> Внешнее програмирование флеш.
Jenya7
сообщение May 16 2017, 09:00
Пользователь №: 71 075
Я подключил к проекту Altera On-Chip Flash и он создал мне компонент
component flash_update is
        port (
            clock                   : in  std_logic                     := 'X';             -- clk
            avmm_csr_addr           : in  std_logic                     := 'X';             -- address
            avmm_csr_read           : in  std_logic                     := 'X';             -- read
            avmm_csr_writedata      : in  std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
            avmm_csr_write          : in  std_logic                     := 'X';             -- write
            avmm_csr_readdata       : out std_logic_vector(31 downto 0);                    -- readdata
            avmm_data_addr          : in  std_logic_vector(18 downto 0) := (others => 'X'); -- address
            avmm_data_read          : in  std_logic                     := 'X';             -- read
            avmm_data_writedata     : in  std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
            avmm_data_write         : in  std_logic                     := 'X';             -- write
            avmm_data_readdata      : out std_logic_vector(31 downto 0);                    -- readdata
            avmm_data_waitrequest   : out std_logic;                                        -- waitrequest
            avmm_data_readdatavalid : out std_logic;                                        -- readdatavalid
            avmm_data_burstcount    : in  std_logic_vector(3 downto 0)  := (others => 'X'); -- burstcount
            reset_n                 : in  std_logic                     := 'X'              -- reset_n
    end component flash_update;
    u0 : component flash_update
        port map (
            clock                   => CONNECTED_TO_clock,                   --    clk.clk
            avmm_csr_addr           => CONNECTED_TO_avmm_csr_addr,           --    csr.address
            avmm_csr_read           => CONNECTED_TO_avmm_csr_read,           --       .read
            avmm_csr_writedata      => CONNECTED_TO_avmm_csr_writedata,      --       .writedata
            avmm_csr_write          => CONNECTED_TO_avmm_csr_write,          --       .write
            avmm_csr_readdata       => CONNECTED_TO_avmm_csr_readdata,       --       .readdata
            avmm_data_addr          => CONNECTED_TO_avmm_data_addr,          --   data.address
            avmm_data_read          => CONNECTED_TO_avmm_data_read,          --       .read
            avmm_data_writedata     => CONNECTED_TO_avmm_data_writedata,     --       .writedata
            avmm_data_write         => CONNECTED_TO_avmm_data_write,         --       .write
            avmm_data_readdata      => CONNECTED_TO_avmm_data_readdata,      --       .readdata
            avmm_data_waitrequest   => CONNECTED_TO_avmm_data_waitrequest,   --       .waitrequest
            avmm_data_readdatavalid => CONNECTED_TO_avmm_data_readdatavalid, --       .readdatavalid
            avmm_data_burstcount    => CONNECTED_TO_avmm_data_burstcount,    --       .burstcount
            reset_n                 => CONNECTED_TO_reset_n                  -- nreset.reset_n
Вопрос как мне работать с ним. Я хочу по UART програмировать CFM на MAX10. Может кто нибудь работал с этим модулем?
Maverick
сообщение May 16 2017, 09:03
я только учусь...
Из: Украина
Пользователь №: 24 839
        port (
        port map (
Avalon MM
If it doesn't work in simulation, it won't work on the board.
"Ты живешь в своих поступках, а не в теле. Ты — это твои действия, и нет другого тебя" Антуан де Сент-Экзюпери повесть "Маленький принц"
Jenya7
сообщение May 16 2017, 09:21
Цитата(Maverick @ May 16 2017, 14:03) *
я изучал этот документ. он расчитан на крутых перцев, искушенных в этом коре.
sonycman
сообщение May 16 2017, 09:27
Любитель
Из: Тольятти
Пользователь №: 19 695
Авалон MM - очень простой интерфейс, даже начинающий без труда его должен понять.
Так что вникайте.
В этом компоненте два таких интерфейса - один простой, видимо, для команд, второй посложнее, с поддержкой пакетной передачи - для данных.
ЗЫ: с verilog решили не иметь дела, а только архаичный vhdl?
