> Покритикуйте проект
D-Luxe
сообщение Jan 24 2011, 14:59
Из: Пенза
Пользователь №: 55 642
Подскажите как можно покрасивее написать. Какие косяки?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ip_header is
  generic
   C_IP_ADDR_DST                      : std_logic_vector        := X"ac1e69bf"
  port
  RFF_WR_CLK_IN                     : in std_logic;
  RFF_DATA_IN                       : in std_logic_vector(0 to 31);
  RFF_WR_REQ_IN                     : in std_logic;
  RFF_DATA_OUT                       : out std_logic_vector(0 to 31);
  RFF_WR_REQ_OUT                     : out std_logic
--  RFF_FULL_OUT                     : out std_logic
end entity ip_header;
architecture IMP of ip_header is
  signal remove34_cnt : std_logic_vector(0 to 34) := "000" & X"00000000";
  signal ip_addr_dst : std_logic_vector(0 to 31) := X"00000000";
  signal ip_src_wrong : std_logic := '0';
  signal write_cnt : std_logic_vector(0 to 1) := "00";
begin
  RFF_DATA_OUT <= X"000008" & RFF_DATA_IN(24 to 31) when ( write_cnt(0) and RFF_WR_REQ_IN ) = '1' else
          X"000000" & RFF_DATA_IN(24 to 31) when ( write_cnt(1) and RFF_WR_REQ_IN ) = '1' else
          X"00000000";
  RFF_WR_REQ_OUT <= ( write_cnt(0) or write_cnt(1) ) and RFF_WR_REQ_IN;
  process( RFF_WR_CLK_IN )
  begin
    if ( RFF_WR_CLK_IN='1' and RFF_WR_CLK_IN'event ) then
      if ( RFF_DATA_IN(20)='1' and RFF_WR_REQ_IN='1' ) then
        remove34_cnt <= "100" & X"00000000";
      elsif ( RFF_DATA_IN(20)/='1' and RFF_WR_REQ_IN='1' ) then
        remove34_cnt <= '0' & remove34_cnt(0 to 33);
      end if;
      if ( remove34_cnt(25)='1' or remove34_cnt(26)='1' or remove34_cnt(27)='1' or remove34_cnt(28)='1' ) then
        ip_addr_dst <= ip_addr_dst(8 to 31) & ip_addr_dst(0 to 7);
      elsif ( ( remove34_cnt(25) or remove34_cnt(26) or remove34_cnt(27) or remove34_cnt(28) ) = '1' and ( ip_addr_dst(0 to 7) /= RFF_DATA_IN(24 to 31) ) ) then
        ip_src_wrong <= '1';
      elsif ( remove34_cnt(24)='1' ) then
        ip_addr_dst <= C_IP_ADDR_DST;
        ip_src_wrong <= '0';
      end if;
     if ( ip_src_wrong='0' and remove34_cnt(32)='1' ) then
          write_cnt <= "10";
     elsif ( ip_src_wrong='0' and remove34_cnt(33)='1' ) then
          write_cnt <= "01";
     elsif ( RFF_DATA_IN(20)='1' ) then
          write_cnt <= "00";
     else
          write_cnt <= "00";
      end if;
    end if;
  end process;
end IMP;
Нелегко оказаться на верном пути, но куда труднее его пройти.
(с) Уилл Роджерс
dsmv
сообщение Jan 25 2011, 14:14
Пользователь №: 8 284
1. Вместо FF_WR_CLK_IN='1' and RFF_WR_CLK_IN'event написать rising_edge( ff_wr_clk_in )
2. Вместо RFF_DATA_IN(20)/='1' написать RFF_DATA_IN(20)='0'
3. Все сигналы написать маленькими буквами
4. Добавить комментарии ко всем портам в entyty
5. Добавить комментарий в начало файла
6. Добавить в этот файл пакет ip_header_pkg, в котором привести описание компонента.
7. Выходы RFF_DATA_OUT и RFF_WR_REQ_OUT хорошо бы защёлкнуть на триггере
8. Проверить начальную установку. Похоже компонент будет в неопределённом состоянии
9. Проверить установку write_cnt <= "00" - встречается в двух местах, похоже на ошибку.
