUD DAC W/USB 28-SSOP
PE-65612NL AUDIO TRANS 1:1 2000VRMS
RC0603FR-07100RL RES 100 OHM 1/10W 1% 0603 SMD
RC0603FR-0710KL RES 10.0K OHM 1/10W 1% 0603 SMD
RC0603FR-071K5L RES 1.50K OHM 1/10W 1% 0603 SMD
RC0603FR-071ML RES 1.00M OHM 1/10W 1% 0603 SMD
RC0603FR-0747KL RES 47.0K OHM 1/10W 1% 0603 SMD
RC0603FR-0751RL RES 51.0 OHM 1/10W 1% 0603 SMD
RC0603FR-07680RL RES 680 OHM 1/10W 1% 0603 SMD
RC0603FR-076K2L RES 6.20K OHM 1/10W 1% 0603 SMD
SM5842AP High-Class Audio Multi-function Digital Filter
SN74AHC1G125DBVR IC BUS BUFF TRI-ST N-INV SOT235
SRC4192IDB IC 192KHZ SAMPL RATE CONV 28SSOP
TMMBAT41FILM DIODE SCHTKY 100MA 100V MINIMELF
UKZ1E221MHM CAP ELECT 220UF 25V AUDIO SNAP
UKZ1E470MPM CAP ELECT 47UF 25V AUDIO SNAP
еще можно сделать каталог в виде документа, там будут и посадочные места и все все все)))