Jenya7
сообщение May 16 2017, 09:33
Так что вникайте.
нет времени изучать верилог, многое уже написано на вхдл.
а почему два сигнала. какой когда использовать?
avmm_csr_addr
avmm_csr_read
avmm_data_addr
avmm_data_read
то есть, что значит csr?
Сообщение отредактировал Jenya7 - May 16 2017, 09:34
sonycman
сообщение May 16 2017, 09:52
Любитель
Из: Тольятти
Это Control and Status Register.
Читайте сначала доки на компонент флэш памяти MAX 10 User Flash Memory User Guide (ug-m10-ufm-16.0.pdf).
Потом - на Avalon MM.
Доки - это ваше все.
И уже потом спрашивайте на форуме, что не понятно.
Jenya7
сообщение May 16 2017, 10:30
Так тут как раз таки непонятно. Они в документе говорят о UFM. А мне надо програмировать CFM.
Don Eugenio
сообщение May 16 2017, 11:38
Пользователь №: 92 805
При настройке IP-Core (Altera On-Chip Memory) у вас должна быть таблица с адресами и типом памяти (UFM, CFM). Надо просто в ней в Access mode для CFM поставить write and read и тогда она должна быть доступна для записи и чтения. (Железа с MAX10 нету чтобы проверить как это будет работать).
Jenya7
сообщение May 16 2017, 11:45
понял. а потом генерики наверно надо изменить на начало и старт CFM
onchip_flash_0 : component altera_onchip_flash
    generic map (
    INIT_FILENAME                       => "",
    INIT_FILENAME_SIM                   => "",
    DEVICE_FAMILY                       => "MAX 10",
    PART_NAME                           => "10M50SAE144I7G",
    DEVICE_ID                           => "50",
    SECTOR1_START_ADDR                  => 0,
    SECTOR1_END_ADDR                    => 8191,
    SECTOR2_START_ADDR                  => 8192,
    SECTOR2_END_ADDR                    => 16383,
    SECTOR3_START_ADDR                  => 16384,
    SECTOR3_END_ADDR                    => 114687,
    SECTOR4_START_ADDR                  => 114688,
    SECTOR4_END_ADDR                    => 188415,
    SECTOR5_START_ADDR                  => 188416,
    SECTOR5_END_ADDR                    => 360447,
    MIN_VALID_ADDR                      => 0,
    MAX_VALID_ADDR                      => 360447,
    MIN_UFM_VALID_ADDR                  => 0,
    MAX_UFM_VALID_ADDR                  => 114687,
    SECTOR1_MAP                         => 1,
    SECTOR2_MAP                         => 2,
    SECTOR3_MAP                         => 3,
    SECTOR4_MAP                         => 4,
    SECTOR5_MAP                         => 5,
    ADDR_RANGE1_END_ADDR                => 360447,
    ADDR_RANGE1_OFFSET                  => 2048,
    ADDR_RANGE2_OFFSET                  => 0,
    AVMM_DATA_ADDR_WIDTH                => 19,
    AVMM_DATA_DATA_WIDTH                => 32,
    AVMM_DATA_BURSTCOUNT_WIDTH          => 4,
    SECTOR_READ_PROTECTION_MODE         => 4,
    FLASH_SEQ_READ_DATA_COUNT           => 4,
    FLASH_ADDR_ALIGNMENT_BITS           => 2,
    FLASH_READ_CYCLE_MAX_INDEX          => 5,
    FLASH_RESET_CYCLE_MAX_INDEX         => 14,
    FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX  => 72,
    FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 21000000,
    FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 18300,
    PARALLEL_MODE                       => true,
    READ_AND_WRITE_MODE                 => true,
    WRAPPING_BURST_MODE                 => false,
    IS_DUAL_BOOT                        => "False",
    IS_ERAM_SKIP                        => "True",
    IS_COMPRESSED_IMAGE                 => "False"
правда непонятно какие генерики относяться к UFM а какие к CFM.
RSS Текстовая версия Сейчас: 21st August 2025 - 16:47
Страница сгенерированна за 0.01523 секунд с 7
