4 страниц V  < 1 2 3 4 >
> real time timer - прерывание по переполнению
srm
сообщение May 26 2010, 16:10
Сообщение #16
Из: Пермь
Пользователь №: 54 501
aaarrr, ок. спасибо за желание помочь.
CODE
template <uint_t i_timer>
class CTimerImpl
private:
static const AT91PS_TC m_timer;
static const uint_t m_timer_id =
i_timer == 0 ? AT91C_ID_TC0 :
i_timer == 1 ? AT91C_ID_TC1 :
i_timer == 2 ? AT91C_ID_TC2 : 0;
private:
static const uint32_t m_max_ticks = 0x10000;
static const uint32_t m_interrupt_priority = 1;
public:
static CTimerImpl<i_timer>* m_instance;
private:
float m_max_time_ms;
float m_ticks_per_ms;
private:
static void interrupt_handler()
uint32_t mask = m_timer->TC_SR;
uint32_t x = 0;
x = mask;
// m_instance->on_interrupt(mask);
inline bool on_interrupt(uint32_t mask)
if (mask & AT91C_TC_CPAS)
on_event_a();
if (mask & AT91C_TC_CPBS)
on_event_b();
if (mask & AT91C_TC_CPCS)
on_overflow();
return (mask & (AT91C_TC_CPAS | AT91C_TC_CPCS | AT91C_TC_CPBS)) != 0;
uint32_t calculate_optimal_divider(float max_period_ms)
const float cycles_per_ms = CSystem::get_instance()->get_frequency() / 1000.0f;
const float max_time_ms = m_max_ticks / cycles_per_ms;
m_max_time_ms = max_time_ms * 2.0f;
m_ticks_per_ms = cycles_per_ms / 2.0f;
if (m_max_time_ms > max_period_ms)
return AT91C_TC_CLKS_TIMER_DIV1_CLOCK;
m_max_time_ms = max_time_ms * 8.0f;
m_ticks_per_ms = cycles_per_ms / 8.0f;
return AT91C_TC_CLKS_TIMER_DIV2_CLOCK;
m_max_time_ms = max_time_ms * 32.0f;
m_ticks_per_ms = cycles_per_ms / 32.0f;
return AT91C_TC_CLKS_TIMER_DIV3_CLOCK;
m_max_time_ms = max_time_ms * 128.0f;
m_ticks_per_ms = cycles_per_ms / 128.0f;
return AT91C_TC_CLKS_TIMER_DIV4_CLOCK;
m_max_time_ms = max_time_ms * 1024.0f;
m_ticks_per_ms = cycles_per_ms / 1024.0f;
return AT91C_TC_CLKS_TIMER_DIV5_CLOCK;
__STL_THROW(invalid_argument("vary big period"));
protected:
virtual void on_event_a() = 0;
virtual void on_event_b() = 0;
virtual void on_overflow() = 0;
void initialize(float max_time_ms)
m_instance = this;
AT91F_AIC_CfgPMC();
AT91F_PMC_EnablePeriphClock(AT91C_BASE_PMC, 1 << m_timer_id);
// Disable TC clock
m_timer->TC_CCR = AT91C_TC_CLKDIS;
AT91F_TC_InterruptDisable(m_timer, 0xFFFFFFFF);
// Clear status register
mask = ~mask;
// Set mode
m_timer->TC_CMR = calculate_optimal_divider(max_time_ms) | AT91C_TC_WAVESEL_UP_AUTO | AT91C_TC_WAVE | AT91C_TC_EEVT_XC0;
// enable interrupts
AT91F_TC_InterruptEnable(m_timer, AT91C_TC_CPCS | AT91C_TC_CPAS | AT91C_TC_CPBS);
// configure interrupt handler
AT91F_AIC_ConfigureIt(
AT91C_BASE_AIC,
m_timer_id,
m_interrupt_priority,
AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL,
(void(*)())interrupt_handler
// enable interrupt
AT91F_AIC_EnableIt(AT91C_BASE_AIC, m_timer_id);
void deinitialize()
stop();
// disable interrupts
