onizuka
сообщение Mar 24 2008, 20:03
Пользователь №: 34 012
может у кого нибудь есть приемо-передатчик для ftdi fifo (245R например).
onizuka
сообщение Mar 24 2008, 20:06
неоходимо соеденить ПЛИС и атмегу. коннект по spi.
вот такая реализация spi подойдет?
SPI_master.v - Verilog source for SPI module
Features:
- 25 MHz max operating frequency (on Xport 2.0)
- 8-bit Clock divider to obtain slower speeds
- Synthesizable and tested on Xport 2.0
Limitations:
- Only supports master mode
- Only supports MSB first data read/write
- Only supports sampling on rising edge and setup on falling edge
- Only 8-bit data transfers
- no IRQ support but has a busy bit that can be polled to assure module is not busy
- !SS pin has to be controlled by GPIO
Copyright © 2007  Steven Yu
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program.  If not, see <http://www.gnu.org/licenses/>.
module spi_master(addr, in_data, out_data, rd, wr, cs, clk, miso, mosi, sclk);
input wire [1:0] addr;
input wire [7:0] in_data;
output reg [7:0] out_data;
input wire rd;
input wire wr;
input wire cs;
input wire clk;
inout miso;
inout mosi;
inout sclk;
reg sclk_buffer = 0;
reg mosi_buffer = 0;
reg busy = 0;
reg [7:0] in_buffer = 0;
reg [7:0] out_buffer = 0;
reg [7:0] clkcount = 0;
reg [7:0] clkdiv = 0;
reg [4:0] count = 0;
always@(cs or rd or addr or out_buffer or busy or clkdiv)
begin
    out_data = 8'bx;
    if(cs && rd)
    begin
        case(addr)
        2'b00:   begin out_data = out_buffer; end
        2'b01:   begin out_data = {7'b0, busy}; end
        2'b10:   begin out_data = clkdiv; end
        endcase
    end
end
always@(posedge clk)
begin
    if(!busy)
    begin
        if(cs && wr)
        begin
            case(addr)
            2'b00: begin in_buffer = in_data; busy = 1'b1; end
            2'b10: begin clkdiv = in_data; end
            endcase
        end
    end
    else
    begin
        clkcount = clkcount + 1;
        if(clkcount >= clkdiv)
        begin
            clkcount = 0;
            if((count % 2) == 0)
            begin
                mosi_buffer = in_buffer[7];
                in_buffer = in_buffer << 1;
            end
            if(count > 0 && count < 17)
            begin
                sclk_buffer = ~sclk_buffer;
            end
            count = count + 1;
            if(count > 17)
            begin
                count = 0;
                busy = 1'b0;
            end
        end
    end
end
always@(posedge sclk_buffer)
begin
    out_buffer = out_buffer << 1;
    out_buffer[0] = miso;
end
assign sclk = sclk_buffer;
assign mosi = mosi_buffer;
endmodule
Сообщение отредактировал onizuka - Mar 24 2008, 20:52
zltigo
сообщение Mar 24 2008, 20:18
Из: Riga, Latvia
Пользователь №: 1 244
Цитата(onizuka @ Mar 24 2008, 23:06) *
вот такая реализация подойдет?
Moderator:
И все с увлечением бросились читать слепой не фоматированный текст. По ходу дела устраивая телепатические сеансы....
Старая истина - вопрос должен содержать не менее половины ответа.
onizuka
сообщение Mar 24 2008, 20:48
прошу прощения за неправильный формат текста
AlexKLm
сообщение Mar 24 2008, 21:02
Из: Мурманская
Пользователь №: 35 989
Висит, платка с 245-ой, уже с годик. А что такое 'verilog'? Просьба - не выражаться.
Демократия - это когда считается, что два дурака лучше одного умного
Суверенная демократия - это когда считается, что один дурак лучше двух дураков
onizuka
сообщение Mar 24 2008, 21:08
я имею в виду модуль для ПЛИСа для общения с 245R написанный на verilog'е. verilog - это язык описания аппаратуры, используемый для описания и моделирования электронных систем
zltigo
сообщение Mar 24 2008, 21:41
Из: Riga, Latvia
Цитата(onizuka @ Mar 24 2008, 23:03) *
может..
Если у Вы не можете описать что-то типа банального параллельного регистра, то что будете делать дальше?
onizuka
сообщение Mar 25 2008, 19:34
банальный параллельный не проблема. проблема с тем чтобы сделать slave модуль для wishbone например.
des00
сообщение Mar 26 2008, 03:57
Вечный ламер
Из: Томск
Пользователь №: 3 453
Are you using Wishbone, do you need some simple 'slaves' to test your bus with ?
http://www.opencores.org/projects.cgi/web/...t_port/overview
onizuka
сообщение Mar 26 2008, 20:38
Цитата(des00 @ Mar 26 2008, 06:57) *
спасиба. немного помогло
RSS Текстовая версия Сейчас: 16th August 2025 - 04:40
Страница сгенерированна за 0.01354 секунд с 7