Для создания документации можно использовать DOXYGEN.
andrew_b
сообщение Jan 26 2011, 06:17
Из: Воронеж
Пользователь №: 1 757
Забудьте. Используйте numeric_std.
Вам охота считать все эти нули? Используйте others.
Victor®
сообщение Jan 26 2011, 07:47
Lazy
Из: Ukraine
Пользователь №: 76
library ieee;
entity ip_header is
  generic
  port
begin
          X"00000000";
  begin
      end if;
      end if;
          write_cnt <= "10";
          write_cnt <= "01";
          write_cnt <= "00";
     else
          write_cnt <= "00";
      end if;
    end if;
  end process;
end IMP;
Эквивалентно
if ( remove34_cnt(28 downto 25) /="0000"  then
P.S.
а вообще я бы ввел сигнал
remove_vec <= '1' when remove34_cnt(28 downto 25) /="0000" else '0';
в Вашем описании повторяется, и если надо что-то менять - надо менять в 2-х местах, что не есть хорошо.
P.P.S.
      end if;
Что-то кажется мне, что латчей тут будет...
Получается что-то вида
if a='1' then
       sig1 <= ...;
elsif a = '1' and b = '1' then
       sig2 <= ...;
elsif c = '1' then
       sig1 <= ...;
       sig2 <= ...;
end if;
Что будет с sig2 в первом условии? И с sig1 во втором?
И с условиями плохо....
второе условие будет проверяться, когда a не равно '1', но во втором
условии есть a='1'...
Вообщем переделать надо, мутно как-то все.
А косяки будет видно, если промоделируете... и чем раньше - тем лучше.
"Everything should be made as simple as possible, but not simpler." - Albert Einstein
D-Luxe
сообщение Jan 27 2011, 17:50
Из: Пенза
Переписал щас проект выглядит следующим образом. Моделируется нормально, но сбоит при работе на частоте 125МГц. Предполагаю, что дело в счетчиках. Что делать?
library ieee;
entity ip_header is
  generic
  port
  signal write_packet : std_logic := '0';
  signal addr_cmp : boolean;
  signal addr_cmp_cnt : std_logic;
begin
  RFF_DATA_OUT <= X"000008" & RFF_DATA_IN(24 to 31) when ( remove34_cnt(33) ) = '1' else
          X"00000" & RFF_DATA_IN(20 to 31) when ( write_packet ) = '1' else
          X"00000000";
  RFF_WR_REQ_OUT <= ( write_packet or remove34_cnt(33) ) and ( not ip_src_wrong );
  begin
        write_packet <= ( write_packet or remove34_cnt(33) ) and ( not RFF_DATA_IN(21) );
        else
          remove34_cnt <= remove34_cnt;
      end if;
      if ( addr_cmp_cnt='1' ) then
        else
          ip_addr_dst <= ip_addr_dst;
      end if;
      if ( ( addr_cmp_cnt='1' ) and addr_cmp ) then
        else
          ip_src_wrong <= ip_src_wrong;
      end if;
    end if;
  end process;
  process ( RFF_DATA_IN, ip_addr_dst, remove34_cnt )
  begin
     addr_cmp_cnt <= ( remove34_cnt(25) or remove34_cnt(26) ) or ( remove34_cnt(27) or remove34_cnt(28) );
    addr_cmp <= ip_addr_dst(0 to 7) /= RFF_DATA_IN(24 to 31);
  end process;
end IMP;
Эквивалентно
P.S.
P.P.S.
      end if;
if a='1' then
       sig1 <= ...;
       sig2 <= ...;
elsif c = '1' then
       sig1 <= ...;
       sig2 <= ...;
end if;
Спасибо за советы. Как описать чтобы латчей не было. Мой исправленный вариант пойдет?
Сообщение отредактировал D-Luxe - Jan 27 2011, 17:45
(с) Уилл Роджерс
DW0
сообщение Feb 3 2011, 19:34
Из: Украина
Пользователь №: 58 828
    end if;
латчей не будет т.к. все действия внутри условия
DiWhite
сообщение Feb 3 2011, 19:41
Пользователь №: 59 952
А что вообще за проект?