AT91F_TC_InterruptDisable(m_timer, AT91C_TC_CPCS | AT91C_TC_CPAS | AT91C_TC_CPBS);
// mode
m_timer->TC_CMR = 0;
// perepheral clock
AT91F_PMC_DisablePeriphClock(AT91C_BASE_PMC, 1 << m_timer_id);
void set_time_a(float time_a_ms)
m_timer->TC_RA = (uint32_t)(std_math::min(time_a_ms, m_max_time_ms) * m_ticks_per_ms);
void set_time_b(float time_b_ms)
m_timer->TC_RB = (uint32_t)(std_math::min(time_b_ms, m_max_time_ms) * m_ticks_per_ms);
void set_time_reset(float period_ms)
m_timer->TC_RC = (uint32_t)(std_math::min(period_ms, m_max_time_ms) * m_ticks_per_ms);
inline void start()
m_timer->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG;
inline void stop()
template <>
const AT91PS_TC CTimerImpl<0>::m_timer = AT91C_BASE_TC0;
template <>
const AT91PS_TC CTimerImpl<1>::m_timer = AT91C_BASE_TC1;
template <>
const AT91PS_TC CTimerImpl<2>::m_timer = AT91C_BASE_TC2;
CTimerImpl<i_timer>* CTimerImpl<i_timer>::m_instance;
вызываю так:
    CTimer<0> timer(10.0f);
    timer.set_time_a(2.0f);
    timer.set_time_b(6.0f);
    timer.set_time_reset(8.0f);
    timer.start();
    while(1);
Сообщение отредактировал aaarrr - May 26 2010, 16:16
Причина редактирования: Оформление цитаты исходника
srm
сообщение May 26 2010, 19:16
Сообщение #17
Из: Пермь
максимально упростил код. кому не лень, пожалуйста, скомпилируйте у себя и посмотрите чему равен mask. может у меня контроллер косячный...
void timer_handler()
  unsigned int mask = AT91C_BASE_TC0->TC_SR;
  mask ++;
int main()
  // enable PMC
  AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_FIQ;
  AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_TC0;
  // set mode
  AT91C_BASE_TC0->TC_CCR = AT91C_TC_CLKDIS;
  AT91C_BASE_TC0->TC_IDR = 0xFFFFFFFF;
  AT91C_BASE_TC0->TC_CMR = AT91C_TC_CLKS_TIMER_DIV5_CLOCK | AT91C_TC_WAVESEL_UP_AUTO | AT91C_TC_WAVE | AT91C_TC_EEVT_XC0;
  // enable interrupts on compare A, B, C
  AT91C_BASE_TC0->TC_IER = AT91C_TC_CPAS | AT91C_TC_CPBS | AT91C_TC_CPCS;
  AT91C_BASE_TC0->TC_RA = 100;
  AT91C_BASE_TC0->TC_RB = 200;
  AT91C_BASE_TC0->TC_RC = 400;
  // start
  AT91C_BASE_TC0->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG;
  // set irq handler
  AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_TC0;
  AT91C_BASE_AIC->AIC_SMR[AT91C_ID_TC0] = 0;
  AT91C_BASE_AIC->AIC_SVR[AT91C_ID_TC0] = (unsigned int)timer_handler;
  AT91C_BASE_AIC->AIC_ICCR = 1 << AT91C_ID_TC0;
  // enable interrupts from timer
  AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_TC0;
  while (1);
Сообщение отредактировал srm - May 26 2010, 19:23
srm
сообщение May 27 2010, 16:35
Сообщение #18
Из: Пермь
Вроде, немного разобрался. Если поставить значение делителя 1024 и значения регистров A ~ 10000, B ~ 40000, C ~ 60000, то ошибка перестаёт повторяться.
