169 страниц V  « < 160 161 162 163 164 > »
sergei94
сообщение Mar 19 2017, 09:58
Сообщение #2416
Пользователь №: 91 904
Цитата(Aner @ Mar 19 2017, 10:51) *
And if you look at the description, from CST, how to set the port. Well, or go to yutube ...
Hello aner, i have tried many ideas, the first is to use a multipin discrete port where the grounds are minus and the middle part is +,because a stripline and a coax are the same principle.
all what i find on the web where partial description which i am not sure if i got them coorectly
if you could please show in two photos the setting of such a port so we will have a visual example,there is not YOUTUBE manual about stripline unfortunetly.
Thanks
enom
сообщение Mar 20 2017, 06:41
Сообщение #2417
Из: Королёв, Моск.обл.
Пользователь №: 60 575
Цитата(sergei94 @ Mar 19 2017, 10:11) *
Hello, in my multisection coupler structure i have a port shown as bellow(strip-line port) i have selected all three faces of the port and pressed ,"waveguide port" and i got the following window, what to do now , how to define in so i will get it functioning as a stripline port?
or do i need to define it as a desrete port, then how do you suggest to do that?
i am not sure regarding this final step
Thanks
Не надо ничего делать. Порт вполне корректно определился
APEHDATOP
сообщение Mar 22 2017, 06:55
Сообщение #2418
Пользователь №: 40 417
Я так понимаю CST® Filter Designer 3D работает не в полном объёме с FEATURES lines предложенными F5BJR на http://maintracker.org/forum/viewtopic.php?t=5373753 ??? Не могу увидеть 3D модель crying.gif help.gif
sergei94
сообщение Mar 22 2017, 09:34
Сообщение #2419
Hello , i have used 4 different script files to construct my antenna.
but if i save and exit the project then when i reopen the project then the "dicrete ports" dissapear,
or if i put my antenna inside a PEC box and change one parameter then the whole script built structure dissapears.
what needs to be done in order to keep the objects which were built by scripts from dissapearing?
Thanks.
APEHDATOP
сообщение Mar 23 2017, 07:05
Сообщение #2420
StasExR
сообщение Mar 30 2017, 08:22
Сообщение #2421
Из: Украина
Пользователь №: 36 680
Кто-нибудь сталкивался с ограничением на запуск постпроцессинга на удаленных машинах при качании параметров или оптимизации? У меня пишет: "Remote postprocessing is disallowed for this project by frontend."
EVO_X
сообщение May 3 2017, 13:32
Сообщение #2422
Пользователь №: 96 874
Всем привет!
Подскажите, можно ли снимать S-параметры не по напряжению, а по мощности?
Redcrusader
сообщение May 4 2017, 03:53
Сообщение #2423
Пользователь №: 86 252
Цитата(EVO_X @ May 3 2017, 19:32) *
....можно ли снимать S-параметры не по напряжению, а по мощности?
Скорее всего, нет.
Т.к. S-параметры это отношение падающего и отраженного напряжений (проходящего напряжения).
И зависит от сопротивления тракта измерения S-параметров.
А формулу P = (U^2)/2R никто не отменял!
EVO_X
сообщение May 4 2017, 04:18
Сообщение #2424
Ну чтобы считать по формуле, нужно брать точки на спектрах s-параметров,и перичитывать, поэтому рассчет получается не такой точный.
Grizzzly
сообщение May 4 2017, 19:06
Сообщение #2425
Пользователь №: 75 748
Экспортируйте в файл результаты, а дальше в любом математическом пакете по формуле получите точные значения.
EVO_X
сообщение May 5 2017, 14:00
Сообщение #2426
подскажите, пожалуйста, как экспортировать их оттуда
aaa-aaa
сообщение May 10 2017, 12:27
Сообщение #2427
Пользователь №: 93 556
Добрый день,
не сталкивался ли кто с установкой аппаратного ускорителя Xeon Phi? Не могу понять, почему при проверке корректности установки аппаратного ускорителя, утилита HWAccDiagnostics AMD64.exe сообщает следующую ошибку: Intel MPSS Driver Version (expected 3.4.32795.0 or 3.4.34161.2 or 3.4.35999.3 ): 3.4.34161.2. Хотя версия драйверов для карты ускорителя установлена подходящая.
Tema-yes
сообщение May 11 2017, 12:07
Сообщение #2428
Пользователь №: 71 170
Вот так
 Уменьшено до 68%
528 x 328 (36.09 килобайт)
формат csv или s*p
Tema-yes
сообщение May 11 2017, 13:17
Сообщение #2429
Добрый день!
Кто-нибудь сталкивался с задачей моделирования антенны перед некой металлической структурой?
Задача следующая, есть АФАР 20х20 и есть некая металлическая конструкция перед ней. Интересует как исказиться ДН и какая мощность прилетит обратно, будет наведена на каждом отдельном излучателе.
В голову приходит моделирование отдельно излучателя, пересчет в антенную решетку, экспорт ДН и дальнейшее моделирование металлической структуры облученной этой ДН (в качестве источника) интегральным решателем. Полагаю что полученной ДН верить можно, а вот как обстоят дела с S параметром в этом случае, насколько он правдив и как получить мощность на отдельном излучателе, это пока что под вопросом.
Может у кого-то есть идеи?
Denis_ll
сообщение May 23 2017, 08:30
Сообщение #2430
Пользователь №: 97 230
Помогите разобраться с диполем Герца!
Начал осваивать CST 2016 на примере модели полуволновой антенны Герца.
Скачал книжку: Frank Gustrau · DirkManteuffel EM Modeling of Antennas and RF Components forWireless Communication Systems (может кому будет полезно - владываю PDF)
Пытаюсь повторить картинку успользуя TDSolver:
Параметры взяты из другого раздела книжки:
L =150мм
diam=5мм
g =5мм
PEC
Я сделал так:
Open(add space) = Lambda/4 1E-6
Вокруг воздух
Частоты почти получились, но РЕАЛЬНАЯ ЧАСТЬ Z УПОРНО СТРЕМИТСЯ К БЕСКОНЕЧНОСТИ близи нуля частот, а не как на рисунке стремится в НУЛЬ.
С идеями, что же у меня пошло не так пока кризис!
-Кстати, что для цилиндра обозначает параметр Segments?
По умолчанию он равен нулю и все считается быстро, если сделать скажем 100, то считается гораздо медленнее и чуть смещаются частоты на S11.
6 чел. читают эту тему (гостей: 6, скрытых пользователей: 0)
RSS Текстовая версия Сейчас: 5th August 2025 - 21:04
Страница сгенерированна за 0.01714 секунд с 7
