> cannot back annotate in OrCAD Layout Plus
pavel47
сообщение Dec 19 2005, 17:37
Из: Lausanne, Switzerland
Пользователь №: 12 413
Hello
I cannot back annotate from Layout.
I swaped in layout 2 gates from 2 different components of the same type.
When I try to back annotate, I receive the message:
External pin swap (U2.7 and U1.7) not supported.
The same message for other 2 pins of gate.
So, I can't annotate to capture the gate's swapping from 2 different components???
Thanks in advance.
Pavel.
Ответов (1 - 4)
Alex11
сообщение Dec 19 2005, 21:32
Из: С-Петербург
Пользователь №: 965
Yes, you can use gates and pin swap only in one chip.
pavel47
сообщение Dec 19 2005, 22:44
Thanks Alex
But this feature isn't documented in Layout Plus help...
dm_mur
сообщение Dec 20 2005, 04:35
Из: Омск
Пользователь №: 3 195
Цитата(pavel47 @ Dec 19 2005, 20:37) *
Hello
Thanks in advance.
Pavel.
You can use swaping in the same type different components. In data of packing of a component check up an option "internal swap gate only"
pavel47
сообщение Dec 23 2005, 13:38
... option "internal swap gate only".
Thanks
RSS Текстовая версия Сейчас: 27th July 2025 - 02:48
Страница сгенерированна за 0.01377 секунд с 7