Я несколько изменил тестовый пример. в обработчике делаю так:
volatile static int ss;
  ss = (mask & (AT91C_TC_CPAS | AT91C_TC_CPBS | AT91C_TC_CPCS)) == (AT91C_TC_CPAS | AT91C_TC_CPBS);
А в программе постоянно вывожу значение ss:
  while (1)
    printf("%d", ss);
Если делитель = 32, A = 0x7331, B = 0xA681, С = 0xD335. Т.о. Время между двумя сравнениями 13136*32/48000 = 8,75 мс. печатается:
00000100001000001000000100000100000100000010000010000010000010000010000001000001
ну не может прерывание обрабатываться 8 миллисекунд! тем более, что при уменьшении времени (вплодь до десятых долей мс) выводится примерно то же самое.
srm
сообщение Jun 1 2010, 18:14
Сообщение #19
Из: Пермь
В реалтайме, вроде, всё норм. У меня 12 сервомеханизмов, шимы под них генерирует таймер at91sam7s256. Всё замечательно, сервы крутятся именно так, как мне нужно. Но, опять всплыл подводный камень и опять с real time timer'ом.
если я в цикле изменяю позицию серв:
  while (true)
    for (uint32_t x = 0; x < 20000; x ++)
      servo0.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f);
      servo2.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f);
      servo11.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f);
      servo0.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f);
      servo2.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f);
      servo11.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f);
, то всё прекрасно. Если я синхронизирую позицию по таймеру, то сервы время от времени начинают уезжать. т.е. двигается медленно, с постоянной скоростью в одну сторону, потом раз - и резко ушла в другую, потом снова медленно двигается вперёд. повторяется, примерно, один раз за 4 прохода цикла (20 сек):
  while (true)
    start_time = watch->get_time_us();
    while (true)
      uint64_t current_time = watch->get_time_us();
      if (current_time - start_time > 5000000)
        break;
      float x = (current_time - start_time) / 5000000.0f;
      servo0.set_position(servo::min_position + x * (servo::max_position - servo::min_position));
    while (true)
        break;
      servo0.set_position(servo::max_position - x * (servo::max_position - servo::min_position));
Сообщение отредактировал srm - Jun 1 2010, 18:19
aaarrr
сообщение Jun 1 2010, 18:58
Сообщение #20
Пользователь №: 1 448
Ну а get_time_us() что собой представляет?
Желание использовать RTT как источник информации о времени представляется, мягко говоря, несколько странным: таймер работает от RC-генератора, частота которого по определению может бултыхаться в широких пределах. Единственное разумное его применение - это поднимать процессор из idle по будильнику.
srm
сообщение Jun 1 2010, 19:14
Сообщение #21
Из: Пермь
aaarrr, я, вроде, по применению и использую. насколько я понял из даташита, real time timer служит как раз для получения информации о текущем времени. Тем более, что большая точность мне не нужна. Время мне нужно для того, чтобы движения робота были синхронны. Ну и плюс для работы ПИД регуляторов.
get_time_us всего лишь запрашивает показание счётчика и переводит тики в микросекунды.
По ходу дела, все эти глюки происходят из-за jtag'a. если запускать программу на выполнение без отладки, при отключенном Jtag'е, то глюки, вроде, не повторяются.. В общем, magic!
Сообщение отредактировал srm - Jun 1 2010, 19:18
aaarrr
сообщение Jun 1 2010, 19:20
Сообщение #22
Цитата(srm @ Jun 1 2010, 23:14) *
aaarrr, я, вроде, по применению и использую. насколько я понял из даташита, real time timer служит как раз для получения информации о текущем времени. get_time_us всего лишь запрашивает показание счётчика и переводит тики в микросекунды.
RC Oscillator Frequency: Min. 22 Typ. 32 Max. 42 kHz
Т.е. плюс-минус лапоть. Устраивает такое время?
Для формирования точных интервалов существует Periodic Interval Timer.
srm
сообщение Jun 1 2010, 19:35
Сообщение #23
Из: Пермь
мдя... робот будет ходить либо вдвое быстрее, либо вдвое медленнее smile.gif)))))
aaarrr
сообщение Jun 1 2010, 19:54
Сообщение #24
Вот именно. Тут не 5%, а совсем неприлично.
Nikitoc
сообщение Jun 25 2010, 07:47
Сообщение #25
Группа: Validating
Из: Днепропетровск
Пользователь №: 43 367
Добрый день. Дабы не плодить похожих тем решил спросить здесь.