D-Luxe
сообщение Feb 4 2011, 10:20
Из: Пенза
    end if;
Не вижу логики в этой фразе. Ставятся ли защелки зависит от вложенных if'ов в этот if (if ( RFF_WR_CLK_IN='1' and RFF_WR_CLK_IN'event ) then).
Фильтрует езернет пакеты по айпи адресу.
(с) Уилл Роджерс
DW0
сообщение Feb 4 2011, 18:43
Из: Украина
если все сравнения делаются внутри if (if ( RFF_WR_CLK_IN='1' and RFF_WR_CLK_IN'event ) then.....{тут хоть что угодно}... end if; то в результате латчи не получатся.
, вот я и говорю их не будет пока {тут хоть что угодно} заключено в условие работы по переднему фронту.
D-Luxe
сообщение Feb 5 2011, 08:18
Из: Пенза
Хочешь сказать латчи ставятся при описании логики работающей по заднему фронту?
(с) Уилл Роджерс
DW0
сообщение Feb 5 2011, 15:57
Из: Украина
не придирайтесь к словам, хочу сказать, что в данной конструкции латчей нет! они могут быть если убрать условие работы по фронту заднему/переднему
D-Luxe
сообщение Feb 25 2011, 17:53
Из: Пенза
Финальная версия выглядит следующим образом.
library ieee;
entity ip_header is
  generic
    -- ADD USER GENERICS BELOW THIS LINE ---------------
    --USER generics added here
     C_HEADER_LENGTH                                    : integer                          := 272;
     C_ETH_HEADER                      : std_logic_vector        := X"0021856DBF4B001377AFCEC60800"; -- 14 байт
     C_IP_HEADER                              : std_logic_vector        := X"0500000000000000000000FF"; -- 12 байт
     C_IP_ADDR_SRC                      : std_logic_vector        := X"ac1e69bf";
     C_IP_ADDR_DST                      : std_logic_vector        := X"ac1e6964"
    -- ADD USER GENERICS ABOVE THIS LINE ---------------
  port
    -- ADD USER PORTS BELOW THIS LINE ------------------
    --USER ports added here
    -- From rocket
    WFF_WR_CLK_IN                     : in std_logic; -- По этой частоте происходит запись в компонент, в который пишется пакет с заголовком
    WFF_DATA_IN                         : in std_logic_vector(0 to 31);
    WFF_WR_REQ_IN                     : in std_logic;
    -- From emac
    WFF_FULL_IN                           : in std_logic;
    -- From emac
    RFF_WR_CLK_IN                     : in std_logic; -- По этой частоте происходит запись в компонент, в который пишется пакет без заголовка
    -- To emac
    WFF_DATA_OUT                       : out std_logic_vector(0 to 31);
    WFF_WR_REQ_OUT                   : out std_logic;
    -- To rocket
    RFF_WR_REQ_OUT                  : out std_logic;
    RFF_FULL_OUT                 : out std_logic;
    -- ADD USER PORTS ABOVE THIS LINE ------------------
-- Architecture section
  -- User signals
  signal Header : std_logic_vector(0 to C_HEADER_LENGTH-1) := C_ETH_HEADER & C_IP_HEADER & C_IP_ADDR_SRC & C_IP_ADDR_DST;
  signal Header_Copy : std_logic_vector(0 to 271);
  signal header_wr : std_logic;
  signal bytes35_cnt : std_logic_vector(0 to 34);
  signal remove_cnt : std_logic_vector(0 to 5);
  signal ip_addr_dst : std_logic_vector(0 to 31);
  signal ip_src_wrong : std_logic;
  -- Signals for C2R FIFO
  signal IP2FIFO_C2R_RdReq : std_logic;
  signal IP2FIFO_C2R_WrReq : std_logic;
  signal C2R_FIFO2IP_Data : std_logic_vector (0 to 31);
  signal C2R_FIFO2IP_Empty : std_logic;
  signal C2R_FIFO2IP_Full : std_logic;
  signal C2R_FIFO2IP_RdAck : std_logic;
  signal C2R_FIFO2IP_WrAck : std_logic;
  signal write_packet : std_logic;
  signal addr_cmp_cnt : boolean;
