> Cypress! - Na POMOOOOOOOOOOSH'....................
dimi0579
сообщение Jun 18 2007, 13:33
Пользователь №: 27 201
dobryj den vsem!
raspisyvaü situaciü:
usb (Cy7C68013) dol*en generirovat' na primer 4isla i otkladyvat' k primeru na EP6. a ja na kompe s4ityvaju eti 4isla s EP6.
vtoroj den' mu4aüs' i ne mogu ponjat' gde tut oshibka, etc.
kak primer beru example 'bulkloop' von cypress i menjaü tam TD_Pool():
void TD_Poll(void)              // Called repeatedly while the device is idle
  WORD i;
  WORD count;
//  if(!(EP2468STAT & bmEP2EMPTY))
//  { // check EP2 EMPTY(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is empty
     [b]if(!(EP2468STAT & bmEP6FULL))
     {  // check EP6 FULL(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is full
        for(i =  0; i < 64; i++)
            EP6FIFOBUF[i] = i + 1;
        EP6BCH = 0x00;
        SYNCDELAY;
        EP6BCL = 0x40;
    else
        //SYNCDELAY;
        //EP6BCL = 0x80;         // re(arm) EP6OUT
    }[/b]
  if(!(EP2468STAT & bmEP4EMPTY))
  { // check EP4 EMPTY(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is empty
     if(!(EP2468STAT & bmEP8FULL))
     {  // check EP8 FULL(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is full
        APTR1H = MSB( &EP4FIFOBUF );
        APTR1L = LSB( &EP4FIFOBUF );
        AUTOPTRH2 = MSB( &EP8FIFOBUF );
        AUTOPTRL2 = LSB( &EP8FIFOBUF );
        count = (EP4BCH << 8) + EP4BCL;
        // loop EP4OUT buffer data to EP8IN
        for( i = 0x0000; i < count; i++ )
           // setup to transfer EP4OUT buffer to EP8IN buffer using AUTOPOINTER(s)
           EXTAUTODAT2 = EXTAUTODAT1;
        EP8BCH = EP4BCH;
        SYNCDELAY;
        EP8BCL = EP4BCL;        // arm EP8IN
        SYNCDELAY;
        EP4BCL = 0x80;          // re(arm) EP4OUT
izmenenno v principe tol'ko odno mesto (*irnyj shirft)
moja proga 4itaet EP6. ona to4no rabotaet, tak kak proverjal na origenale (bulkloop).
nadeüs' raspisaml problemu doskonal'no.
pomogite naiti oshibku. ili esli u kogoto podobnaja proga est', to skin'te na borja@htwg-konstanz.de
blagodarü za ranee
RSS Текстовая версия Сейчас: 11th August 2025 - 15:31
