Atmel AT91SAM9263, Первая информация по новому камню |
Jul 12 2006, 21:58
Из: Moscow
Пользователь №: 554
Processor Clock, PCK up to 200Mhz
- 220 MIPS at 200 MHz (1.1 Mips/Mhz)
Master Clock , MCK up to 100Mhz
80 Kbytes of FAST Internal SRAM
- Single access at MCK speed - Supports ARM926 TCM interfaces
16 Kbytes of FAST Internal SRAM
128 Kbytes of Internal ROM
- Dedicated Boot code: SAM Boot - Single access at MCK speed
32-bit SDRAM Memory support
16-bit Static Memory, NAND Flash, Compact
BGA-324 package
16-KByte Data Cache, 16-KByte Instruction Cache
ARM V5TEJ architecture
ARM Jazelle : Java byte code acceleration achieved by hardware
DSP enhancement:
- Multiply instructions using a single-cycle 32*16 implementation - Multiply or Multiply Accumulate (MAC) instructions - Pipeline allows one multiply to start each cycle
Memory Management Unit (MMU)
Tightly-Coupled Memory (TCM):
- Separate interface for Instruction and Data - Single access at Processor Speed
JTAG ICE support
Dual External Bus Interface (EBI0 and EBI1) frequency: up to 100Mhz
Mobile SDRAM support through the embedded SDRAM Controller
- Deep Power Down Mode support - Partial array self-refresh and others Mobile SDRAM features
8-bit, 16-bit NAND Flash support through NAND Flash glue-logic
Compact Flash support through Compact Flash glue-logic (EBI1 only)
- Compact Flash access on SMC NCS4 and/or NCS5 - True IDE mode allows HDD devices access
2D Graphics Accelerator
- Line Draw, Block Transfer, Polygon fill, Clipping, Commands Queing
LCD Controller
- Supports Passive or Active Displays - Up to 24-bit per pixel in TFT Mode, Up to 16-bit per pixel in STN color Mode - Up to 16M Colors in TFT Mode, Resolution up to 2048x2048, supports wider screen buffers - Virtual screen support
Image Sensor Interface
- ITU-R BT. 601/656 External Interface, programmable frame capture rate - 12-bit data interface for support of highly sensitive sensors - SAV and EAV synchronization, preview path with scaler, YCbCr format
One AC97 Controller (AC97C)
- 6-channels Single AC97 Analog Front end Interface, Slot Assigner
One Part 2.0A and Part 2.0B compliant CAN Controller
- 16 fully-programmable Message Object Mailboxes, 16-bit time stamp counter
One Four-channel 16-bit PWM Controller (PWMC)
2-ch DMA controller
- Single or Multi-block transfers - Block chaining using linked list - Auto-reloading - Hardware handshaking
Engineering samples : Sept'06
Production : 1Q07
Summary Datasheet : July'06
Full Datasheet : July'06
Development board : Oct'06
Jul 13 2006, 14:13
Пользователь №: 12 999
А можно и мне на zrs_alex@mail.ru А то доступа к FTP нет, а камень интересный...
Jul 6 2007, 04:27
Пользователь №: 25 325
А Вы Errata читали, то не работает, другое не работает (Самое обидное, что Polygon fill function в 2D Graphic Controller на работает и решений нет) и эта Errata от 1.06.07, тоесть исправят не скоро. Сыроват пока булыжник.  Сам хочу на таком что нибудь собрать, но как такую дуру развести. Ни каждая организация берется такие тонкие дорожки и переходы вытравить. Даже не знаю что сложнее будет: припаять BGA или вытравить.
Сообщение отредактировал Ivan. - Jul 6 2007, 04:35
Я могу ВСЁ, вопрос, сколько времени у меня это займет.
