Необходимо чтобы в проекте была доступна вся SD-RAM начиная с адреса 0x20000000. Проект грузится изпод U-boot в адрес 0x20000000 и ему передаётся управление.
Единственнаое место где упоминается SD-RAM в проекте:
/// Initialize and configure the SDRAM
void BOARD_ConfigureSdram(unsigned char busWidth)
volatile unsigned int i;
static const Pin pinsSdram = PINS_SDRAM;
volatile unsigned int *pSdram = (unsigned int *) AT91C_EBI_SDRAM;
unsigned short sdrc_dbw = AT91C_SDRAMC_DBW_16_BITS;;
unsigned int tmp = 0;
busWidth = 16;
// Enable corresponding PIOs
PIO_Configure(&pinsSdram, 1);
// Enable EBI chip select for the SDRAM, VDDIOMSEL set: memories are 3.3V powered
tmp = READ(AT91C_BASE_MATRIX, MATRIX_EBI) | AT91C_MATRIX_CS1A_SDRAMC;
WRITE(AT91C_BASE_MATRIX, MATRIX_EBI, tmp);
// CFG Control Register
WRITE(AT91C_BASE_SDRAMC, SDRAMC_CR, AT91C_SDRAMC_NC_9
| AT91C_SDRAMC_NR_13
| AT91C_SDRAMC_CAS_2
| AT91C_SDRAMC_NB_4_BANKS
| sdrc_dbw
| AT91C_SDRAMC_TWR_2
| AT91C_SDRAMC_TRC_7
| AT91C_SDRAMC_TRP_2
| AT91C_SDRAMC_TRCD_2
| AT91C_SDRAMC_TRAS_5
| AT91C_SDRAMC_TXSR_8);
for (i = 0; i < 1000; i++);
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_NOP_CMD); // Perform NOP
pSdram[0] = 0x00000000;
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_PRCGALL_CMD); // Set PRCHG AL
pSdram[0] = 0x00000000; // Perform PRCHG
for (i = 0; i < 10000; i++);
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 1st CBR
pSdram[1] = 0x00000001; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 2 CBR
pSdram[2] = 0x00000002; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 3 CBR
pSdram[3] = 0x00000003; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 4 CBR
pSdram[4] = 0x00000004; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 5 CBR
pSdram[5] = 0x00000005; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 6 CBR
pSdram[6] = 0x00000006; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 7 CBR
pSdram[7] = 0x00000007; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_RFSH_CMD); // Set 8 CBR
pSdram[8] = 0x00000008; // Perform CBR
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_LMR_CMD); // Set LMR operation
pSdram[9] = 0xcafedede; // Perform LMR burst=1, lat=2
WRITE(AT91C_BASE_SDRAMC, SDRAMC_TR, (BOARD_MCK * 7) / 1000000); // Set Refresh Timer
WRITE(AT91C_BASE_SDRAMC, SDRAMC_MR, AT91C_SDRAMC_MODE_NORMAL_CMD); // Set Normal mode
pSdram[0] = 0x00000000; // Perform Normal mode
Эта функция определена в файле board memory.c и больше нигде не упоминается...
Я чайник полный, пока что. Но когда гружу проект через U-boot в SD-Ram, то мне пишет
Zero length ???
## Starting application at 0x20000000 ... и висит...
а должон выдавать в консоль сообщение об удачном старте....
а проект-то по сути простой (мигалка), но запустить что-то никак не получается...