  signal remove24 : boolean;
  signal remove33 : std_logic;
  signal remove34 : std_logic;
begin
    FIFO_INST_C2R : entity ip_header_v1_00_a.fifo_generator_v4_3
    port map
        din                        => WFF_DATA_IN,
        rd_clk                    => WFF_WR_CLK_IN,
        rd_en                        => IP2FIFO_C2R_RdReq,
        rst                        => ipif_Bus2IP_Reset,
        wr_clk                    => WFF_WR_CLK_IN,
        wr_en                        => WFF_WR_REQ_IN,
        almost_empty            => open,
        almost_full                => open,
        dout                        => C2R_FIFO2IP_Data,
        empty                        => C2R_FIFO2IP_Empty,
        full                        => C2R_FIFO2IP_Full,
        valid                        => C2R_FIFO2IP_RdAck,
        rd_data_count            => open,
        wr_ack                    => C2R_FIFO2IP_WrAck,
        wr_data_count            => open );
    RFF_FULL_OUT <= C2R_FIFO2IP_Full;
    IP2FIFO_C2R_RdReq <= ( not ( C2R_FIFO2IP_Empty ) and not ( WFF_FULL_IN ) and not ( C2R_FIFO2IP_Data(20) ) ) or bytes35_cnt(34);
    header_wr <= C2R_FIFO2IP_Data(20) and ( not bytes35_cnt(34) );
    WFF_WR_REQ_OUT <= ( C2R_FIFO2IP_RdAck and not ( C2R_FIFO2IP_Data(20) ) ) or header_wr or bytes35_cnt(34);
    process( WFF_WR_CLK_IN )
    begin
        if ( WFF_WR_CLK_IN'event and WFF_WR_CLK_IN='1' ) then
            if ( header_wr='1' ) then
                Header_Copy <= Header_Copy(8 to 271) & Header_Copy(0 to 7);
                bytes35_cnt <= '0' & bytes35_cnt(0 to 33);
            else
                Header_Copy <= Header;
                bytes35_cnt <= "100" & X"00000000";
            end if;
        end if;
    end process;
    WFF_DATA_OUT <= C2R_FIFO2IP_Data when ( C2R_FIFO2IP_RdAck and ( not C2R_FIFO2IP_Data(20) ) ) = '1' else
                    X"000008" & Header_Copy ( 0 to 7 ) when ( header_wr and bytes35_cnt(0) ) = '1' else
                    X"000000" & Header_Copy ( 0 to 7 ) when ( header_wr ) = '1' else
                    X"000000" & C2R_FIFO2IP_Data(24 to 31) when ( bytes35_cnt(34) = '1' ) else
                    X"00000000";
    RFF_DATA_OUT <= X"000008" & RFF_DATA_IN(24 to 31) when ( remove33 ) = '1' else
                        X"00000000";
    RFF_WR_REQ_OUT <= ( write_packet or remove33 ) and ( not ip_src_wrong );
    write_packet <= ( write_packet or remove34 ) and ( not RFF_DATA_IN(20) );
    begin
            remove_cnt <= (others => '0');
        elsif ( RFF_WR_REQ_IN='1' and remove_cnt < X"24" ) then
            remove_cnt <= remove_cnt + '1';
        else
            remove_cnt <= remove_cnt;
        end if;
        if ( addr_cmp_cnt ) then
        elsif ( remove24 ) then
        else
        end if;
        if ( addr_cmp_cnt and addr_cmp ) then
        else
        end if;
        end if;
    end process;
    process ( RFF_DATA_IN, ip_addr_dst, remove_cnt )
    begin
        addr_cmp_cnt <= ( ( remove_cnt = "011001" ) or ( remove_cnt = "011010" ) ) or ( ( remove_cnt = "011011" ) or ( remove_cnt = "011100" ) );
        remove24 <= ( remove_cnt = "011000" );
    end process;
    remove33 <= '1' when ( remove_cnt = "100001" ) else '0';
    remove34 <= '1' when ( remove_cnt = "100010" ) else '0';
end IMP;
(с) Уилл Роджерс
RSS Текстовая версия Сейчас: 15th July 2025 - 20:16
Страница сгенерированна за 0.01476 секунд с 7
