> DDRIII+HPCII глюки или руки?
billidean
сообщение Feb 23 2011, 05:51
Из: г. Екатеринбург
Пользователь №: 59 925
Всех с праздником, мужики.
Уже неделю сижу с проблемой::
есть код (примерный):
    write_data_in    : in std_logic_vector(63 downto 0);
    read_data_out    : out std_logic_vector(63 downto 0);
    rdata_valid_out    : out std_logic := '0';
    local_size <= "010";
process( phy_clk )
    variable var_local_address : std_logic_vector(23 downto 0) := ( others => '0' );
    variable counter_write : integer := 0;
    variable counter_read_req  : integer := 0;
    variable counter_read_data : integer := 0;
begin
    case( step ) is
    when step_pre            =>
                    if( start_write == '1' ) then
                        counter_write := 100;
                        step := step_write_first;
                    end if;
                    if( start_read == '1' ) then
                        counter_read_req  := 100;
                        counter_read_data := 100;
                        step := step_read;
                    end if;
                    local_burstbegin    <= '0';
                    local_write_req    <= '0';
                    local_read_req    <= '0';
                    local_address    <= ( others => '0' ); --начинаю с 0-го адреса
                    var_local_address    <= ( others => '0' ); --начинаю с 0-го адреса
    when step_write_first    =>
                    if( counter_write = 0 ) then
                        step := step_pre;
                    else
                        if( local_ready = '1' ) then
                            local_address     <= var_local_address;
                            local_write_req   <= '1';
                            local_burstbegin  <= '1';
                            local_write_data(63 downto 0)  <= write_data_in(63 downto 0);
                            step := step_write_second;
                        end if;
                    end if;
    when step_write_second    =>
                    counter_write       := counter_write - 1;
                    var_local_address <= (инкремент var_local_address)
    when step_read            =>
                    if( counter_read_req = 0 ) then
                        step := step_pre;
                    else
                            local_read_req    <= '1';
                            counter_read_req := counter_read_req - 1;
                        end if;
                    end if;
                    if( counter_read_data = 0 ) then
                        rdata_valid_out <= '0';
                        step := step_pre;
                    else
                        if( local_rdata_valid = '1' ) then
                            rdata_valid_out <= '1';
                            read_data_out(63 downto 0) <= local_rdata(63 downto 0);
                            counter_read_data := counter_read_data - 1;
                        else
                        end if;
                    end if;
    end case;
end process;
На железе (Stratix IV) получаю данные read_data_out правильные процентов на 99, а 1% битые.
Почему так???
Не совсем вник в то, когда менять адрес относительно сигнала local_burstbegin, по фронту или по спаду бурста.
billidean
сообщение Feb 23 2011, 16:04
Из: г. Екатеринбург
Подскажите плз, правильно ли я представляю себе циклограмму при local_size=2:
phy_clk          :  _I`I__I`I__I`I__I`I__I`I__I`I__I`I__I`I__I`I__I`I__I`I__I`I__
local_burstbegin :  _I````I____I````I____I````I____I````I____I````I____I````I____
local_address    :  _<:::::::::><:::::::::><:::::::::><:::::::::><:::::::::>_____
local_write_data :  _<:::::::::><:::::::::><:::::::::><:::::::::><:::::::::>_____
Сообщение отредактировал billidean - Feb 23 2011, 16:05
billidean
сообщение Feb 24 2011, 14:31
Из: г. Екатеринбург
Спасибо ОГРОМНОЕ замечательному форуму за такую плотную поддержку.
Но я уже сам все сделал.
З.Ы. А могли бы подсказать.
З.З.Ы. Вот так все здесь и делают: "Я то знаю ответ tongue.gif но говорить не буду. Пусть сами пытаются"
dinam
сообщение Feb 25 2011, 03:11
Из: Наукоград Кольцово(Новосибирск)
Пользователь №: 5 898
Сочувствую, сам не могу понять в чем проблема в моём случае (см. соседний топик).
dvladim
сообщение Feb 25 2011, 17:44
Из: Воронеж
Пользователь №: 24 737
Ну а объяснить в чем была проблема и в чем состояло решение?
billidean
сообщение Mar 2 2011, 13:48
Из: г. Екатеринбург
В документации на HPCII говорится, что использовать сигнал precharge необходимо при переключении банков памяти,
Моя система работает с адресами в пределах одного банка. Запись данных производится пакетаами по 100 слов. Сейчас я использую local_size=4(выше в коде было 2).