Пытаюсь вызвать прерывание от RTTC. Работаю в Keil. Инициализирую так:
AT91S_AIC  *pAIC = AT91C_BASE_AIC;
void INIT_RTTC (int Alarm_Value_seconds) {                       /* Initialize Real Time Timer */
   pRTTC->RTTC_RTAR = (Alarm_Value_seconds - 1);
   pAIC->AIC_IECR = AT91C_ID_SYS;
   pAIC->AIC_SMR[1] = AT91C_AIC_PRIOR_HIGHEST | AT91C_AIC_SRCTYPE_POSITIVE_EDGE;
   pRTTC->RTTC_RTMR = (AT91C_RTTC_RTPRES & 0x8000) | AT91C_RTTC_ALMIEN | AT91C_RTTC_RTTRST;
Обработчик объявляю так:
__irq void RTTC_Interrupt_Handler (void) {
        if ((pRTTC->RTTC_RTSR & AT91C_RTTC_ALMS) != 0) {
              LED_ON;
        } else {
              LED_OFF;
В стартапе этот кусок поменял так:
Reset_Addr      DCD     Reset_Handler
Undef_Addr      DCD     Undef_Handler
SWI_Addr        DCD     SWI_Handler
PAbt_Addr       DCD     PAbt_Handler
DAbt_Addr       DCD     DAbt_Handler
                DCD     0        ; Reserved Address
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
Undef_Handler   B       Undef_Handler
SWI_Handler     B       SWI_Handler
PAbt_Handler    B       PAbt_Handler
DAbt_Handler    B       DAbt_Handler
                   PRESERVE8
                   IMPORT RTTC_Interrupt_Handler
IRQ_Handler     B       RTTC_Interrupt_Handler
FIQ_Handler     B       FIQ_Handler
В общем, прерывание не происходит. В чем ошибка, подскажите, пожалуйста.
P.S. Отладчиком смотрю содержимое регистра RTT_SR - флаги ALMS и RTCINC -поднимаются и SYSIRQ - находится в состоянии pending. Однако, перехода по вектору не происходит...
Сообщение отредактировал Nikitoc - Jun 25 2010, 08:29
aaarrr
сообщение Jun 25 2010, 08:46
Сообщение #26
Ну почему, почему все упорно пытаются работать по фронту, а? Для внутренних источников это в 99.9% случаев не нужно, для внешних - в 90%. В остальных 0.1% и 10% нужно проявлять предельную внимательность при обслуживании такого прерывания. В вашем случае отсутствует сброс источника в AIC, и запись в EOICR (хотя если принять во внимание переделку в стартапе, последнее уже несущественно).
А уж прерывания RTT - это просто одно большое недоразумение. Для их использования нужно иметь ну очень веские основания.
Nikitoc
сообщение Jun 25 2010, 09:07
Сообщение #27
Группа: Validating
Из: Днепропетровск
Изменил инициализацию таким образом:
pAIC->AIC_SMR[1] = AT91C_AIC_PRIOR_HIGHEST;
pAIC->AIC_ICCR = AT91C_ID_SYS;
А обработчик так:
LED_ON;
} else {
LED_OFF;
pAIC->AIC_EOICR = 0; // Reset AIC logic
Сообщение отредактировал Nikitoc - Jun 25 2010, 09:17
aaarrr
сообщение Jun 25 2010, 09:20
Сообщение #28
ICCR работает только для прерываний по фронту, писать его здесь бессмысленно.
А обработчик так:
EOICR нужно писать в любом случае, если уж оказались в прерывании, а не по каким-либо еще условиям.
Глобально прерывания разрешены? Отладчик малину не портит, часом?
Nikitoc
сообщение Jun 25 2010, 10:07
Сообщение #29
Группа: Validating
Из: Днепропетровск
Сообщение отредактировал Nikitoc - Jun 25 2010, 10:08
aaarrr
сообщение Jun 25 2010, 10:38
Сообщение #30
Разрешаются сбросом бита I регистра CPSR процессора. Из-под 'C' обычно предусматривается доступ в виде intrinsic-функций типа __enable_inerttupts(), или чего-то подобного - смотрите хелп своего компилятора.
RSS Текстовая версия Сейчас: 18th July 2025 - 18:08
Страница сгенерированна за 0.01641 секунд с 7
