2sysel
первый пункт сделал
второй пункт сделал
третий я не понял как сделать. поясните плз.
у меня есть два файла icf
LPC1768_RAM.icf
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x00000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0x00000100;
define symbol __ICFEDIT_region_ROM_end__ = 0x00007FFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x10000000;
define symbol __ICFEDIT_region_RAM_end__ = 0x10007FFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x800;
define symbol __ICFEDIT_size_heap__ = 0x400;
/**** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
define region ROM_region = mem:[from __ICFEDIT_region_ROM_start__ to __ICFEDIT_region_ROM_end__];
define region RAM_region = mem:[from __ICFEDIT_region_RAM_start__ to __ICFEDIT_region_RAM_end__];
define symbol _AHB_RAM_start__ = 0x2007C000;
define symbol _AHB_RAM_end__ = 0x20083FFF;
define region AHB_RAM_region = mem:[from _AHB_RAM_start__ to _AHB_RAM_end__];
define block CSTACK with alignment = 8, size = __ICFEDIT_size_cstack__ { };
define block HEAP with alignment = 8, size = __ICFEDIT_size_heap__ { };
initialize by copy { readwrite };
do not initialize { section .noinit };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
place in RAM_region { readonly };
place in RAM_region { readwrite,
block CSTACK, block HEAP };
place in AHB_RAM_region
{ readwrite data section AHB_RAM_MEMORY };
LPC1768_flash.icf
/*-Specials-*/
define symbol __ICFEDIT_region_ROM_end__ = 0x0007FFFF;
/*-Sizes-*/
do not initialize { section USB_DMA_RAM };
place in ROM_region { readonly };
{ readwrite data section AHB_RAM_MEMORY, section USB_DMA_RAM, section EMAC_DMA_RAM};
в этих вайлах вижу AHB но не могу найти в програматоре
четвертый сделал(был один макрос с ram
содержимое этого макроса
execUserReset()
__writeMemory32(0x10000000, 0xE000ED08, "Memory"); //Vector table remap at 0x10000000
execUserPreload()
пятый пукт сделал.
пишет что "writing outside flash memory at address 0x10000000"
The debugging sesion could not be started.
either the debugger initilization falied? or else the file "D:\.....\RAM Debug\Exe\uart.out" was corrupt or of an unsupported format.
There might be more information in the Debug Log window
log
Wed Sep 22 10:41:01 2010: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\NXP\LPC17xx.mac
Wed Sep 22 10:41:01 2010: ------- Prepare for flashloader -------
Wed Sep 22 10:41:02 2010: 1224 bytes downloaded and verified (0.26 Kbytes/sec)
Wed Sep 22 10:41:02 2010: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\NXP\FlashLayout1RAM32K_Cortex.out
Wed Sep 22 10:41:02 2010: Target reset
Wed Sep 22 10:41:02 2010: Writing outside flash memory at address 0x10000000
еще вопрос. когда я просто в отладчике при выполнении программы нажимаю ресет она снова заходит в маин но потом вылетает в
Default_Handler
B Default_Handler
END
причем начал по шагам и натыкаюсь на то что код меняется в строчке до ресета все нормально после ресета какая то белеберда именно в в одной сточке.
рисунки приведены ниже
воообще все просто оказалось!!!!!!
