> Sabrewing FPU/ALU
Postoroniy_V
сообщение Jun 27 2012, 16:24
МедвеД Инженер I
Пользователь №: 951
случайно нарыл
http://caes.ewi.utwente.nl/index.php/resea...erial/sabrewing
Sabrewing tightly integrates floating-point and integer arithmetic in a single datapath. Because the architecture is mainly intended for use in low-power embedded digital signal processors, the following design constraints where adhered during its implementation: limited use of pipelining for the convenience of the compiler; maintaining compatibility with existing technology for easy integration; minimal area and power consumption for applicability in embedded systems. The architecture is tailored to digital signal processing by combining floating-point fused multiply-add and integer multiply-accumulate. It could be deployed in a multi-core system-on-chip designed to support applications with and without dominance of floating-point calculations.
может кому пригодится хотя и
The VHDL structural description of this architecture is available for download under BSD license
Cogito ergo sum
RSS Текстовая версия Сейчас: 12th August 2025 - 02:17
Страница сгенерированна за 0.01399 секунд с 7