Я как честный человек провожу строб сигнала precharge каждый раз перед началом передачи пакета(100).
Опытным путем я выяснил (может это только у меня wacko.gif ), что при таком раскладе в память пишутся какие-то битые данный процентов на 5.
Я долго тыкал клаву на всякие кнопки и натыкал выход из моей ситуации.
При каждой установке бурста(local_burstbegin) я загонял строб сигнала precharge, и о чудо w00t.gif данные перестали биться.
З.Ы.: вот такая моя история борьбы начинающего ПЛИС-схемотехника с HPCII
Сообщение отредактировал billidean - Mar 2 2011, 13:49
warrior-2001
сообщение Mar 2 2011, 15:35
Из: Таганрог, Ростовская обл.
Пользователь №: 40 792
При генерации контроллера отключите precharge. Данная опция подробно описана в мануале.
Глупцы игнорируют сложность. Прагматики терпят ее. Некоторые могут избегать ее. Гении ее устраняют.
billidean
сообщение Mar 3 2011, 13:34
Из: г. Екатеринбург
Сегодня пробовал отключить эту галочку при насчтройке контроллера DDR3. В результате данные записываются битые на 50 процентов.
Вернул обратно - все ок.
warrior-2001
сообщение Mar 4 2011, 12:36
Думаю, что после отключения "галочки" поменялась времянка. Вообще основные мучения с ddr/ddr2 у меня были связаны с шиной Avalon. Как только выяснилось это - http://www.alteraforum.com/forum/showthrea....oss=burstbegin , и ещё ряд глюков был устранён Альтерой - всё проблемы ушли.
Физический интерфейс не может так глючить - обычно проблемы либо в таймингах либо в локальной шине. При наличии свободного места в ПЛИС контроллеры памяти обычно без проблем запускаются на максимальных скоростях.
billidean
сообщение Mar 18 2011, 14:46
Из: г. Екатеринбург
Цитата(warrior-2001 @ Mar 4 2011, 16:36) *
... и ещё ряд глюков был устранён Альтерой - всё проблемы ушли.
А можете уточнить, какие именно глюки и кто именно устранял???
billidean
сообщение Mar 19 2011, 13:03
Из: г. Екатеринбург
при local_size=4 и манипулированием сигналами precharge и refresh у меня вроде получилось сделать ОЗУ из DDR3.
Но попытки сделать все то же самое с local_size=64 ничего не получается, данные портиться начинают.
Вообще кто-нибудь использовал local_size=64? если да, то ПЛЗ подскажите что-нить help.gif
novartis
сообщение Mar 19 2011, 14:58
Из: Свердловский регион
Пользователь №: 52 845
У меня коллега на работе тоже с такой проблемой мучается, если справится, отпишусь.
warrior-2001
сообщение Mar 21 2011, 12:53
Конкретные глюки описаны в err data на ddr/dd2/dd3 контроллеры. Устраняет разработчик - Altera.
Проверил свои проекты - local_size меняется от 1 до 32. 64 пока не использовал.
Если при отключении чего-то появляются ошибки - я бы копал в эту сторону. Повторюсь, при генерации оставляю precharge на откуп Altera.
nmurzin
сообщение Mar 22 2011, 15:46
Из: г.Зеленоград
Пользователь №: 61 141
Объясните пожалуйста,
а зачем вобще задирать local_size более чем 2 ?
Ведь burst_begin можно дергать непрерывно.
warrior-2001
сообщение Mar 23 2011, 08:48
Если, к примеру, в проекте используется большая локальная шина, со своим интерконнектом и прочими вкусностями.
Мне нужно в рамках спецификации этой шины подключить к ней контроллер ddr/ddr2/ddr3 фирмы Altera. Берётся Avalon и делается переходник между ним и этой локальной шиной, с поддержкой пачек, с handshake и т.д.
И вот чтобы этот переходник не весил много - проще пачки передавать напрямую. Раз контроллер поддерживает - отчего не пользоваться-то?
RSS Текстовая версия Сейчас: 18th July 2025 - 12:19
Страница сгенерированна за 0.01516 секунд с 7
