Продам Осциллограф Tektronix TDS640A
С опциями:
1F - дисковод,
2F - БПФ - вычисление спектра и другие дополнительные функции.
Цена 35 т.р.
Tektronix TDS640A Oscilloscope, Digital: 500MHz,2GSa/s,4ch (Stand alone)
The Tektronix TDS640A oscilloscope is a graph-displaying device – it draws a graph of an electrical signal. In most applications, the graph shows how signals change over time: the vertical (Y) axis represents voltage and the horizontal (X) axis represents time. The intensity or brightness of the display is sometimes called the Z axis.
The Tektronix TDS640A oscilloscope's simple graph can tell you many things about a signal, such as: the time and voltage values of a signal, the frequency of an oscillating signal, the “moving parts” of a circuit represented by the signal, the frequency with which a particular portion of the signal is occurring relative to, other portions, whether or not a malfunctioning component is distorting the signal, how much of a signal is direct current (DC) or alternating current (AC) and how much of the signal is noise and whether the noise is changing with time.
Performance Characteristics of the TDS640A
Form Factor Benchtop
Bandwidth 500 MHz
Number of Channels 4 ch
Simultaneous Channels 4 ch
Simultaneous Maximum Sampling Rate/ch 2 GSa/s
One ch. only max. sampling rate 2 GSa/s
Max. Single Shot bandwidth 2 GHz
Max. Record Length 2000 pt/sec
Min. Vertical Sensitivity 1 mV/div
Maximum Vertical Sensitivity 10 V/div
Rise time 700 ps
Number of Bits 8 bits
Input Impedance 1 MOhm
Input Impedance (alternate) 50 Ohm
Input Coupling AC,DC,GND
Maximum Input Voltage 400 Vrms
Main time base - lowest 500 ps/div
Main time base - highest 10 s/div
Timebase accuracy 0.1 %
Trigger Source External,Internal
Trigger Modes Auto,Edge,Normal,Pulse,Single
Display Type CRT Monochrome
Display Size 17.78 cm
Display modes Dot,Vector
