switch (UartIntId & 0xF)
case UART_RX_ERROR_INTERRUPT_ID: // Receive Line Status
case UART_RX_TIMEOUT_INTERRUPT_ID: // Character Time-out Indicator
case UART_RX_TRIGGER_INTERRUPT_ID: // Receive Data Available
// Read the line state of the UART
tmp = regs->LSR;
do
if(tmp & UART_LSR_OE)
// Overrun Error
pUartInfo->Data.UartStatus.overrun = 1;
if (tmp & UART_LSR_BI)
// Break Indicator
pUartInfo->Data.UartStatus.break_ind = 1;
else if (tmp & UART_LSR_FE)
// Framing Error
pUartInfo->Data.UartStatus.framing=1;
else if (tmp & UART_LSR_PE)
// Parity Error
pUartInfo->Data.UartStatus.parity = 1;
// Push a new data into the receiver buffer
if(ISRRxFreeSize()>0)
Data = regs->RBR;
PutRxByte(Data);
else
pUartInfo->Data.UartStatus.overflow = 1;
break;
tmp = regs->LSR;
while(tmp & UART_LSR_RDR); // Is the hardware FIFO is empty?
VICADDRESS=0; //reset VIC
return;
tmp = regs->LSR;
do
// Overrun Error
// Break Indicator
// Framing Error
// Parity Error
Data = regs->RBR;
PutRxByte(Data);
else
break;
tmp = regs->LSR;
return;
Что не так делаю, подскажите?
